Intertherm feh 015ha
The furnace blows hot air but does not shut off. I have replaced the thermostat after having the problem none of the wires are touching each other. What could be the problem?
  • Heating & Co... Master
  • 9,742 Answers
Look at the "klixon" style heat actuated switches mounted on the fire box of the heater. One of them is not working.
Posted on Jan 05, 2014
Sea Breeze
  • 4654 Answers
SOURCE: troubleshooting intertherm feh-015ha (FROM FREEZING FAMILY)
Having changed the fuse and breaker tell me there is a major short in you furnace. 240 volts is a lot of amperage and a very delicate job to attempt to help you directly. I have found that any intertherm dealer near you will be happy to help solve your problem. Yes, the sequencers are possible reason but 50 amps at 240 volts is what concerns me. Did your transformer burn out also?
Let me know what you think and if you would like, I will locate the correct source of help. Thanks, JT
Posted on Feb 03, 2009
flatech
  • 111 Answers
SOURCE: I NEED A FILTER FOR MY 1991 HOBILE HOME FURNACE
Best things to do is find your Return grill in the home.
Get a measuring tape and measure the Hole size with the grill removed, Or filterback grill whatever the case.
Then simply go to a home retailer with the size, or in rare cases you may want to consider a Hogs hair washable filter that can be cut to size, to fit it perfectly.
Posted on Oct 24, 2009
icemelts
  • 246 Answers
SOURCE: My furnace will not turn
I would suspect your evaporative motor (located in the furnace) is shorted.
To prove it - just disconnect the electrical wires to the motor and turn the breaker back on.
Most likely the breaker will stay on - which will tell you for sure that the motor is shorted.
Note: it's possible that the capacitor on your motor is shorted - but I doubt it. i would bet on the motor. In any event - you have a 'direct short' which is causing your breaker to pop, and I would bet it's the motor.
If it isn't the motor you will just need to find the 'short' to keep the breaker from popping.
Posted on Aug 06, 2011
  • 127 Answers
SOURCE: Intertherm model# FEH-015HA It is no longer blowing heat
High limit safety device is probably tripped, it should reset automatically, also check other safety's for tripped condition, they look like small round device located in a variety locations through out the unit with two wires to each one, some have small push button resets located in the burner compartment area. If all the safety's are reset and check out OK the main control board may need replaced. One of the most common causes of high limit safety device trip is lack of air flow, Dirty filters, evaporator coils, malfunctioning blowers, closed supply air registers etc.
Note: High limit safety switches also go bad after being tripped to many times.
Posted on Dec 01, 2011
  • 12 Answers
SOURCE: I NEED A WIRING DIAGRAM FOR INTERTHERM FEH-015HA WITH ONLY 2 WIRES AVAILABLE FOR HEAT ONLY. THE WIRE ARE CONNECTED TO "W" AND "A" POST BUT THE FURNACE WILL NOT SHUT DOWN AT SET-POINT.
If it's only a two wire system, it should be on the R/RC and W. Fan should kick on automatically.
Not too familar with that unit
A is usally for a heat pump pick-up coil or heating element
Pay attention once you've rewired the t'stat. Make sure the blower goes on automatically. The most it should take is apx five min, even if house is really cold
Also, check the heater. It may have way more options for control. You will just have to run new t'stat wire to take advantage
Posted on Mar 06, 2013
I have a 1987 Intertherm FEH-015HA electric furnace. The issue I am having is that my blower will not shut of unless I pull the disconnect. My thermostat will operate the heating elements like normal,
You most likely have a bad fan limit / cycling switch. If you kill the power to the furnace see if you can trace the wires from the motor to where the connect to the switch. It looks like a round button with tabs sticking out of it for the wires to connect. Mark down where the wires were connected and take it to a HVAC business or furnace supply house. Be sure to have the model off the furnace with you so you can get the correct parts.
Nov 25, 2014 | Intertherm Heating & Cooling
Have 84 model feh-015ha heater comes on but motor wont start
should come on with first stage heat bad sequencer or motor.
Jan 30, 2014 | Intertherm E3EB010H Electric Furnac
Intertherm Feh-015HA
Sounds like a bad contactor in the circuit. They are usually power to close (on) and spring to open (off) so it should go off automatically. A tech can open unit find right relay and replace it or try contacting these folks with your serial number:
http://www.furnaceparts.com/Store/Category/Intertherm.aspx?page=4
Nov 13, 2013 | Heating & Cooling
either the heat strips, fusible links on elements or sequencers.
Sep 21, 2013 | Intertherm E3EB010H Electric Furnac
Mar 05, 2013 | Heating & Cooling
Nov 28, 2011 | Heating & Cooling
I have a intertherm electric furnace model #FEH=015HA=03 w/ an A coil for my AC. Date code 870902 . It burns out the transformer. It did it about a month ago and it was replaced by a certified electrician....
There is a short in the low voltage wiring somewhere...this type of thing can be very hard to track down and is probably a wire rubbed through somewhere...
Have the electrician install a 5 amp. automotive type fuse in the low voltage wiring right after the transformer to keep from burning up anymore transformers...I would do this even if you think you find the problem...
heatman101
Mar 23, 2011 | Heating & Cooling
I have a mobile home with Intertherm electric furnace model FEH-015HA. It will not stop running whenever it has power. We have to switch off the circuit breaker to stop it. The thermostat has been replaced...
You could possibly have a bad sequencer. Turn off the power and check the normally open connections with an ohmmeter. If they are not open then it is bad.
Dec 20, 2010 | Heating & Cooling
I NEED A FILTER FOR MY 1991 HOBILE HOME FURNACE IT IS A INTERTHERM MODEL FEH-015HA-04 NOROYNE SERIAL FEH 9105-00229
Oct 21, 2009 | Intertherm P3RA-048K Air Conditioner
Blower will not shut off on furnace. I have a Intertherm FEH-015HA Central Electric Furnace
If your blower will not shut off from the thermostat, you either have a bad thermostat or your red and green thermostat wires are exposed to each other.
Feb 20, 2009 | Heating & Cooling
Heating & Cooling Logo
165 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
