Question about Proview PA-32JK1A 32 in. LCD Television
My preview rx series has no sound can you help
I want to add a tv antenna, not cable. The tv is fussy and no sound
  • Proview Master
  • 10,291 Answers
What makes you think an antenna will solve the no sound problem? Make sure your audio set correctly in the setup menu
Posted on Jan 06, 2014
How to hook up the TV
To use the TV as a Monitor: Use an HDMI cable from the Monitor Out on the 6006 to an HDMI Input on the TV. You need to go into the setup menu and set the HDMI sound to go to the amp and not the TV.
If you are tuning TV stations with an antenna and the TV tuner: First connect the TV as above so you can watch your other sources, like Blu-ray players. Then add an Optical Digital Audio cable from the output on the TV to an optical input on the TV. When watching antenna TV, select the input on the 6006 that the optical cable is connected to. You may have to play with settings in the TV and the 6006 to get this to work! You should be able to listen to 5.1 sound while watching tv over the antenna.
Mar 08, 2015 | Marantz SR6006
Tv wont tne in to ch9 why iam getting all the other channels
If you are using an antenna to receive broadcast TV you may have to rescan to add channel 9 back into the TV's channel list. If this does not work, it may be seasonal or a weak signal from your channel 9 broadcaster. I use a signal booster on my antenna (purchased at Radio Shack..)
Dec 10, 2014 | Samsung Pn64d8000 64-inch 1080p 600hz 3d...
Have a JVC RX-9010V receiver and get no sound on FM , tv, etc.
no my antenna is a good one i tried with mp player too?? Is this a way to reset it to factory?
Nov 14, 2013 | JVC RX-9010V Receiver
I want to hook a amplified antenna to my sherwood receiver what kind of cable or wire should i use?
You can use standard TV cable (RG-59/U) or for a long run the white RG-6/U which has lower signal loss
Feb 18, 2013 | Sherwood RX-4105 2-CHANNEL...
Which end is the receiving end of a house tv areial
peter_321
One end of the coax cable is connected to your antenna. The other end connects to a coax port on the back of the receiver labeled "TV/Antenna Cable In". All DISH Network receivers have this port on the back except our "K" series receivers. These receivers require a module to plug into the back of the receiver. Connect the antenna cable to this port, "TV/Antenna Cable In", if the receiver has the port available. I hope this helps.
Ray Calo
DISH Network
Mar 05, 2011 | Televison & Video
How do I connect my RCA standard definition television to surround sound if it doesn't have an audio output. I purcahased a colby surround sound system with DVD. I can't get the system to operate with my...
To connect your sorround sound system to your TV that doesn't have audio and video inputs, you have to use an RF modulator, this devices converts your audio and video signals into a channel 3 or 4 VHF channels which you can tune at your TV connecting a coaxial cable, to change from DVD player to antenna without disconenecting cables, you can add an antenna switch device (2 inputs 1 output), this devices should be available at any elecronic parts store.
Feb 11, 2011 | RCA Televison & Video
Can we record with our sanyo drw 500 and a digital tv? If so, how do we do this?
If cable/SAT box, hook-up that box video/sound output to DVD video/sound input. If no cable/SAT box, hook-up cable from wall into antenna/cable in on DVD and tune DVD to channel wished, and hook-up DVD TV antenna out to TV antenna in. If DVD has no antenna/cable in, TV must have video/sound output. Hook to DVD video/sound input. Hope this helps.
Apr 18, 2010 | Sanyo DRW-500 DVD Recorder
Red RX/TX and red ANT light on my CB
Well,first hand ,some cobra radio,s have red some have green RX/TX lights, but are you modulating? Some green lights turn red. What is your standing Wave on the antenna,s? You need to check it and the output of the radio. To do this you need a watt or field strenth meter. Can get one at Radio Shack. Your standing Wave is ok as long as it is below a 2. That has to be done on the antenna. ..hope this helps...
Mar 11, 2010 | Cobra 29 LTD CB Radio
Yamaha RX V 657 - No Sound Output, and No input detection
Bad DSP chip. The only other possibility is if you have the "Direct" on. On the front of the receiver it's a small button. Also make sure your "Speaker Select" A/B is "on" You will see it on the display, it's also a small button on the front of the receiver. If all this is correct and you still have no audio, it's a bad DSP chip. Not worth repair, it's 400-500 repair. Not very common in a Yamaha RX-V series, but I have seen it. I'm a Yamaha Dealer. If you need further help, post a comment and I will be glad to help you further.
Aug 23, 2009 | Yamaha RX-V663 Receiver
Proview PA-32JK1A 32 in. LCD Television Logo
32 people viewed this question
Top Proview Televison & Video Experts
Steven Wander
Steven Wander
Tony
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
