Question about Kodak Easyshare C182 12MP Digital Camera
Removing lock symbol on picture kodakeasyshareC182
I have GE E1480 W Digital Cam. How to remove the write protect?
take card out of camera on the side there's a small switch which is locked if it's moved to the locked symbol, just move to the unlocked symbol.
http://www.youtube.com/watch?v=58pdnjskvyw&feature=related
Mar 09, 2012 | Cameras
Number pad does not work
  1. Find Alt code.
    Numeric Alt codes for symbols are listed in Alt codes list. Check for Alt code of symbol you want to input.
  2. Enable Num Lk.
    You may need to simultaneously press ["FN" and "Scr Lk"] keys. That's the combination for "Num Lock" on some laptops. Look at the picture - the "Num Lk"/"Scr Lk" button is highlighted there.
  3. Hold down "Alt" key.
    Some laptops require you to hold both "Alt" and "FN" keys.
  4. Input Alt code of symbol on Keypad.
    Do this while holding "Alt" button pressed. Type Alt code on your laptop's numeric keypad. It's highlighted on the picture.
  5. Release all the keys.
    After you release all the keys alt symbol should be entered. If all this stuff didn't work - check if you have really enabled the "Num Lock" first. Remember that green indicator should shine near the lock symbol on your laptop's keyboard. If that wasn't the case - try simultaneously holding "FN" and "Alt" keys instead of just "Alt". That just might work.
Feb 15, 2012 | Toshiba Satellite P105-S9722 Notebook
My Fujitsu touchpad is crossed showing it to be locked. How to unlock?
hi,
you can unlock or lock the keypad of your notepad by pressing the "fn" key and F7 key simultaneously. In some versions this feature is changed to "fn + F6" keys. please check the symbol on the keys from (F4-F7), where you can find the symbol of "hand on pad". press fn and that particular key simultaneously to unlock your touchpad! i have shown the picture of another laptop. please observe the F7 key in that picture given below. you can see the symbol i specified. hope this is helpful. Please rate my solution as helpful.ecafc84.jpg
Mar 21, 2010 | Fujitsu Siemens AMILO Pro V1000 Notebook
Lock Symbol on Base tv/dvd combo
I fixed the locked problem on the tv/dvd combo....
on the remote control, press down the DISPLAY button
for ten seconds, this will make the lock symbol disappear.
on my remote control this button is next to the 0 button.
good luck.....
Jun 03, 2009 | Avenger Toys
My vivitar 3695 digital camera is showing a lock symbol.
the memory card is locked remove it slide the switch on the left of the card to the top all fixed simples
Apr 06, 2009 | Vivitar ViviCam 3695 Digital Camera
Picture lock
Protected pictures cannot be erased using [ERASE],
[SEL. IMAGE] or [ALL ERASE], but they are all erased by
formatting.
• Go to Playback mode in the camera. Select the picture to be unlocked with the left or right arrow buttons, and to remove the protection select OFF with the up or down arrow button.
Dec 19, 2008 | Olympus FE-220 Digital Camera
Picture has a sideways "key" on it and won't erase. I have an Olympus FE-210, how do I get rid of the "key" and am then able to erase the picture?
On page 22 of your user manual it talks about protecting images. Looks like you go to playback menu use the arrow keys to select the locked image - then press up or down arrow to remove the key symbol fromt he image by selecting ON or OFF.
Nov 22, 2008 | Olympus Cameras
Hand held electronics
If the card was edited via a computer the xD card becomes locked for protection purposes. Put the card in the recorder and format the recorder the lock will be gone. The device will show up as a removeable disk but gets moody if the memory is altered in any way by the computer.
Apr 15, 2008 | Olympus DS-2300 Digital Voice Recorder
When I go to take a picture i can't get the flash to work and i get a lock symbol in the
your memory card is most likely locked, take it out and find a small button on the side, see if it is in the lock position, switch the position and try the camera to see if this fixed the problem
Jan 22, 2008 | Vivitar ViviCam 5100 Digital Camera
Kodak Easyshare C182 12MP Digital Camera Logo
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
