Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
How to reset fuel pump - 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
  • Chevrolet Master
  • 1,051 Answers
As long as you have power to the fuel pump there is no way to reset it except to change it.
Posted on Nov 18, 2015
Where is the inertial fuel shutoff located on a 1999 Mercury villager van?
It is called the inertia switch or fuel pump cut-off switch
The fuel pump shut-off switch is
located in the driver's foot well,
behind the kick panel. The reset
button for the fuel pump shut-off
switch is accessible through an
opening in the kick panel.
Use the following procedure to reset the fuel pump shut-off switch.
1. Turn the ignition to the OFF position.
2. Check the fuel system for leaks.
3. If no fuel leak is apparent, reset the fuel pump shut-off switch by
pushing in on the reset button.
4. Turn the ignition to the RUN position. Pause for a few seconds and
return the key to the OFF position.
5. Make a further check for leaks in the fuel system.
Jun 26, 2017 | Mercury Cars & Trucks
Where is the fuel reset button? Or how do I do a reset?
There is no fuel reset button , Reset what ? What problem are you having ? Vehicle doesn't start ? Engine cranks but doesn't start an run ? Fuel pressure test the system , check fuel pump relay . Watch scanner Danner's video testing GM fuel pump electrical circuit ! GM Fuel Pump Relay Testing
Jan 10, 2016 | Chevrolet Blazer Cars & Trucks
How to reset fuel pump on 2005 bmw 3x
I cant thin of a good reason to perform a "fuel pump reset" if there were such a thing?
Understand, the fuel pump is simply a tiny motor in the fuel tank that pushes gasoline out for the engine to use. It has no memory, no settings, or adjustments (for the most part, some newer ones do regulate w a duty cycle, but the pump is still a simple motor).
If you are having problems with starting or acceleration and it may be fuel related, the best thing you can do is get it scanned and or tested mechanically by a technician with access to an enhanced BMW scantool.
As to the fuel pump reset, there really isnt such a thing...fuel pump;s always work with the kjey and engine rpm UNLESS something breaks, or the alarm/theft system disables fuel. Thjere are no fault codes that turn off the fuel pump on your vehicle, so no memory to erase to ruen it back on or change its operation.
Apr 13, 2015 | BMW Cars & Trucks
Fuel pump reset switch
Only Ford products use a reset or inertia switch for the fuel pump.
The pump should be getting power from the pump relay.
May 09, 2013 | Nissan Xterra Cars & Trucks
Where is fuel pump reset for 2002 toyota echo
There is no reset button for fuel pump.
Check the fuses, relays, wiring and fuel pump wires polarity.
Mar 06, 2013 | 2002 Toyota ECHO
2006 Ford Expedition blowing Fuel Pump Relay fuse
Try resetting fuel pump. I do believe the reset button is on the forward passengers side of vehicle. The button is behind the plastic shield. Reset once or twice. This hopefully will fix your problem. Look in your manual for exact placement of fuel pump reset button
Mar 25, 2012 | 2006 Ford Expedition XLT
OUR 1990 GEO STORM JUST QUIT RUNNINBG. WE HIT ON THE FUEL LINE UNDER THE CAR AND IT KICKED THE FUEL PUMP ON AND WAS ABLE TO DRIVE IT ABOUT 2 MILES BEFORE SHUTTING OFF. IT REVED VERY HIGH. IS THERE A RESET...
sorry no reset switch. Sometimes like you said you can tap on the fuel pump to engage it (I'd recommend a rubber mallet) but you need a new fuel pump asap.
Apr 23, 2011 | 1990 Geo Storm
Is there a fuel reset button for the fuel pump on my 1992 Nissan Maxima? If so where is located.
There is no fuel pump reset button on the 1992 Maxima. Check your fuel pump fuse under the dash. If it's not blown, check for current at the fuel pump connections. If you have current at the pump, then you probably have a bad fuel pump.
Sep 22, 2010 | 1992 Nissan Maxima
Where is the fuel pump reset button on a 96 grand am 2.4
GM CARS DON'T USE A FUEL PUMP RESET BUTTON, THEY HAVE AN OIL PRESSURE CONTROLLED FUEL PUMP CUTOFF SWITCH ON THE ENGINE, IF THE CAR HAS NO OIL PRESSURE AND THE KEY WAS ON THE FUEL PUMP SHUTS OFF.
Jul 06, 2009 | 1993 Pontiac Grand Am
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
35 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
