Question about Soundstream PCA2000D Car Amp
Amp is smoking
The amp just started smoking
    Novelist:
  • 111 Answers
Send it to a GOOD tech or buy another
Posted on Jan 06, 2014
  • Andy Efstathiou Jan 06, 2014
    Also check to make sure all your connections are correct and that there are no shorts or inadaquate power distribution. (all causes for amps smoking)
My 1985 vette starts up cold good and no smoke but after warm up it don't want to crank when it does it has black gray smoke for a min what's wrong
not starting when it gets warm could be a starter problem, the amp draw is probably to high for the battery to supply enough power to start. starter draw should be around 150-200 amps. the black gray smoke is too much fuel that isn`t being burnt. if the starter draw is too high then there isn`t enough voltage for the ignition system to fire the plugs properly causing the smoke.
Aug 25, 2014 | 1985 Chevrolet Corvette
My 95 Integra smoke at the start white smoke what is that five minutes later it goes away
White Smoke --usually a sign of a failed head gasket
or other issue, allowing coolant into the cylinder & a major
repair
White Smoke only on start up after sitting (Not Lasting 5 Min)
is raw fuel (gasoline) from leaking injectors, leaking fuel into
the cylinders
Injectors can fail,wear,leak or be dirty & NO you can not clean them
Forget the Genie in a Bottle The injectors have to come out & be
mailed away for Ultra-Sonic Cleaning
That condition - the raw fuel- will over heat your exhaust converter
& ruin it as well as many other problems-lack of fuel control the
main one.
Jul 19, 2014 | 1995 Acura Integra Coupe
Soundstream pca2000d started smoking on me what do you think is wrong
well. if it doesn't function after smoking, then it needs to go to a GOOD technician. ( if one is available to you) if not then send it to soundstream. if this was not a good amp , I would advise getting rid of an amp that smoked, however soundstream is a good brand and deserves another chance. (always depending on the cost of repairs)
hope this helps.
.......andy.......
Dec 29, 2013 | Soundstream PCA2000D Car Amp
1998 gmc sierra 1500 5.0L
white smoke is a blown head gasket [white smoke burning anitfreeze]
Jun 24, 2013 | Cars & Trucks
I have JL300/4. My front speakers starting popping and sounding bad, so I replaced them. When I turned the reciever on to listen to them, the right speaker started smoking. Could my amp be bad? The rear...
Well its not a good sign when your equipt starts smoking . Chances are that at least one channel of your amp is bad .But your real quest is to find out why the amp smoked in the first place. Chances are you have a shorted wire or speaker or both. Best way to check is is to check the wire with an ohm meter, if it reads less than 4 ohms you have a short .Next disconnect the speaker and check the wires to ground and measure the speaker. You need to do this before you repair or replace your amp or you will have it happen again. Noow it is possible the amp did fail on its own but the chances are it had help.
Jul 30, 2010 | Jl Audio 300/4 Car Audio Amplifier
Turned on radio amp started smoking on the side where the bass boost goes still got power on amp and voltage meter still works but bass boost does not work thats where the smoke came from
i would get it looked at, you never know. when ever your stuff starts to smoke it might work for a lil while but sooner or later my opoin it will be just junk.
Apr 23, 2010 | Alphasonik PMA800DA Car Audio Amplifier
Smoked
contact eric @ Capital Audio & Electronics Repair in Tallahassee,FL 850-339-1130,we repair all brands & models
Mar 08, 2010 | Lanzar 2H 1000W MOSFET AMP Car Audio...
I recently had an accident with my 1995 nissan quest & had to replace the radiator & fan & transmission coolant radiator . Now , when I start it up & drive it a little ways , it starts to...
BEST THING TO DO IS PRESSURE TEST THE RAD. THIS WILL PRODUCE THE LEAK YOU HAVE IF SMOKE IS COMING FROM ENGINE IF SMOKE IS COMING FROM TAIL PIPE. GO TO PARTS STORE BUY A HEAD TEST KIT VERY EASY TO DO. LETS MAKE SURE NO HEAD DAMAGE WAS DONE AT TIME OF ACCIDENT.
Feb 12, 2010 | 1995 Nissan Quest
MTX 1501 D
If the terminals were smoking, it's probably due to loose screws in the terminal block or wire that's too small.
Did the amp work properly after the terminal blocks smoked?
Apr 29, 2008 | MTX Thunder 1501D Car Audio Amplifier
Soundstream PCA2000D Car Amp Logo
Top Soundstream Car Audio & Video Experts
Matthew Spark
Matthew Spark
Electro Med Services...
Are you a Soundstream Car Audio and Video Expert? Answer questions, earn points and help others
