Question about Stanton C314 Tabletop CD and Mp3 Player
Stanton player laser motor not moving - Stanton C314 Tabletop CD and Mp3 Player
When i turn the cd player on its reading like a cd is in it but it not
reverse the pin of mains supply and try ,and open close cd tray switch,clean cd tray with smooth brush
Sep 03, 2012 | Stanton C314 Tabletop CD and Mp3 Player
STANTON C324 NO DISK \r\nTHIS FIX THE PROBLEM AND COST YOU $25 NO LIKE IN STANTON $320 ;) http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=290406538324&ssPageName=STRK:MEWNX:IT
You need a new laser or laser mechanism. You can order one online no problem. The part number is: Sony KSS 213Q. make sure there is a Q at the end of it because sony makes a lot of different laser types and the one inside the Stanton C.324 is the Q. Yes the C.324 has Sony guts. You might also want to look into ordering a RF Signal Processor Chip. the part number is: CXA 2581N. Once again make sure the part number ends with a N. This part you might have a little more trouble finding online but it is possible. The laser mechanism you can find on Ebay for about 20$ to 30$ and if you order it from stanton magnetics it will run you about 200$. The signal processor I bought the other day from a Sony parts Dealer in my home town for 20$. Im having an Electronics Repair place do it for very cheap. If you send your stanton c.324 to stanton magnetics you will end up paying more than the turntable is worth brand new unless you have valid warranty still on it.
Hope I could help you with the problem. Cheers.
Jun 15, 2010 | Stanton C314 Tabletop CD and Mp3 Player
Not reading cds
There may be dust inside the unit on the laser. Try shoting some compressed air in the CD drive area to clean out. Also, ensure that the CD surface is clean, and try a different factory made audio CD. Sometimes CD players have problems reading "burned" CD's.
Mar 17, 2010 | Stanton C314 Tabletop CD and Mp3 Player
Some cd's wont load
Currently I have one that won't load or unload.
That problem is a slipping drive belt. It is a small square profile belt near the front left of the machine. There is not enough tension and the motor spins its pulley inside the belt. The mechanism it drives is the load and eject function.
Feb 23, 2010 | Stanton C314 Tabletop CD and Mp3 Player
A year ago I bought a Stanton C.324 and now I have a big problem: The player suddenly stops and repeats short segments on currently track. I realized that the ANTI SHOCK AN BUFFER INICATOR is empty and The...
Dust and dirt could cause this by getting in the gear rack that moves the read head.
Make sure no one has smoked cigarettes around this as that is devastating to the optics in the unit.
An internal cleaning is probably in order and there are very fragile elements within the unit. I would recommend taking it to a shop specializing in CD repairs unless you are really capable.
I assume you have verified that the power is good to the unit.
Feb 01, 2010 | Stanton C314 Tabletop CD and Mp3 Player
My staton cd play reads no disk
try using a cleaning disk, but ive found that those dont work that well, find the laser lens "near the motor that spins the cd" and use a micro fiber cloth, or eyeglasses cleaning cloth and gently wipe the lens in one direction, you can use rubbing alcohol on the cloth if you like, just blow on the lens to make sure its complely dry. if that does not work, then the laser may be burnt out.
Jan 14, 2010 | Stanton C314 Tabletop CD and Mp3 Player
My stanton c324 after i put a dics in it reads "no disc" what happend to it and how can i get it fixed?
Had same issue with mine, talking with retailer it seems to be a common problem. I am in New Zealand and have been waiting 2 months for parts to arrive. Something wrong with laser and servo. Good luck getting yours fixed.
Oct 28, 2009 | Stanton C314 Tabletop CD and Mp3 Player
NO Disc
The first step is to clean the lens of the player using a cotton swab and alcohol. If that failes to resolve the problem, it is likely that the optics are starting to fail and need to be replaced.
Please clean the lens and update this with the results.
Thanks,
Dan
Aug 11, 2009 | Stanton C314 Tabletop CD and Mp3 Player
No disc displayed more often sometimes all the time
It sounds like you are having a laser problem. Either the lens is dirty and out of calibration or the laser is getting ready to go completely. In any case it will have to be serviced. You can try cleaning the lens yourself if you are comfortable doing it. It is like doing it on a game console or a regular cd player.
May 09, 2009 | Stanton C314 Tabletop CD and Mp3 Player
Stanton C314 Tabletop CD and Mp3 Player Logo
21 people viewed this question
Top Stanton Music Experts
Michial Gueffroy
Oloyede Monsuru
sreenivask
sreenivask
Are you a Stanton Music Expert? Answer questions, earn points and help others
