Question about Refrigerators
GE Side by Side Model: GSH25VGRECC Refrig.
Water and ice part of refrig began to not dispense regularly and was an intermittent problem. Then shortly thereafter within a few days the LED temperature setting lights began to go out at times. Within a few more days the entire unit stopped working. The lights will come on when opening the unit doors, but it does not dispense water or ice and neither side of the unit cools or freezes. The unit is about 2 years old. When plugged in a clicking noise at regular intervals, say every few seconds is heard coming from a relay at the main control board located to the rear of the unit. Each time the unit clicks the fan (compressor) moves a tiny distance but will not turn as if it was operating. I suspect that maybe the main control board is bad due to the number of things effected including the cooling, freezer, lights and dispenser unit. Any help or direction would be most appreciated. I am in Hawaii on the Big Island and we have lots of humidity and such. The unit has been indoors at all times though.
Thanks and Aloha!
Russ Darling
Pahoa, Hi 96778
  • RussD Oct 18, 2007
    To: duxxyuk
    Thanks for the reply. The unit has been unplugged for about a week now and clear of ice entirely. When the unit is plugged back in the clicking noise, coming from a relay on the electronic board to the rear of the unit, will start a regular click which causes the compressor fan blade to turn a fraction of an inch with each click. The fan blade never starts up though.
    Thanks!
    Russ Darling
  • Anonymous Apr 17, 2008
    I have the exact same problem with my GE SXS. Have there been any solutions offered?
  • 41 Answers
I had luck with a board with a clicking relay by replacing capacitors C29 and C30, which had bulged tops. Bravo, fridge works!
Posted on Apr 21, 2009
  • Chris Goulet Apr 22, 2009
    The capacitors are too close to diode D20, which is on a heatsink that can get pretty hot, so it's best to mount the new capacitors with wire extentions to an available space on the control board.
Your board needs to be replaced, the clicking you hair are the relays. you can try with your fridge on, turn the dials to 0, wait a few seconds then turn them up again.
Posted on Aug 11, 2008
  • norwun Aug 11, 2008
    the clicking sounds are the relays off of your control board which needs replacing. in th emean time try turning your control dials to 0 with the fridge running wait a few seconds then turn them up again.
Russ -
I have exactly the same problems with my GE GSH25JSRF Fridge (fan clicks in back intermittently, no water or ice dispensing). Did you end up replacing the main board?
Posted on Mar 24, 2008
  • 46 Answers
The clicking sounds like your ice dispenser might simply be a frozen block. Have you tried clearing out the ice dispenser with an ice pick?
Posted on Oct 18, 2007
SOURCE:
GE frig not cooling, both refrig and freezer. started with ice/water dispenser not working.
WR55X10942 Main Control Board This sounds like motherboard failure. I am not sure what your model number is but that will be important should you have someone to help repair your refrigerator. These problems are common on the Artica Profile Models. I will be here to help you repair if you should choose, Thanks Sea Breeze
Apr 24, 2013 | GE Refrigerators
Ice maker stopped working. the water and ice dispense from the door, but it does not make any NEW ice...
The water tube to the icemaker inside the refrig is frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Jun 06, 2010 | GE Profile PSW26P Stainless Steel Side by...
Water dispenser doesn't work, side by side, model # GSS22JEPA BB
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Mar 04, 2010 | GE Refrigerators
GE Refig. water does't dispense
adjust tempt of fresh food side it may be to cold and freezing veg/ and water line .. **** ..
Jan 19, 2010 | GE GSH25KGMWW Side by Side Refrigerator
No water entering ice maker.
Replace the solenoid valve , the piece the wall water line connects to , on the refrig . With both ice maker AND valve replaced , that is the complete ice production new .
Jan 01, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Artica, pulsing lights
Your refrig display , has lost communication , with the main control board , located , behind the refrig , behind an 8 " X 10 " panel . The control board , is easily replaceable , with 7 or 8 plugs , attached to it . The part number , for your board , is WR55X10942 . It runs about $150.00 .
Dec 09, 2009 | GE Profile¿ Arctica® Energy...
GE GSS25SGRE side by side water dispenser...
The same thing happened to me. If you pull the refrigerator out and remove the large silver panel, you will see the water lines on the left. The line going to the ice maker was fine, but the line going to the water dispenser was split. You may have the same issue.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side water will not come out of door dispense
The water switch went bad or the water valve. Switch the two wires on the water valve on the back of the ref. Press water switch on door if water fills ice maker valve is bad,if not,door switch is bad.
Jan 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice/water dispenser not working but ice is being made
lighs in the refrig or frezzer not working either???id check your outlet and or circuit braker. at very least yout lights should be on!
Feb 24, 2008 | GE Profile PSS26NGS Side by Side...
Refrigerators Logo
588 people viewed this question
Top Refrigerators Experts
Sal De
Marvin
Marvin
