Question about C. Crane CCRadio-EP AM/FM Radio w/ Lighted Needle & Dial
CCRadio-EP Tuner Knob Spinning and not moving tuner dial
Made in China - State there are NO USER REPAIRABLE PARTS. What size of screwdriver do I need to open case?
  • C. Crane Master
  • 7,993 Answers
Get a set of screw drivers of different dimensions and shapes and try each one until you find the right one.
Posted on Jan 09, 2014
Tuner knob no longer moves needle to tune in stations on radio
Since most radio's have digital displays these days, to have a pointer move along a dial implies it's either old or a retro model. In any case all that will have happened is that the chord or something in the drive that moves the pointer will have either snapped off or broken. It shouldn't be too hard to repair, though it can be a bit tricky to set it up right.
Dec 24, 2013 | Audio Players & Recorders
Haier tv the female plug that connects to the cable coaxial broke off. What can I do?
The tuner should be replaced. The Female plug is the part of the tuner. But, an experienced service technician can replace it. It is not a user repairable work.
Sep 09, 2013 | Televison & Video
Tuning knob turns but does not move tuner bar nor change station. all else works fine.
The linkage between the tuning knob and tuner bar (string?) has failed. Disassembly will be required to repair.
May 19, 2013 | Eton FR300 AM/FM/Weather/TV Radio
Tuning-suddenly stopped. knob turns, yet does not move station indicator bar and i cannot change station. all else works fine. options?
TAKE THE KNOB FO AND SEE IF IT WILL TURN BUY HAND IF SO JUST PUT A BIT OF PAPER ROUND IT AND PUSH THE KNOB BACK ON AND IT SHUOD GO
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Tuner not working
You mean a digital tuner or an analog tuner (the old ones with the cursor)?
Post for reply.
Stelios.
Feb 23, 2010 | Proton R5A Clock Radio
Kitchenaid ksm50pob no stir speed all other speeds seem ok
I don't know if it will work for you but move the speed lever from front to back a few times as fast as you can. This will polish the contacts. This is like the old fashioned TV tuners. People used to turn them slowly and then complain when they needed serviced every 6 months. Spinning the tuner knob kept the tuners working flawlessly for years.
Jan 08, 2009 | KitchenAid KSM50PR Professional Series...
Marantz model PM 400 yes its about 30years old. Problem volume does not respond to knob changes. Very cracklie sound. Do I need to replace the amplifier or is their a service agent on the sunshine coast...
It can be fixed by yourself. All you need is some tuner lubricant (available at Radioshack or similar store, or if nowhere can be found you can even try WD40). Pull the knob off so you can see the shaft. Spray the tuner lube onto the shaft (let gravity be your assistant). Replace knob and work it back and forth until it moves more easily than before. Test it and you should be golden.
Aug 05, 2008 | Marantz Audio Players & Recorders
I have 1 1959 zenith stereo and the tuner needs repaired, i have it apart. and there is a broken string on the end of a small metal spring, how do i put it on the tuner. i can turn the tuner wheel by hand,...
1......Use new dial cord, old dial cord becomes brittle and glazed over the years.
2....the tuning knob shaft should have 2 or 3 turns of the dial cord wrapped around it.
3....the tuning knob shaft should be clean.
4...if there are any small pulleys that the dial cord rides on for smooth operation, they should be clean and free turning.
The biggest things ( as you might have guessed ) are that everything that has the dial cord running over it should be clean and free to turn if necessary.
The little spring is there to keep tension on the cord, otherwise it would loosen once it streches with age.
If you need dial cord, I believe Sony still has some. You may need to contact the Sony parts distributor for your country, but I firmly believe that it is still available.
Good luck......Rob
Mar 04, 2008 | Audio Players & Recorders
C. Crane CCRadio-EP AM/FM Radio w/ Lighted Needle & Dial Logo
109 people viewed this question
Top C. Crane Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a C. Crane Audio Player and Recorder Expert? Answer questions, earn points and help others
