Question about Pride Rally 3 Wheel Scooter
Charging schematic for pride scooter
I have a charger with a xlr plug, would like to know how to wire it to charge the batteries
  • Pride Master
  • 9,783 Answers
Red + goes to pin 1, black - goes to pin 2 and jumps to pin 3
Posted on Sep 03, 2017
SOURCE: pride victory Scooter battery charged won't run
Its probably too late to give my opinion, but here goes anyway.
I had a similar problem with my mothers scooter and it turned out to be a faulty connection on the wires leading to the motor. I simply pulled the plastic connection apart, cleaned and lubricated the contacts, refitted the connection and all was well.
Posted on May 13, 2009
  • 103 Answers
SOURCE: pride sonic scooter won't turn on. the battery is
How do you know that the motor is functional? Have you load tested the batteries. If the batteries are bad usually they will still take a surface charge and appear to be fully charged.
Posted on Jul 23, 2009
gewiz
  • 1263 Answers
SOURCE: Pride Legend scooter won't hold charge
check the wiring from the batteries as a wire could have come loose.
Regards
GeWiz
Posted on Oct 01, 2009
mcdevito75
  • 1970 Answers
SOURCE: batteries won't fully charge
mcdevito75 here, Sounds like the chargeing system has gone bad. Contact Pride online or phone.
Posted on Jun 29, 2010
  • 63 Answers
SOURCE: Pride Sundancer. Batteries will not charge. both
batterys may be to low for charger to pick them back up.Sounds like new batterys to me .dobble check that charger just in case by volt testing the neg and positive wires on one battery ,When its hooked up .then do the other to see if power is getting where its suppose to be. Your checking for volt changed .Battery charger checks out good replace batterys that should do it.
Hope I was of some help have a good day.
Posted on Jan 17, 2011
My mobilty scooter wont charge altough it has new battery
Pride scooters often have fuses that are not shown in the manual. These may be located under the central floor mat hatch.
The charger may be faulty? It happens.
If not that, I recently purchased a faulty XLR plugged charger cable. The man who was selling them hadn't got a clue! Everything was cross-wired! That fried my floor fuse.
Jun 11, 2014 | Pride Health & Beauty
Why when charging battery seems to drain instead
The 3rd wore of the charger plug tells the controller to shut off all power to the scooter while the charger is on. Check the plug for a broken wire
May 17, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
Why wont my celebrity x take a charge brand new batteries brand new charger
Is the charging circuit fuse blown? There are two hidden under the floor mat and hatch. Pride say that they don't exist, but there they are and one of mine mine was blown by a faulty XLR lead
Apr 25, 2014 | Pride Celebrity Xl 4 Wheel Scooter
How do i know if my battery is getting charged the lights on my invacare charger arent coming on
hi, if the lights aren't coming on, that's a no, check the the mains lead as these are standard to those used on computers and other items found in the home.
Regards
Robin.
Apr 06, 2013 | Invacare Invacre Battery Charger...
I have a Pride legend three wheeler- I replace the battery charger because it would not charge the batteries. I pluged the new charger into the control module it will charge the batteries. Batteries are...
if I understanding this correctly , you cannot use the scooter why it is being charged, there is a inhibit pin that stops the scooter from being used,
All scooters are designed this way.
Regards
Dec 14, 2012 | Pride New Mobility Legend 4 Wheel Scooter
Go-go battery won't charge
PLEASE NOTE: The Low Voltage Protection feature on this battery charger will not allow the charger to activate unless it is connected to a battery pack that has a minimum voltage of 16 volts. Battery packs with voltages below that level of charge cannot be recovered or recharged. This is a safety feature to prevent overheating in the event of a faulty battery. This battery charger will not output any voltage to the XLR connector until connected to a battery pack meeting this minimum voltage requirement.
Dec 27, 2011 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Battery charger indicating that batteries are fully charged, but battery meter on the scooter shows no power at all. also the lights, indicaters etc arent working, im presuming that is resulting from the...
With a Pride Scooter the charger will turn green if its fully charged and if there is a bad connection in the wiring with the batteries. If you plug in the charger and the light comes on green right away then there is a problem with the wiring or connections. Take a voltmeter and read the voltage at each battery. Fully charged they should be 13-15 volts each. If they are less than 12 volts then they are not charged and the charger is not working correctly. If the batteries are really low like less than 8 volts each then the scooter might not come on at all. If you find that the batteries have at least 12 volts or more then there is a wiring problem from the rear of the scooter to the front tiller. Pride has a habit of developing problems in the harness running from the rear to the tiller. My suggestion is to contact your provider (where you got the scooter) and have them troubleshoot the scooter. If the scooter is less than a year old then it should be under warranty and your provider will have to fix it under warranty. Sorry I don't have a quick fix for you but scooters are notoriously bad to troubleshoot and repair, especially long distance. Hope this helps you
Mar 14, 2011 | Pride New Mobility Victory XL 4 Wheel...
I have a pride cleberity x...when i plug in the batt. Charger..will not charge...checked all fuze's
Not always the batteries, the chargers are made like garbage, I've gone throught 3 on my power wheelchair. The wheelchair companies will charge you over $300 for new chargers, check EBAY and get one for under $76 they work great and have a warranty
May 10, 2010 | Pride New Mobility Legend 4 Wheel Scooter
Battery charger wont switch over to charge on a sonic scooter
The Sonic has an off board charger. IF the scooter is not charging, you may need to replace it. If you a technically inclined, you can measure the voltage out of the charger, it should be more than 28 V. You may need to contact Pride for more help.
Nov 21, 2008 | Sonic 3 Wheel Scooter
Pride Rally 3 Wheel Scooter  Logo
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
