Question about GMC 2003 Envoy SLE
2003 gmc envoy: shifter will not click into park, key stuck in ignition and won't go into off position
Transmission is in park, the ignition will not register that it is in park
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Problem with the actuater.either needed to be adjusted or replaced.Actuater is visible and located on the gearbox it self .
Posted on Jan 05, 2014
  • Tracey Rider Kelly
    Tracey Rider Kelly Jan 07, 2014
    Thanx will have my hubby check it out
2 Suggested Answers
  • 82 Answers
SOURCE: 2003 gmc envoy: shifter will not click into park, key stuck in ignition and won't go into off position to take out. How to fix?
Sounds like the shift cable needs adjusting on the transmission. It will be on the driver's side, heavy black cable sheath with an adjuster. Adjust it a few turn in one direction then check to see if it gets better or worse. Fine tune as needed
Posted on Dec 30, 2013
How to remove my Keys from 2003 envoy they are stuck
Ignition Lock Cylinder Control Actuator
If the vehicle is equipped with a floor mounted console gear shifter, it has a ignition lock cylinder control actuator system in the steering column as an added safety feature. The ignition lock cylinder control actuators purpose is to prevent the steering wheel from being locked when the transmission is in gear and the vehicle may still be moving. The column ignition lock system consists of a ignition lock cylinder control acutator, and a park position switch that is located in the A/T shift lock control switch. The ignition lock cylinder control acutator contains a pin that is spring loaded out to mechanically prevent the ignition key cylinder from being turned to the lock position when vehicle transmission is not in the Park position. If vehicle power is lost, and/or the transmission is not in the Park position the operator will not be able to turn the ignition key to the lock position and will not be able to remove the ignition key from the column. GM has had some problems with this , If you have the console shifter there is a micro switch that when put into park a linkage pushes on this micro switch closing the circuit to ignition lock cylinder control actuator allowing you to remove your key ! These linkages fall out causing this problem ,an have electrical wiring problems as well ! I fixed a 2006 Chevy cobalt that had this same problem by getting a used shifter assembly at the auto salvage year ! cost $20.00 . There mite be a access hole under the bottom of the steering column with a release button up inside !
Apr 17, 2015 | 2003 GMC Envoy
Dec 30, 2013 | GMC 2003 Envoy SLE
I have a 2003 Chevy blazer xtreme 4.3 v6 automatic transmission and its giving me some issues with the console shifter and ignition system! Every other time I put the blazer in park and try to take the key...
Fixing stuck key in your gmc envoy same as a blazer !
May 08, 2017 | Cars & Trucks
Key stuck in 2004 gmc envoy and car will not start
make sure battery is 12.6 volts. if not you not going to be able to get transmission go all the way in park to remove ignition key.when you press brake pedal it energize brake transmission shift interlock to get transmission all way in park to remove ignition key.if all is good battery is 12.6 volts.sound like ignition switch lock cylinder broken more likely.
Nov 06, 2011 | 2004 GMC Envoy
My key wont turn to off in order to remove my key from ignition while in parking
Ignition - Key Stuck In Ignition Switch/Won't Turn Bulletin No.: 06-02-35-005 Date: February 28, 2006 TECHNICAL Subject: Key Stuck in Ignition, Key Will Not Return to Off Position, Shifter Button Won't Release in Park Position (Adjust Shifter Detent Finger) Models: 2002-2005 Chevrolet Monte Carlo Condition Customers may comment on any of the following conditions: - The key is stuck in the ignition cylinder. - They cannot return the key to the off position to remove the key. - The shifter button won't release in the park position. Cause This condition may be caused by the detent finger shifting over time. This may result in mis-alignment and binding of the shift rod on the shift position guide.
WHERE YOUR SHIFTER IS YOU WILL HAVE TO TAKE IT APART ..MAYBE THE RUBBER BOOT IS IT THE WAY,OR THE SHIFT LOCK SELINOID WHENT BAD
Aug 05, 2011 | 2005 Chevrolet Monte Carlo
2005 GMC Envoy key is stuck in accessory position in the ignition with dead battery and transmission stuck in park. Will replacing battery help or is it security system lock down? If it is the security...
Jump starting the battery may be all you need. If this vehicle was not in park when the battery went dead and when you got in to start it it was dead. You then probably put it into park trying to start it.
But the issue at this time is if it was in neutral when the battery went dead the you changing the selector to park may not actually have placed the transmission in park. With electronic gear selection it actually need power to the system to place the transmission in park.
Without it really being in park the key may move to the lock position.
A bit of quess work here but I hope for you I hit the mark.
May 20, 2010 | 2005 GMC Envoy
Igniton key is stuck in switch and won't turn off
Check the shift cable to the shifter to the transmission,and the shifter could be malfunctioning.
May 16, 2010 | 2004 GMC Envoy
Gmc yukon stuck in park.
possible brake switch not sending signal to shifter solenoid to allow shifter movement. possible broken shifter knob/relay rod in shifter assembly
Nov 15, 2009 | 2002 GMC Envoy
I have Envoy 2002 XL 4WD Transmission indicator stuck in D
I think the linkage came off the transmission. It is on the left side of the transmission, near the pan. There is a neutral safety switch that is used in that area. That's why the indicator is different than what the transmission is really in. The linkage arm may be worn and/or the shifter cable end is worn and will not stay on the linkage arm.
Dec 25, 2017 | 2002 GMC Envoy
GMC 2003 Envoy SLE Logo
108 people viewed this question
Top GMC Heating & Cooling Experts
gbob59
Lawrence Oravetz
Nicola Conroy
Are you a GMC Heating and Cooling Expert? Answer questions, earn points and help others
