Question about Kodak Easyshare C182 12MP Digital Camera
Unlock cameras unprotecting pictures - Kodak Easyshare C182 12MP Digital Camera
Unlock pictures on Olympus X-835 camera
You may download a copy of the manual here. The instructions for protecting/unprotecting pictures is on page 27.
Feb 12, 2013 | Cameras
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
How do i unprotect my sd card because i cant upload pictures
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 04, 2012 | Sanyo VPCCA102 Dual Camera Xacti
Sdcard protect: when I plugg on camera an error message appears on screen " SDcard is protected " I tried to change SDcard and the same message related to sdcard appears . I can not unprotect...
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 25, 2011 | Intova CP8 Digital Camera
How do unprotect card how do i delete pictures
Remove the memory card from the camera, look along the one edge for a tiny switch, slide it towards the contacts to unlock the card, the switch that is in the furthest position from the contacts is in the lock position to prevent deletion of the photographs. Now! if the switch is already in the unlock position slide it back and forth to reset, if this fails replace the card.
Mar 26, 2011 | Digital Concepts Digital Camera
How do you unprotect pictures to delete
While viewing the particular locked photo, press the Menu button and select Lock/Unlock to toggle. Your camera's menu might also call it Protect/Unprotect. Hope this helps!
Mar 02, 2011 | Kodak EasyShare V1073 Digital Camera
The camera says that my Memory card is protected. How do I unprotect my pictures? Also how do I reset switch on memory card? Thanks
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If you had protected any pictures on the card, then while viewing that picture press the Menu button. Use up/down to select Unprotect.
Oct 13, 2010 | Kodak Easyshare C182 12MP Digital Camera
My Kodak Pictures have a lock, how do I unlock them on my computer?
Press review button to display the picture that is save., Now if the picture already display on the screen press menu button., Now under menu settings look for a icon of a padlock or the word unprotect so you can unlock the picture.
Nov 13, 2009 | Kodak EasyShare V1073 Digital Camera
How to unprotect the memory card
If I understand correctly what your asking what is the brand and size of the memory card. If I were to take a stab at it right now I would assume there is a lock/unlock switch on the card. Have you had this problem with the card before?
Good luck,
Lee
Jun 13, 2008 | Polaroid I533P Digital Camera
Unlock card
If the card is locked, you could the steps below:
- Turn off camera
- Remove memory card
- Take a look on the switch of the memory card itself
* If it's at the TOP = card is UNLOCKED
* If it's at the BOTTOM = card is LOCKED
- So, you just have to make sure that the switch is at the top
for the memory card to be UNLOCKED
After doing that, you just have to put back the memory card to your camera and turn on the camera. Try to check if this works.
Nov 10, 2007 | Pentax Optio 550 Digital Camera
Kodak Easyshare C182 12MP Digital Camera Logo
20 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
