Question about Garden
Sprinkler system, pump makes humming nose but never turns on
When I turn on my sprinkler system, I hear the pump start humming but nothing happens, it never actually clicks on.
    Problem Solver:
  • 5 Answers
Is this a MQ3-35??? If so, it is most likely the capacitor. This is easy to replace. Take out the 4 screws from the push button cover. The capacitor is the white plastic cylinder with wires plugged in the top. Put the wires in the new capacitor exactly the same as the old one. Be sure to unplug that pump before you do anything.
Posted on Aug 29, 2009
  • 864 Answers
Make sure the water to the pump is turned on.  If it is then it sounds like the pump may have to be replaced.
Posted on May 20, 2009
How do I get my Hunter ICC irrigation control box to turn on?
Check batteries with tester. Check internal fuse (sometimes same compartment as batteries. May have have to spend the $20.00
Jan 18, 2015 | Hunter ICM-400 ICC 4 Station Sprinkler...
How do I stop water from coming out of sprinkler heads after the pump cuts off
There will be water come out of the heads for a few min after they shut off to bleed the pressure off there is no way to stop it you might turn your system timer down a little
Sep 14, 2014 | Garden
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/support/
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
I have Intermatic sprinkler model T8845pv. I want to set it for daily watering in only one of 8 zones. When I remove the gold pins in the main dial and locate the zone I want to water, it waters the...
Intermatic sprinkler timers are 24 hour repeat cycle, with day-skipper option.
The timer does not change zones. The timer just turns ON-and-OFF at scheduled times.
Each tripper represents 12-15 minutes of watering. And then the timer circuit turns OFF.
When timer circuit turns OFF, the sprinkler system is designed to advance to next zone each time.
So when the timer circuit turns OFF and then turns ON again, your sprinkler control starts watering the next zone. This is the way sprinkler systems are designed.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
If you had a sprinkler system with 1 zone, or could change your sprinkler system to 1 zone on certain days, then the timer would turn that zone on-off each time.
Call a local sprinkler company and see if they have a dual control or some solution >> but sprinkler controls are outside my area of expertise. I am timer expert.
You could solve problem with two separate sprinkler systems, but that would require two timers. I have never seen a 2-channel sprinkler timer. There are electronic two-channel timers that can handle two different programming schedules with minimum 1 minute on-off, and these timers can cost a few hundred dollars up to thousands, PLUS cost of the dual sprinkler system. Add a comment and let me know if two-channel timers are something you want information on.
Apr 27, 2011 | Intermatic R8806P101C -...
I have an aquamate pump and when i connect it to a continuous sprinkler it stops and starts contiuously
The pump is putting out too much water for the sprinkler.
You can raise the pump shut off pressure at the switch until it is higher than the pressure that the pump runs at with the sprinkler operating. You should have a surge tank connected to the system to give the pump time to balance with the sprinkler.
You can use more water with the sprinkler. This could mean adding another sprinkler or increasing the nozzle size of the existing sprinkler.
Dec 05, 2010 | Garden
1-1/2 hp sprinkler pump hangs up and just hums sometime
The impeller and or bearings are seized. You may have to force the impeller loose (breaking it to get the unit apart). See if you can obtain the bearings and impeller and shaft seal before attempting the overhaul. Be aware that the hardware attaching the motor to the pump housing may need lubrication before attempting to remove.
Apr 06, 2010 | Pool & Spa
Sprinkler head does not spray water
Make sure when you pull the head to ck the screen you turn the system on and blow out the line, then run a hose through the head to make sure it isn't plugged up anyway. Depending on the head and the cost of a new one will dictate cleaning or replacement.
Oct 04, 2009 | Garden
Garden Logo
630 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
