Question about Frigidaire 24 in. FDB510LC Free-standing Dishwasher
Water will not drain out of bottom of dishwasher.It will go through the whole cycle but will not drain. This is a Frigidaire model no.FDB510LCS3 Serial no.is:noth70219331.Pump hose was disconnected and drained completely,dishwasher was put through another cycle and still ended up with water puddled in the bottom!! Could this dishwasher be called a lemon??? Does the pump need replacing?? I have noticed on your website that many others are having the same problem.To me it appears that it may be shoddy manufacturing processes.
  • Tracy Farrell
    Tracy Farrell May 11, 2010
    About your dishwasher. Is the drain hose hooked up to a garbage disposal? If it is, can you tell me when the disposal was installed?
    SG
    p.s. Yes... I'm serious. These are diagnostic questions and in order to help you, I need to know.
  • 864 Answers
Check the input to the drain hose to make sure it is not blocked by something like a cherry pit.  That could cause the water to not drain fully.
Posted on May 20, 2009
  • John Morganti May 20, 2009
    Check the inlet to the drain hose to make sure it is not blocked by something like a cherry pit.  That could cause the water to not drain fully.
Do I need a new drain pump?
Get a wet vacuum and hook it to the drain HOSE
May 29, 2015 | Frigidaire Professional Series 24"...
Frigidaire fdb510lcs3. Will continue to wash but will not shut off
You may have the same issue we do - but it's pointing to a bad thermostat, or maybe the wiring.
Try running your cycle with both the heat and power wash switches off. If it works that way, it's likely the thermostat which controls the heating element; if the wash water isn't hot enough to register 127 °F on the tub bottom, it won't let it advance. When it does get there, the thermo closes, restoring the timer power.
Sep 24, 2013 | Frigidaire Dishwashers
Dishwasher motor sounds like its struggeling to run. oR LIKE it's bogging down during washing cycles any and all cycles. there is water going into the washer but when washing it sounds like there is no...
Try pouring water from the front. The pump has got air traps inside. This will ease your problem.
Also check whether the spray arm turns freely without any obstacles.
Mar 30, 2010 | Frigidaire 24 in. FDB510LC Free-standing...
Arms not spinning on frigidaire dishwasher model number fdb510lcs3
Your problem could be one of the following:
* clogged spray arms
* water inlet issue (water pump, motor, etc.)
Feb 25, 2010 | Frigidaire Dishwashers
Hello, I have a Frigidaire Dishwasher, model FDB750RCC1. It will not fully drain. There is water in the bottom of the unit after the cycle is complete. As it is not full of water or leaking out of the...
On the drain hose at the connection to the dishwasher there is a one way check valve. If debris has gotten trapped water will drain back into the dishwasher at the end of cycle
Hope this helps.
Remove the connection and clear.
Jul 01, 2017 | Frigidaire 24 in. FDB750RCC Stainless...
New dishwasher won't pump out water Frigidaire Mod# FDB510LCS3
Check the drain hose and pump for damage.Here is a link that contains the internal diagrams for your model so that it might be easy for you to check through.Also its any part is damaged,you can order a new one from the same and fix it in its spot without the help of a technician.I would like to know it its showing some error codes.so please do post your comments.
click here for internal diagrams
Good luck.
Sunny
Apr 16, 2009 | Frigidaire Dishwashers
Dishwasher won't drain
There's usually a filter cup around the bottom of the lower arm, did you check it? Look for kinks in the drain hose, if not it's most likely due to a blocked/faulty drainage pump.
Dec 28, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
The dishwasher does not drain water
I had the same problem after a year of use. All the cycle sounded good except for the drain. I disconnected the drain hose with all turned off and only a small amount of water came out ( the inside pan was full ) I then stuck it to my mouth ( gross ) and nothing but back pressure. Another great heave and POW a wad of grease came out. In short by wife poured some fresh stock down the drain which backed into the drain pipe and cooled. Done.
Jul 21, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire dishwasher ultaquiet , model=FDB750RCC1
the first thing that your dishwasher does when you turn it on is drain when you turn it on you hear a motor running then it stops then it fills start the washer when it stops to start filling open the door should be no water in the unit if there is you have a drain problem and in fact are washing your dishes in dirty water can be several things that can cause drain problems a piece of food blocking the line at the sink where the drain goes in if its run to a disposer there is a knockout plug that should be removed just stick your finger in there to see if it was removed get you installation instructions and read the part about not removing the drain loop but just about all the time installers will lol if you cant find the instructions go to www.frigidaire.com under customer support can down load them there let me know what you find
Jan 17, 2008 | Dishwashers
Frigidaire 24 in. FDB510LC Free-standing Dishwasher Logo
1,165 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
