Question about Thule 2002 Dodge Dakota - Quad Cab, without factory rack - Xsporter Truck Rack
Brake lights not working club
2002 Dodge Dakota has all lights working except the brake lights. Replaced switch and and all fuses are good.
  • 3 Answers
Need to check the Intergrated Power Module (fuse box) and/or the FCM (body control module attached to the fuse box) They have a terrible design and are not weather-proofed from the underneath where the harnesses plug in and water corrodes the circuit board on the fuse box...
Posted on Feb 18, 2014
My 1994 dodge dakota blows brake light fuse, replaced sw and still blows fuse after 2-3 times I push on pedal
You'll have to disconnect the lights to track down the short. It could be one of the lamp sockets, or something in the wiring, or in the turn signal switch.
Mar 05, 2014 | 1994 Dodge Dakota Club Cab
1991 dodge dakota brake lights dont work
switch on the brake pedel may be faulty or out adjustment/place
Dec 02, 2012 | 1994 Dodge Dakota Club Cab
2002 dodge dakota all lights work and no brake light put new bulb in still no brake lights
check the fuse, it is usually located under the dashboard or between the door and the dashboard.
Oct 14, 2009 | 2002 Dodge Dakota Club Cab
O2 Dodge Dakota Brake lights wont work but bulbs r good.
If the bulbs are good I would suspect the Brake light switch.
Brake Light Switch: Testing and Inspection
The brake lamp switch can be tested with an ohmmeter. The ohmmeter is used to check continuity between the pin terminals.
Switch Circuit Identification
- Terminals 1 and 2: brake lamp circuit
- Terminals 3 and 4: RWAL/ABS module and Powertrain Control Module (PCM) circuit
- Terminals 5 and 6: speed control circuit
Switch Continuity Test
NOTE: Disconnect switch harness before testing switch continuity.
With switch plunger extended, attach test leads to pins 1 and 2. Replace switch if meter indicates no continuity.
With switch plunger retracted, attach test leads to pins 3 and 4. Replace switch if meter indicates no continuity.
With switch plunger retracted, attach test leads to pins 5 and 6. Replace switch if meter indicates no continuity.
Sep 11, 2009 | 2002 Dodge Dakota Club Cab
No brake lights
Crossed up live wires with ground on the trailer harness, check the truck fuses for the lights they might be blown.
Jul 08, 2009 | 2002 Dodge Dakota Club Cab
Brake lights don't work
Toggle the 4 way flasher switch on and off a few times and see if that corrects problem, if it doesn't replace the switch.
Apr 22, 2009 | 2001 Dodge Dakota
Dodge ram 1500 tail lights don't work
i had the same prob with my 2002 dodge ram and i was told that it was the fuse box which cost 700 to 800 bucks.Ifixed mine with a relay switch and about 6 feet of wire
. works like new
Jan 18, 2009 | 2002 Dodge Dakota Club Cab
2002 Dodge Dakota
well because the abs light indicates a problem with your anti-lock braking system you need to find out why it is on.... keep in mind one quick way you would disengage your cruise is with the brake pedal.
under the hood is a fuse panel (often located near the battery) ... see if there is a relay in the for your cruise... replace that.
Robert
Dec 17, 2008 | 2002 Dodge Dakota Club Cab
2002 Dodge Dakota, no brake lights. Where is the fuse or breaker???
Your prob could be the switch at the brake peddle. If not go to the wiring at the trailer hitch. Frankster016
Sep 19, 2008 | 2002 Dodge Dakota Club Cab
Thule 2002 Dodge Dakota - Quad Cab, without factory rack - Xsporter Truck Rack Logo
82 people viewed this question
Top Thule Boating Experts
Tom Chichester
L Pfaff
L Pfaff
John Mabry
John Mabry
Are you a Thule Boating Expert? Answer questions, earn points and help others
