Pye air conditioner manual
My PYE ACP24I Air Conditionerhas stopped working
wagdom
  • 64 Answers
SOURCE: maytag performa pye/g2200,3200
when you say the drum wont spin even manually. Do you mean the drum is too stiff to turn by hand? If so the bearings may have seized up solid. If the drum is free to turn by hand, the pump may be blocked, or burned out & not allowing the water out. If so the circiut wont allow the machine to spin. If thats the case, unblock or replace the pump
Posted on Oct 21, 2007
yalmer
  • 549 Answers
SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Posted on Feb 25, 2008
  • 230 Answers
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Posted on Jun 30, 2008
SOURCE: Need PYE PY 90DG Manual-ours lost in a move
yes you can download one from the website www.funaicorp.com they have all the manuals of their products in pdf form.
hope this helps,
gmt
Posted on Jan 30, 2009
MARZX
  • 61 Answers
SOURCE: air conditioner, fuel gauge, and temp gauge all stopped working at the same time
Three possibilities;
All related to blown fuses,
1- Fuse blown in the engine compartment LH.
2- Fuse blown in the cabin forward LH below the dashboard (below your legs left hand).
3- Fuse blown in the harness (wire bundles) below the dashboard very easy to reach with your hands “just look underneath steering wheel ".
U said " The air conditioner blows, but the air is not cold.
" Yes only the fan working which might receiving power independent all from those other mentioned things.
If all fuses OK. Then look for broken wires.
Regards;
MAR
Posted on Jun 03, 2009
What is e3 when I turn my pye split system on
E3 on an some brands of air conditioners means faulty indoor coil thermistor, either mice have chewed through the cable or the thermistor itself is stuffed.
Good luck
Feb 13, 2015 | Heating & Cooling
Pye split system errors
it sounds like a wiring fault between your evaporater and condensing unit or your inside capillary sensor is damaged
Dec 09, 2013 | Heating & Cooling
Remote for Pye 4205T TV
Your GE remote may not have a code for your Pye TV. The solution may be to obtain another Pye remote
Nov 28, 2012 | GE JASRM24912 Remote Control
Where can I get a user manual for a PYE DVD PLAYER/RECORDER
Only suggestion is GOOGLE the model number with "manual" to see if can find one.
May 02, 2012 | Televison & Video
Have pye split system. ACP35. Error 1 comes up
E-1. Defective of room sensor. Replace it.If it works for few seconds and then shows this error.
Suppose, when you switch on, it doesn't work and shows error code 1- means blower motor mechanism locked. Replace bearings or motor.
Helpful?
Jan 04, 2011 | Heating & Cooling
hope this helps,
gmt
Jan 24, 2009 | Funai PY90VG DVD Player/VCR
Heating & Cooling Logo
93 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
