Question about Whirlpool 25.2 cu. ft. Side-by-Side Refrigerator ED25PQXF
13 yr old Whirlpool side by side fridge temp. contol problem
Works if manually operated
  • Whirlpool Master
  • 4,654 Answers
Is your model the ED25PQXF ? Can you explain what you need to do manually to cause it to work? The thermostat? If thermostat is the answer the thermostat will need replaced. By straight wiring the 2 wires it turns refrigerator on. Let me know, Sea Breeze
Posted on May 20, 2009
Auto defrost seems to not be working because the drip tray is dry is it supposed to be like this or wet most of the time freezer is cold but not freezing and fridge isnt cold i have temp gaugers in both...
either un plug the fridge and let it defrost manually, or empty and flush out drain line with a hose or hot water. when it goes into the defrost mode, water should drip into the pan..
Apr 03, 2012 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Whirlpool Refridgerator Model # ET1FTKXKQ00 My Question: I can not seem to locate the hose that would take the moisture from the freezer/fridge to the evaporation tray at the bottom. My fridge is...
Hey i think they freze free lol and thers no tubes they are connected by chanels/ tunels blockes at the back fron freezer down. Reg temp yr nobe controler could b gone or temp module. So thats why it wont help lol check if the temp changes after yr turning it, so atleast u can iluminate that.. if it is working. Than i would sugest next checking yr front doors rubers and magnets on them all the way and both doors.. as wen it gets old it could b having gaps so there 4 it will not close the dore properly and u wont even know or notice and if thats the case. Thats why it running inside, as it not fully and all aront germeticky closed .. hooe that helps you . G/luck ??.. Tony
Apr 19, 2017 | Whirlpool Refrigerators
8 yr old maytag msd2758drw side by side isn't freezing
If the clicking noise is comming from the rear of the frig it could be your compressor trying to start. The motor would be the fan in the freezer running. That part would be normal.
If it is the compressor it could be replaced but if it were me I would buy a new frig.
Dec 29, 2009 | Refrigerators
Regulating Temps on Whirlpool Side by Side
well i think you know what this is!!!!
you moved it and it got upset about it?
but some freezers need to be dead upright
or,,,its the darn thermostat's there playing you up like mad if you cant control them there on there way out
best bet is have new ones fitted or just dump it all together,,after all think of how much that floor is worth? and how much ice cream do you need????
ps,,,i use a hammer drill to get my ice cream out the tub?? have you ever tryed "fried ice cream" its realy
"""""yucky"""""??? (sorry im mad you see)
Oct 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a 3 yr old side-by-side. The freezer is freezing ice cream solid even though it's turned all the way down. Food in the bottom two drawers on the refigerator side are freezing. Water has dripped...
Hi, this problem is going to be with the running thermostat. (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
6 yr old whirlpool fridge/freezer side by side - no cooling
If the compressor is not running at all and not cooling or freezing it is most likely that the control module is u/s or that the compressor is u/s. If the compressor is running it ios most likely that the control module and / or the thermostat is u/s, or that the unit needs regassing. Call a service engineer.
Aug 16, 2009 | Refrigerators
Our whirlpool 6 yr old refrig / freezer is not working correctly
Use a vacuum and clean under your fridge. A dryer cleaning brush will help make the job go much faster. Use a good light so you can get all the lint out. Give it 12 hours to level out. hope this is helpfull.. Saw
Aug 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My 3 yr old whirlpool fridge has been constantly running for the last few days. The temps in the fridge and freezer portions are running high and the sides of the fridge are warm to the touch. What they...
" The refrigerator never cycles offThe thermostat cycles the refrigerator on and off. The refrigerator normally runs as long as the temperature inside the refrigerator is higher than the set temperature. If the temperature inside the refrigerator is cold enough and the thermostat still does not cycle off, the thermostat may be defective. If so, you need to replace it, because it cannot be repaired. If the thermostat is not defective, you may have a problem with the sealed (refrigerant) system, in which case you should contact a qualified appliance repair technician.
From repairclinic"
Aug 29, 2008 | Refrigerators
Fridge freezer samsung model no sr-s2028cvw
fridge side should only be around 36 to 40 degrees freezer side around 0 to10 below
Apr 13, 2008 | Refrigerators
Refrigerators Logo
178 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
