Question about Dewalt D28112 Heavy Duty 4 - 1/2" Small Angle Grinder
D28111 angle grinder stops all over a sudden. what are the possible causes
  • pastrust55 May 11, 2010
    have you checked the brushes in the motor? or perhaps some small piece of what you are grinding has shorted the armature inside the grinder? Or check the trigger switch to make sure the wires are securely clipped in.
    The alternative is the end of the cord is shorting out or the plug pins are loose. Try a new cord from the manufacturer.
  • 216 Answers
If its intermittent most likely cause, there is a break in the main power supply cable.  Do a continuity check.
Posted on May 20, 2009
Grinding problem
That is a good idea. Also one or both brushes brushes could be stuck in the holder. If stuck I would just replace the brushes so I could count on it working a long while.Give the brush holders a good cleaning if you decide to replace or not.
Aug 03, 2014 | Dewalt D28493N 9" 230mm Large Angle...
I have a dewalt dw818 angle grinder when i press the trigger it starts spinning but if i tilt the grinder a little it stops spinning done the brushes already help please
Check your power cord. Turn the grinder on, then pull and twist the power cord, especially by the boot coming out of the grinder. If there's a break in the line, it's possible for it to work in some positions but it will die if you change the orientation of the cord to the tool.
Jul 21, 2012 | Heavy Duty Dewalt Dw818 Heavyduty 412"...
How do I remove the cover of the black and decker angle grinder.It stopped working,I think a wire is loose inside,but i cannot get it open to see if I am right. Can anyone help? Thanks. Gerry
Hi Gerry,
The body of the grinder should be in two halves. Normally there are two or more screws holding the plastic parts together but these may be hidden behind plastic stoppers. See diagram:
http://servicenet.blackanddecker.com/Products/DetailDiagram?isId=true&productNumber=11651&selectedType=16337#
Remove the screws and it should be possible to split the case.
Hope this helps!
Apr 27, 2011 | Black & Decker 4 1/2" Small Angle Grinder
I own a metabo 9-125 quick but can't don't know how to place the blade
On the silver part on top of the grinder is a button , press this button and hold it down. now turn the blade until it stops moving, this locks the blade, keep holding the button down and turn grinder over ,and turn the nut counter clockwise, and remove it , take old blade off ,put on new one .it should go over the shaft and at the bottom on a "fit" Make sure it is on the "fit". replace the nut and tighten. If you dont get the nut tight enough it will loosen while in use and the disc you are cutting/grinding with will wobble and may even come off causing possible injury .
Jan 29, 2011 | Metabo ® 12 Amp 9000 RPM Model WE14150...
I have mac allister angle grinder the problem when switch on the geinder start and suddenly stop and showing over loaded
Hi ibychackoja, It is the problem of the carbon brass replace it with a new with the identical size of the old one. Feel free to ask whatever the results.
Regards; VOTIT
Dec 03, 2010 | Makita Angle Grinder
I need a clamp nut for a B&D angle grinder model #6247. Where can I purchase one??
The clamp nut for angle grinders have a standard thread.
It should be possible to get one at a large tool store. You may have to buy a new wrench for tightening the nut though.
Aug 30, 2010 | Black & Decker 4 1/2" Small Angle Grinder
Dewalt D28112 Heavy Duty 4 - 1/2"  Small Angle Grinder Logo
285 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
