Question about Kenmore Elite HE4 Electric Dryer
Dryer wont turn on
Im getting electric to my dryer as the light turns on when the door is open,you can hear the timer going the problem is it wont start. i checked the belt and its nice and tight no play in it at all i also tried holding in the button and still wont turn on. the model # is-110.62702100 and the SER#-ML110811 and the type is-DWSR-ELE-2406028-FM54 i hope this information will help you. Thank You, Judy
4 Suggested Answers
vickygomar
  • 460 Answers
SOURCE: Kenmore electric dryer Mod. 100.66662501, type
Assuming that the fuses you speak of are the external pair, and not the internal motor or timer resets:
Check the fuse holder for corrosion on the plates. Often the fuse is not properly seated because of this build-up and therefore has an intermittent connection. This will cause the fuse to either heat up, or overload; ultimately failing.
To remedy this, turn OFF the breaker, or main switch if necessary, and fix a wooden dowel with a piece of emery cloth (or sand paper) on the end. Remove any visible black corrosion from the contact plates.
Finish with a spray of WD40 to protect the plates and fuse end.
Replace the fuse, ensuring that it's tight, reinstate power and try again.
Was this  helpful?
Posted on May 13, 2009
  • 266 Answers
SOURCE: electric dryer model # 110.68422700
take the back off the heating element will be on the right side as you face the back of the dryer inside a metal container. The heating element is resistor wire. The other part that commonly goes bad is a thermal fuse it will be connected to the heating element but mounted on the back of the dryer near the bottom center right. The fuse should show continuity so should the heating element. Elements sometimes ck good but if you shake them the wire will seperate.
Posted on Aug 10, 2010
heatman101
  • 43501 Answers
SOURCE: Kenmore electric dryer DWJR-ELE-2406028-FM54 Model
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Aug 10, 2011
Electric clothes dryer wont turn on but I hear a faint buzzing sound
Hello:
the noise could be coming from the timer which will be going through the motions if the door switch is not working right( door open -no drying)
Jul 08, 2017 | Dryers
Dryer wont turn on. light is on when door is open. When you push on button you can hear a faint buzzing noise where timer is.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Jan 01, 2011 | Kenmore 600 7962 Dryer
Dryer Does Not Tumble When Pressing Start
Hi,First of all check your door switch, make sure it is operational.If the door switch checks good, the start switch could be faulty, in newer dryers the start switch is built into the timer in older dryers your start switch may be separate, if you have to push on the timer dial to start the dryer, its built into the timer.
Check any other safety's that may be stuck open.Double check anyway. If it wont do anything, I would say its the door switch or the start switch.
Thank you
May 10, 2010 | Frigidaire GLEQ2152ES Electric Dryer
I have an electric whirlpool with start switch not working
OPEN THE DOOR/PUSH THE START SWITCH ON DRYER/THEN PUSH THE DOOR SWITCH/HAVE A PERSON TURN THE DRUM/IF IT STARTS TO TURN (DRUM) OR STILL HUMS AND DRUM WILL NOT TURN YOU HAVE A BAD MOTOR/REPLACE MOTOR.
FREDDY
Feb 14, 2010 | Whirlpool LGB6300 Gas Dryer
The dryer wont turn itself off
Is the timer turning?
Actually, doesn't matter, the timer is the component that turns the dryer on and off. If the dryer won't turn off via the timer then the timer is bad!
(I'm assuming, opening the door turns the dryer off.)
Replace the timer to fix.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 18, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Wont start door shut tight can heat timer drum lite on when door open
If you can hear the motor running with door is closed and the dryer is turned on, the the belt that turns the drum is likely off the drum or broken.
If you cannot hear the anything when the door is closed and the dryer is turned on, then the door switch is likely defective.
The other more unlikely causes are either the Timer or Switch that starts the dryer is defective.
Aug 21, 2009 | Kenmore 400 6942 Dryer
Dryer wont start. starter switch is new and timer will run when the door is closed
HI. if the timer is running, and the wiring harness is in good condition, this will confirm motor failure. I would advise to test the operational value of the door switch as well but if the door switch is working, this will only lead to motor failure.
May 22, 2009 | Kenmore 73952 Gas Dryer
Dryer wont start
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208522243.pdf
if possible, with the door open, push the limit switch the door normally hits to let the drier know the door is shut. That switch may be bad.
Dec 27, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryer not turning on
most likely its the timer it has electrical contacts built on the timer that allow it to start its cycle if the timer has bad contacts it wont allow dryer to come on
Jan 21, 2008 | Dryers
Kenmore Elite HE4 Electric Dryer Logo
94 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
