Question about Tomtom ONE GPS Receiver
Touch pad seem to be out of calibration - when you touch anywhere on the screen, it highlights about 1/2 inch above where you are pointing - very hard to enter addresses etc.
    Problem Solver:
  • 7 Answers
Not sure what tom tom you have but try this (found in a forum)
SAW THIS IN ANOTHER FORUM - RESOLUTION TO SCREEN CALIBRATION ISSUE
So I will give it a try to help sort out a friends TomTom.
Method valid for NavCore versions until 8.051.
A manual method to correct the calibration of the touchscreen input device of any all-in-one TomTom systems consists in creating a file called calib.txt (e.g., with notepad) and saving it in the main directory of the TomTom disk memory (e.g., the SD card; the same directory of the ttsystem file).
calib.txt should include one line with four numbers separated by a space: MaxX MinX MinY MaxY
Notice that the ‘x’ sequence (max, min) is inverted than the ‘y’ sequence (min, max). MaxX > MinX and MinY < MaxY.
For instance, the file can include:
928 118 107 912
Each TomTom device has its own most appropriate sequence.
In order to compile the file with default data, one method could be to perform a TomTom reset (or to eject the SD card), powering on the device and holding down the ON button for a few seconds until a unit status screen appears. The line named “Touchscreen calib. data:” will include four numbers that in sequence represent MinX MaxX MinY MaxY; these numbers can be used to fill the configuration line of calib.txt remembering to swap the first two ones. For example, if the unit status screen returns 118 928 107 912, calib.txt has to be saved with 928 118 107 912.
Tuning can then be done by adjusting these numbers until the touchscreen is calibrated. Distortions like screen rotation, trapezium and rhombus correction cannot be achieved with this method even if tuning these parameters can provide an acceptable touchscreen management even in presence of distortions; the best screen to tune the calibration is exploiting the soft keyboard of the NavCore application.
For instance, in my old TomTom GO Classic device I realized that, after activating the NavCore soft keyboard, when moving vertically (Y axis) the cursor appeared calibrated, while the horizontal movements (X axis) prevented to manage the left and right key columns (especially in the left bottom corner positions). So, I left the last two digits unaltered and, after some tests, I successfully used the following values: 805 200 107 912.
Method valid for NavCore versions post 8.051.
For NavCore versions 8.2x and 8.3x, use the same method as mentioned above, with these small differences:
the file should be named cal.txt (and not calib.txt) and should again be positioned in the main directory of the SD (or HD) drive of the TomTom system (e.g., the same directory where ttsystem can be found). Besides, the four numbers included in the file should have a different sequence than what previously described for versions until 8.51; cal.txt shall include the following sequence: MaxX MinX MaxY MinY (notice that also MaxY precedes MinY).
For instance, cal.txt could include the following four digits: 928 118 912 107
Again, these numbers are specific of each TomTom single unit.
E.g., my TomTom GO Classic correctly runs 840 245 912 107.
Posted on May 19, 2009
Htc prophet touch screen issue
for window phones
1. Press the "Home" key and press "Start." Use the directional pad to highlight "Settings," then press the center or "Enter" button.
2. Use the directional pad to select the System tab. Select "Screen," then press the center or "Enter" button. Select "Align Screen."
3. Using your smartphone's stylus, tap the crosshairs as they appear on your screen. Do this for as many as appear, until the calibration tool finishes. Your screen is now properly calibrated.
for Android phone
4. Press the "Home" button or capacitive area, then press "Menu." Tap "Settings."
5. Tap "Language and keyboard." Tap "Keyboard settings." Tap "Tutorial" and go through the steps that appear on your screen.
6. Once this is finished, turn your phone off and on again. Your keyboard has been adjusted, which activates a re-calibration of the capacitive touchscreen. (Capacitive screens are technically far more accurate that resistive, and so a full calibration tool is not included with Android phones.)
Aug 20, 2012 | imate JAMin Smartphone
Canon iR C3380 touch screen seem to have shifted, anyway i can re-calibrate the touch screen?
UP TO COPIER I CAN TOUCH 1 INCH ABOVE
AFTER THAT I CANT TOUCH FUNCTION TAB ON THAT
IT GOES ABOVE
Jul 27, 2012 | Canon Office Equipment & Supplies
Ricoh Aficio 3025 Copier LCD Touch Screen out of Allignment
It's not in service mode, but rather in the 'self diagnostic menu'. Access it as follows:
Press "clear modes", 1 9 9 3, "clear/stop" (5 times).
** Do not try any other adjustments in this mode...only touch screen
please rate me :)
Apr 10, 2009 | Ricoh Office Equipment & Supplies
Touch screen calibration
Touch screen not working for sony ericsson P990i Mobile phone
When I hit the center some part above gets highlighted and selected and the botton part where the taskmanager and battery icons are present does not respond to my taps ... what could be the problem,,, kindly help me solve the issue.
Praveen
Aug 24, 2007 | Sony Ericsson P990i Cellular Phone
Tomtom ONE GPS Receiver Logo
1,246 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Jon Piercy
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
