Question about ViewSonic VX924 19" LCD Monitor
Monitor has no power
I have a Viewsonic 19" widescreen LCD monitor, and it no longer powers on. I have checked the cord, and the connection, but it still doesnt turn on. Is there anything else I can do to salvage the monitor?? It is out of warranty, but is still a very nice monitor, just doesn't turn on.
  • 42 Answers
Is posible a malfunction on the power on/off button or a internal integrate burn, the best thing that u can't do is to get on a service dep to get fix if u don't have a good electrical degree, im sorry for that but this is the real truth.
Posted on Oct 18, 2007
24" widescreen lcd viewsonic monitor will not power up.
Check the power supply caps, solder connections, etc.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Aug 06, 2010 | ViewSonic VP920b 19" LCD Monitor
My viewsonic monitor works fine for some time but the n suddenly stops displaying even though the power cord is fine ...after some time it comes alive or some times by fidgeting with the power cord.....
It sounds like a loose connection. The easy thing to try is to replace the power cord to make sure that's not the problem. If that doesn't fix it, it's probably a broken or loose wire inside the monitor that you would need to trace down with a multimeter.
Oct 16, 2009 | ViewSonic VX924 19" LCD Monitor
Monitor boots ok, then "Analog" appears/monitor shuts off
Does it have a digital port being used? If you are using the DVI port, it is probably digital. Try using the menu to selct the port. If it doesn't work, not sure from here. What is the model number?
Aug 01, 2009 | E-Machines 19" Widescreen Flat Panel TFT...
Monitor no power
manipulate each ac power cord wiggle it . PS died?
Aug 01, 2009 | LG 19" Widescreen Flat Panel LCD Monitor
ViewSonic VX910 monitor has a power supply issue.
Your monitor have a bad condensator in the PSU.
The only thing to do is to replace the Power Supply Unit (very expensive, more than a new monitor) or if you have electronic tools, found and replace that condensator.(cheaper way...)
or
Have you connected your monitor with a new power cord ?
Best Regards!
Jun 29, 2009 | ViewSonic VX910 19" LCD Monitor
Gateway 19inch wide screen, lcd monitor stopped working randomly.
It could be a faulty power cord. Try plugging it in and moving the cord around in the areas where it takes the most movement. Do the same with the data cable to see if you get a response there. If your cables are fine, the problem is most likely hardware in the monitor - in that case you're better off replacing the monitor.
May 06, 2009 | Gateway 19" Widescreen Flat Panel TFT LCD...
No display, clipping sound appear
The clipping sound is the internal safety switch that keep shutting down the monitor.
It means there is an internal problem on the main board (overvoltage, bad component , short).
Try unplugging power cord and leaving it unplugged two or three hours, this will reset ICs by draining power completely from circuits, it is called hard reset, it rarely works.
CRT monitors waste up to 15 times more energy than TFT screen, if your CRT starts giving troubles, then it is a good time for upgrading it to a new TFT.
17'' start at $120
17'' Dell 1703FPt DVI LCD Monitor w/USB Hub (Black/Silver) -B
171ABB 17" Widescreen LCD Monitor - 1440x900 (WXGA+),
Envision H716A4 17 in. LCD Monitor
19'':
19'' Princeton VL1919 DVI LCD Monitor (Black)
19'' panoramic
V7 Series D19W12 19" Widescreen LCD Monitor
Sep 10, 2008 | ViewSonic E70f 17" CRT Monitor
Won't power on. No lights at all.
You have done Most of it...
You have tried to swap the Power cords that work fine with the Other Monitors and If that do not work there are 2 things externally that could be bad.
1-> The Power Button.
2-> The Port where you would Plug in the Power cable.
so Check if the Power button is stuck or Broken, or Loose out of control.
besides that If with one of the good power cord connected when you connect an external Head phone and you receive some Kind of sound out of it.,
It could be because of the Display settings.
you can try the monitor self test.
By having the Monitor Unpluged from the computer but still connected to the power.
you would see a message that shows, that the VGA cable is not pluged in if that shows your Monitor is fine otherwise it is BAD.
Jul 17, 2008 | ViewSonic VX924 19" LCD Monitor
The monitor gree light blinks
It may be your power cord to the monitor. Did you use the same cord when you attached the monitor to a different computer?
May 17, 2008 | ViewSonic VX924 19" LCD Monitor
ViewSonic VX924 19" LCD Monitor Logo
57 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
