Question about Danby Dishwashers
Danby dishwasher DDW497W spray arm not rotating
  • 641 Answers
SOURCE: Dishwasher Repair
It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Check if motor spins. In case it spins, the problem is with the pump ,in case it doesn't spin it could be a motor problem or a motor and pump problem. Good luck
Posted on Sep 10, 2007
SOURCE: Danby dishwasher E3 error
Same issue here so I just got off the phone with Danby. They said the E3 means the water is not hot enough when it goes into the machine. Now I dont know your guys situation but I let the water run hot until I cant touch it anymore, then I turn on the machine and plug it in. So it sounds like the heating mechanism is not working properly and does not heat the water to the appropriate temp to continue with the cycle. I will say that their support was really friendly and she informed me that since it was purchased less than a year ago it would be covered under the warranty. She gave me the number of a local repair shop. Lets just hope they dont tell me nothing is wrong with it because my water temp is fine. I will let ya guys know. Here is the number for Danby that I called. General office: 419-425-5052. Good Luck!
Posted on Feb 13, 2009
SOURCE: danby DDW396W-2
I have had a similar problem numerous times, a couple of which required manoeuvreing it into a place I could work on it, and a laborious removal of the covers. Each time, up until this current incident, the solution that worked, at least temporarily, was quite simple. The recurrent problem was at least consistent: every 6-8 months I would find that the pump would work but the spray arm was not moving. The solutions always seemed to be something different: once all I needed to do was to prime the pump, other times it seemed like calcium and lime build-up was clogging up the parts so a little C.L.R. got me on my way.
This most current incident was more baffling, as my standard solutions did not work. However, I think I finally got to the root of the problem.
Look inside the dish compartment, to the right, near the top. There are two little nubby holes. Their function is to allow air to enter/exit either the spray arm pump tubing or the water filling tubing. Remove the one zillion screws from the cover to access the innards. Pull off the tubing and unscrew the washer (it will be tight due to the sealant on it). Upon inspection, I found that the air hole for the spray arm pump was clogged with food residue. A tiny screwdriver will clear things out nicely - you should be able to see through it. If you clear it out a little but, but still can't see through it, then I presume you're just going to have the same problem back again.
It is important that this be clear so that the water can displace the air while filling is occurring and allow for good suction. Actually, it looked like a manufacturing flaw - there was still some residual plastic from the original molding on the inside, and food was getting caught on it.
Good luck.
Posted on May 26, 2009
  • 110 Answers
SOURCE: Hobart SR24H dishwasher will not spray, arm does not rotate
ck. flow press. of water , when fill solenoid opens press. should be @20 p.s.i because this is a time fill machine. this is important .not static press. flow press. also ck the screened washers in the fill hose to see if they are plugged .let me know what you find so i can futher assist. dont forget to vote tks
Posted on Jan 11, 2010
SOURCE: Bosch SKT 20 table top
Bosch SKT 20 επιτραπ?­ζιο νερ?? πλυντ?®ριο πι?¬των σταμ?¬τησε ζεστα?¯νεται, το βραχ?¯ονα ψεκασμο? ?­χει σταματ?®σει να περιστρ?­φεται και ψεκασμ??
Posted on May 23, 2010
My danby countertop dishwasher ddw497w turns on, drains the water in the tub, refills and right before it usually fires up. click and nothing. just sits there with no fault code. any ideas before i sm
Hey Derrick,
According to the manual:
http://www.danby.com/cms/documents/pdfs/en/DDW497W_EFSOM.pdf
The most likely cause is the appliance not being leveled properly. Apart from that, I have found no useful information.
If you have a smart phone, try using one of the various, 'Surface Level' apps which will allow you to set your phone on the top of the appliance and then adjust the level until the bubble is centered in the crosshairs.
Hope this helps.
Oct 03, 2014 | Danby DDW497W 22 in. Countertop Dishwasher
Why is my danby countertop dishwasher is leaking?
I would check hoses to make sure they are not kinked.... mine also loosened after I pushed it back and had to re-tighten. HTH
Jul 08, 2014 | Danby DDW497W 22 in. Countertop Dishwasher
Danby dishwasher faucet adapter
Yes, I have a new portable dishwasher and no adapter, not sure what size to get. model DDW1899WP-1
Jun 25, 2014 | Danby DDW497W 22 in. Countertop Dishwasher
The upper spray nozel no longer spins. There is water going in but for some reason it no longer turns leaving the uper tray of dishes dirty.
Check that the arm outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it.
Feb 05, 2011 | Danby DDW2406 Stainless Steel Built-in...
The sprayer arm moves readily but does not rotate when in operation mode
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 05, 2011 | Danby DDW497W 22 in. Countertop Dishwasher
Plexi glass on the inside of danby dishwasher is broken
Try calling the number below - we managed to get parts for our portable dishwasher (after a considerable wait). Dan by Products Inc. 1-800-263-2629 Ext. 212 1-419-425-8627 Fax: 1-419-425-1244
Feb 04, 2009 | Danby DDW497W 22 in. Countertop Dishwasher
Dishwashers Logo
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Andrew Taylor
Andrew Taylor
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
