ASUS A8N-E motherboard's all PCI slots are dead
Dear sirs my ASUS A8N-E motherboard's all PCI slots are not functioned, not work, dead. please help me how to fix this problem. tahnk you. best regards than swe thanswe3@gmail.com
  • mr Overland May 11, 2010
    Don't Spam use we are helping you
    remove your Email address please
    an follow rules
    Novelist:
  • 118 Answers
Often what has been known to happen in these cases is ESD which damages the PCI ports on the computer. In some cases, the ESD will only damage those places where it was introduced, but many times, the ESD will circulate throughout the inside of the computer, damaging some things and leaving other things alone.
ESD is Electro Static Discharge. You know, when you rub your feet on a carpet and then touch a doorknob? Same thing. The significant difference is, however, that the amount of spark needed to damage your computer needs to be multiplied by 30 before it is strong enough for you to feel it on your fingertip.
Odds are, your motherboard will only be fixed by replacing it.
Good luck. Wish I had better news.
tony
Posted on May 19, 2009
PCI Slot 4 (PCI bus 5, device 9, function 0) driver
The PCI slots are cover by the Chipset driver. Go to Asus.com and download the latest driver and install it.
May 29, 2011 | ASUS A8N-SLI Premium Motherboard
Is the ASUS A8N-VM PCI Express 2.0 compliant?
not that I know. It may support newer pci-express graphic cards, but surely they won't run at full-power with pci express 1.0 lower specs. if you're not satisfied with your motherboard, you should buying a new one that supports pci-express 2.0
Feb 06, 2010 | ASUS A8N-VM Motherboard
Some usb slots not working
Replace it with an USB expansion card and get it installed in the motherboard PCI slots.
Oct 28, 2009 | ASUS A8N-E Motherboard
Asus a8n sli premium
From the Asus support site.
If you installed total 4GB memory, the system will detect less than 4GB of total memory because of address space allocation for other critical functions, such as:
- System BIOS (including motherboard, add-on cards, etc..)
- Motherboards resources
- Memory mapped I/O
- configuration for AGP/PCI-Ex/PCI
- Other memory allocations for PCI devices
Different onboard devices and different add-on cards (devices) will result of different total memory size.
e.g. more PCI cards installed will require more memory resources, resulting of less memory free for other uses.
On a SLI system, since PCI-Ex graphic cards will occupy around 256MB, another 256MB will be occupied after you install a 2nd PCI-Ex graphic card. Hence, 2.75GB memory left only if two SLI cards installed on A8N-SLI Premium while 3.0GB memory left with one graphic card without other add-on devices.
This limitation applies to most chipsets & Microsoft Windows 32-bit version operating systems.
If you install Windows 32-bit version operating system, we recommend that you install less than 3GB of total memory. If more than 3GB memory is required for your system, then below two conditions must be met: 1. The memory controller which supports memory swap functionality is used. Chipsets later than Intel 975X, 955X, Nvidia NF4 SLI Intel Edition, Nvidia NF4 SLI X16, and AMD K8 CPU architecture support memory swap function. 2. Windows 64-bit OS which can address more than 4GB memory.
Jan 06, 2009 | ASUS A8N-SLI Deluxe Motherboard
P4p800-vm pci slot is not recognising the add on card ( TV tuner)
There is no PCI-E slot on this motherboard. It has an AGP 8x slot and 3 PCI slots, but no PCI-E. Therefore, even if you could manage to get the PCI-E card physically into the slot it will never work.
Here is a link to the manual - http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4p800-vm/e1338_p4p800-vm.pdf
Dec 30, 2008 | ASUS PCI Express Graphic Card
Type of ram
ASUS A8N-SLI Premium Specifications
CPU: Socket 939 for AMD Athlon 64FX / Athlon 64 /Sempron / Athlon 64 X2
Chipset: NVIDIA nForce4 SLI
Front Side Bus: 2000/1600 MT/s
Memory: 4 x DIMM, max. 4GB, DDR 400/333/266, ECC, non-ECC, un-buffered memory, Dual Channel Architecture.
Expansion Slots:
2 x PCI-E x16
- SLI mode: x8, x8
- Default (single VGA): x16, x1
1 * PCI-E x 1/ 1*PCI-E x 4(x2 mode)
3 x PCI
Storage/RAID: nForce4: 4 x SATA 3Gb/s
NVRAID: RAID0, RAID1, RAID0+1 and JOBD span cross SATA and PATA
2 x UltraDMA 133/100
Silicon Image 3114R RAID controller
4x SATA with RAID0, 1, 10, 5
Audio: Realtek ALC850, 8-ch High-Definition Audio CODEC
LAN: nForce4 built-in Gbit MAC with external Marvell PHY MARVELL PCI Gbit LAN controller
or see this site:
http://www.ngohq.com/home.php?page=articles&go=read&arc_id=34
Oct 30, 2008 | ASUS A8N-SLI Premium Motherboard
Version of PCI Express
my motherboard has a PCI-E 1.0 it's an Asus Commando graphics is 9600GT which is PCI-E 2.0 and it runs fine till now no prob about that mate PCI-E 1.0 and 2.0 is backwards compatible so it should work fine make sure your graphics card is working @ x16 coz when I first plug my graphics it runs only @ x2 then I reset the bios and re-seat the graphics now fully functional x16 of PCI-E lanes.
May 15, 2008 | ASUS A8N-VM CSM (00610839133826)...
PCI card not been detected via Windows.
the sound card is installed into the ISA slot not the PCI slot.
clear the cmos for a minute, set it normal again.
install the sound card to the ISA slot carefully - i mean a working sound card and couple the system unit and boot, surely you will have your sound card working.
UZOWUANYA
e-mail:uzowuanya@yahoo.ca
Feb 12, 2008 | ASUS A8N-SLI Deluxe Motherboard
Installing NVidia 8500GT XFX 256MB graphics to A8N-VM Motherboard
The chances are that you have an old motherboard which is not compatable with the new graphic card. Or you may be running windows 98 and are downloading the driver for xp or visa versa. The probable solution, will be to sell the new card on ebay and buy the best old card you can off ebay. Or just make do with the card you already had in your computer. If you are determined to have a better graphics card. A motherboard upgrade with better graphic card may be the best answer or buy a better spec pc second hand if you don't have much money. You'll probably waiste a lot of time trying to get the new card to work and it probably never will.
Jan 28, 2008 | ASUS A8N-VM Motherboard
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
