Question about Crosley CR66 Rochester 5 in 1 Entertainment Center with auxiliary
Hooking up external speakers
How do i hook up external speakers
Hooking external speakers tv
If you use your headphone socket for an output, you will have to use an external mixer to access a split signal.
Nov 12, 2013 | Lenovo Computers & Internet
How do I conect external speekers and get them to work? Sansui 22
Depends. What are you hooking external speakers to? Car radio? If the speakers do not exceed the output of the radio, you can directly hook speakers up to the radio by connecting 2 wires. If they do exceed the radio output, you will need an amplifyer.
Jan 10, 2012 | Televison & Video
HTR-5740 Subwoofer Hooking Up Issue
You can use a hi-level to low-level adapter. Just remember, the Yamaha does not send power (wattage) to the sub, just signal. You need to use a subwoofer that has an amplifier either externally or built in.
Jun 26, 2009 | Yamaha HTR-5740 Receiver
No Audio when disconnect from external amp and hook to speakers
In a radio like your Pioneer and all similar units there are always a pre-amp circuit that feeds a power amp circuit,In some players there are more than one pre-amp circiuts. It is possible and highly probable that the power amp circuit in your Pioneer is shorted, so you still get some audio output , but very little. I believe this is your problem and I suggest that you bring it to a repair shop for an estimate or replace the unit. Good luck and please rate this answer, Thanks.
Apr 12, 2009 | Pioneer Car Audio & Video
Hooking up external speakers to a VIZIO
There is only one choice of audio out and that is the optical out put which locate on the far right if facing back of TV.
Mar 29, 2009 | Vizio L32 32 in. LCD HDTV
Hooking up external speaskers to my Panasonic TV
you will need to buy a surround sound receiver. the new tv's do not have an external speaker jacks on them. you might also try a old stereo receiver hooked up to the tv's audio out jacks
Jan 24, 2009 | Panasonic 50" 720p Flat-Panel Plasma HDTV
Do you have a headphone jack ?
You can hook up there that would be the easiest way.
Jan 18, 2009 | JVC AV-48WP74 48" Rear Projection...
Hooking up stock speakers
is there a external jack for a speaker or head phones? If there is try your head phones or ext speaker. If you look inside your case you will see that the speaker wires go from the sound board to the jack to the speakers. Some times the jack gets something in it or stuck open and it doesnt let the sound go to the speakers
Jan 10, 2008 | Acer Aspire 5630 Notebook
Magnavox projection tv hookup to external speakers
The external (audio out) connectors are intended for use with an external amp, not direct speaker connection.
Sep 02, 2017 | Televison & Video
Crosley CR66 Rochester 5 in 1 Entertainment Center with auxiliary Logo
96 people viewed this question
Top Crosley Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Crosley Furniture Expert? Answer questions, earn points and help others
