Question about JVC Audio Players & Recorders
CA-EX70R The receiver will not always change from FM to AM and vice versa, and the volume control is very erratic Regards Alastair Will
I cleaned the PCB with the volume control and checked the volume control but as I could not get any specifications  info on the control reassembled it and it works. I suspect I have only bought time  Alastair
Posted on May 19, 2009
When I depress the foot pedal on my 2140 nothing happens, yet I can manually sew a few stitches and my light is on?
..... what do you mean by 'manually sew a few stitches'?
If you test your foot control on another machine or vice versa, you can verify if it is the control. Has it sewn a little erratically lately? Could be the contact tracer pins in the foot control.
Oct 19, 2013 | Husqvarna Designer I
The screen is always black and white' no colour what so ever
Check the color system settings. If PAL is selected while the receiver is receiving NTSC and vice versa, there will be no color to picture. Set color system setting to 'Auto".
Jun 07, 2012 | Televison & Video
Yamaha RX-V1000 volume control erratic, remote doesn't work. All was well then the volume control knob became erratic (volume would change erratically as knob was turned in either direction, remain...
sounds like you need to take it in to have it looked at. no simple fix unless you are an appliance technician. hard to walk a beginner through. i suggest calling an stereo repair guy.
Fix Ya
FixYa Support
Please accept solution and rate 4 thumbs up! Thanks for your feedback!
Aug 21, 2011 | Yamaha RX-V1000 Receiver
My fisher amplifier ca-854 switches speaker channels form left to right and vice a versa. Any ideas on what could be causing this? Thanks!
well could be a few things. It could be the input source. so if you are playing a cassette, try cd or tuner and see if the same happens.
Could be dust in switches so wiggle and push the function selector controls and see if it gets any better or worse.
Could be bad speaker terminations - Try removing speaker cables, re-stripping and re connecting at both amp and speaker end.
Possible dust in the volume pottentiometer so with the power off, move volume up and down franticallly (but gently) from min to max for about 15-30 seconds) to clear out any loose particles.
If these small things should not work, please reply back with anything you've noticed from these tests and I will try and aid you some more
Jan 16, 2011 | Audio Players & Recorders
My xm plays extremely loud thru my car stereo.no matter what i set the volume at.it is either off when volume is set to zero or loud at any other setting.changing the output level on the xm receiver does...
Are you playing it directly thru your FM antenna connection, or using the RCA jacks? You have to set the FM modulator level. It is also possible that you have a new FM radio with a type of ALC that will raise the lever regardless, but your regular car radio volume control should work. do not wire this directly to a power amp, as you won't have the control that you need. Good luck, let me know more.
Apr 01, 2010 | Terk XM Commander Satellite Radio Receiver
Have isuues with volume control knob. It does not seem to adust correctly when going up sometimes turns down and vice versa. Scared the you know what out of our baby sitter. (We just curently use the...
Turn off the power. Remove the knob by pulling straight out on it. Spray liberally around the dowel and into openings in the plastic shroud with what is called "tuner cleaner" and replace the knob, turn it fully around a few times and allow to dry for about 15 minutes. Power it back up and try!
Jan 13, 2010 | Pioneer VSX-D608 Receiver
Denon AVR 1609 volume Zone 2
Logitech recommends that zone 2 is controlled using device mode on your Harmony remote. Controlling zone 1 and zone 2 simultaneously within activities may lead to the AV Receiver turning on and off unexpectedly as you switch between activities. For example, if you try to turn on zone 2 within an activity, it may turn on or off zone 1 and vice versa. Controlling zone 2 in device mode will prevent this from happening.
Aug 07, 2009 | Denon AVR588 Receiver
I have the Onkyo 706 with remote RC-717M. My remote just suddenly started to malfunction. The volume up is turning it down and vice versa. The power button to shut the receiver off is doing the function...
Have you tried resetting the remote? According to the manual (page 101), press and hold the RECEIVER button, press the AUDIO button, wait approx 3 sec. until RECEIVER highlights and finally press RECEIVER again. Of course if you've programmed a remote control code for your PVR in the RC-717M, you'll have to do it again.
Oct 18, 2008 | Onkyo Audio Players & Recorders
177 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
