Question about HP Pavilion Computers & Internet
My HP Pavillion G6 laptop screen goes black if not tilted in two certain positions
My screen only shows if I tilt it at a 90 degree angle or if I open it all the way (about 140 degrees) otherwise the screen goes black. What goes wrong and how can I fix it?
    Top Expert:
  • HP Master
  • 24,419 Answers
Sounds like the cable feeding the inverter is either faulty or has a bad connection. You will need to take the laptop to bits. See utube video.
http://www.youtube.com/watch?v=M7CEtfJtu_Y
Hope that helps.
Posted on Dec 30, 2013
4 Suggested Answers
SOURCE: LCD screen has black and red colrs + a green vertical line
Reset the video card, and if that doesn't work it sounds like the card is dying. How old is the card?
Posted on Apr 03, 2009
  • 10406 Answers
SOURCE: when the screen is tilt back more than 90 degrees shuts off
Look closely at the area where the computer "folds";
there's a small sensor that should trigger when you *CLOSE* the lid -- perhaps, something is triggering that sensor (a small pin) when you're exceeding 90 degrees, putting the computer to "sleep".
Posted on Apr 05, 2010
  • 256 Answers
SOURCE: my acer aspire 7730z's screen gets all fuzzy and
try to hook an external monitor. if it will still have same problem then you should replace video card. if not, then its the LCD screen that should need replacing.
Posted on Apr 06, 2010
My Asus eee pc netbook screen will turn pink or black when screen is tilted at certain angles. How can I fix this problem as it is becoming more and more bothersome.
Try to open it carefully, and all you have to do is to stick some strong adhesive tape to the LCD cable that is connected to the LCD screen. Try the difference with power on pc and try to push smoothley with finger.
Sep 01, 2013 | ASUS Computers & Internet
10 inch lest tilt Unisaw will not tilt to complete verticle --only goes to 88.5.
There is an adjustment under the table top. It usually is a bolt with a lock nut that allows you to adjust the table to a predetermined angle every time. You can adjust the amount that the table will go by unlocking the lock nut and then turning the bolt the correct direction allowing the table to come to a full 90 degrees. Once you have the table a 90 degrees lock the bolt down with the lock nut. This will aloow you to change the tilt of the table to something other than 90 degrees and then come back to the 90 degrees by turning the adjusting wheel until it bottoms out against the locked doen adjusting bolt.
Mar 17, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
My old laptop screen goes black when it is tilted back. Why does this happen
if it works at certain angles and not others, it's probably a damaged connection to the screen. Whether it be caused by physical damage or manufacture flaw.
If it doesn't work at all, it could still be damaged connection or the video card could be bad. I'd suggest attempting to connect it to an external monitor to see if it will display to the monitor.
Feb 22, 2011 | Apple Computers & Internet
Compaq Presario CQ50 notebook screen goes fuzzy when opened to a certain angle (about 90 degrees). Wires being pinched at the hinges? If so how do I go about repairing this?
it sounds like you've damaged the cable that goes from your graphincs card to your screen or when you move it to 90degrees it's disconnecting. it's usually caused by someone opening the laptop and not putting the cable back in the right place, or loose screws in your hinges or a broke hinge. there are plently of videos showing how to open it up. follow one of them and make sure your wires are sitting in the right place, you don't have loose screws and the hinges aren't broken.
Jan 13, 2011 | HP Compaq Presario CQ50-110US Laptop
My acer aspire 7730z's screen gets all fuzzy and lines come accross it when i tilt my screen farther than a 90 degree angle
Apr 06, 2010 | Computers & Internet
When the screen is tilt back more than 90 degrees shuts off
Apr 05, 2010 | Compaq CQ60-215DX Notebook
How do you fix a 90 degree tilted monitor sreen??
Ctrl-Alt-arrow key....try all arrows, one of them will correct it.
Dec 03, 2009 | Northgate 17" LCD Tilt Screen Innovations...
Apr 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
