Question about Dell Computers & Internet
Copy of windows xp on to a usb flash drive - Dell Computers & Internet
johnychel
  • 796 Answers
SOURCE: my laptop
there is a software called as alcohol...it makes cd image on your hard disk....first create an image of your xp cd on your system and then try to copy the files to your pen or flash drive..
then connect to the laptop..
thankyou
Posted on Sep 01, 2008
cpenzes
  • 1102 Answers
SOURCE: Acer Aspire 5735z Install XP
okay you might want to write this down make sure you have your product key #
put winxp
into cd drive then restart press F7 during restart then choose option start with cd or cd/dvd whichever you have
then press enter follow instructions YOU DO NOT want to press F6 for third party or raid let system go past that
then when asked to setup on the chosen space CLICK TO DELETE partition ( or unpartion ) then enter will ask to confirm
once all confirmed your installation will start
let me know how it goes MAKE SURE YOU READ ALL THE INSTRUCTIONS THE SYSTEM WILL GIVE
Posted on Jan 26, 2009
  • 256 Answers
SOURCE: MB P21G V3.1 Cannot use USB port (with USB flash drive)
You, probably have what is quite a common problem. Your system cannot recognize the USB, because, either your USB requires a USB 2.0 input or vice versa. Most moedern MB's have either both kinds or they work with regular USB. It might take you some time, or if you the manual, it will take you no time to be up and running. Personally I like the PCCHIPS. They make a good product, they have the currency exchange on their side and here in the US, they provide us with a good and reliable product. Let me know how you make out. This is the way I get graded...
My name is Constantin
Posted on Jun 01, 2009
  • 11800 Answers
SOURCE: Does my Asus K8V-MX support USB boot as in can i
Yes it does, but it's not recommended to use it since the XP installer was designed to be launched from a cd. Just find a cd-rom unit, whatever its age - recover one from a junked pc.
Posted on Jul 01, 2010
  • 825 Answers
SOURCE: My DameElec 2GB is not working on my XP Computer
try installing the flash drive once through add new hardware wizard from control panel. it might fix the problem for you. also plug the device directly into the usb slot present in the backside of the computer.
Posted on Jul 17, 2010
Blue creen with blinking cursor
you can do a clean install from your usb. i use this setup for all my flash drive boots.
WinSetupFromUSB - Install Windows XP from USB Flash Drive
This guide will show you, how to use WinSetupFromUSB to create a bootable USB Flash Drive including all Windows source files, plus the following installation of Windows XP. Compare to the different USB_Multiboot versions, WinSetupFromUSB comes with a Graphical User Interface (GUI) and is in my opinion easier to use.
Here you can get the latest version of the program and you will also find many detailed informations about WinSetupFromUSB.
I've tested this guide with a 32-bit version of Windows XP and a 64-bit version of Windows Vista and it worked flawlessly.
Prerequisites:
All you need is:
a USB Flash Drive with at least 1GB of storage
the original Windows XP Setup CD
WinSetupFromUSB
If you use nLite to slim down your version of Windows XP, please keep the following in mind:
DO NOT remove "Manual Install and Upgrade"
under Operating System Options!
I also recommend to integrate Service Pack 3 into your Windows XP source files.
1. Preparations
Download and install WinSetupFromUSB. Default installation path is C:\WinSetupFromUSB.
Create a new folder with the name WINXPCD in the root directory of drive C:\ and copy all files from your Windows XP Setup CD into this folder. Depending on your version of Windows XP, the content of C:\WINXPCD should look approximately like this:
Content of WINXPCD
The following files will show you, which Service Pack is already integrated into your CD:
WIN51IC.SP1, Sevice Pack 1
WIN51IC.SP2, Sevice Pack 2
WIN51IC.SP3, Sevice Pack 3
2. Start WinSetupFromUSB
Connect the USB Flash Drive to your PC and start WinSetupFromUSB. It should show up under USB Disk Selection :
WinSetupFromUSB - main window
3. Select your Source Path
Click on Browse under Windows 2000/XP/2003 Source and navigate to the folder with your Windows XP Source Files. It should be C:\WINXPCD:
Browse to Folder
Click OK and C:\WINXPCD should show up under Windows 2000/XP/2003 Source :
WinSetupFromUSB - source path
4. Format USB Flash Drive
PeToUSB or HP Format Tool are used to format the USB Flash Drive. There is no need to download these programs seperately as they are already included in WinSetupFromUSB.
USB Flash Drives up to 2GB should be formatted with PeToUSB in FAT16, USB Flash Drives with 4GB or more with HP Format Tool in FAT32.
I will use PeToUSB to format my Kingston Data Traveler with 2GB.
In the main window of WinSetupFromUSB click PeToUSB under Format target using to start the program. The USB Flash Drive should show up under Destination Drive. Check USB Removable, Enable Disk Format and Quick Format. Uncheck Enable File Copy under File Copy Options :
PeToUSB
Click Start and answer the following two questions "Continue?" with Yes.
All existing volumes and data will be lost!
If everything goes well, the message "Operation Completed Successfully!" should appear. Click OK and close PeToUSB.
The process with HP Format Tool is similar.
5. Copy Windows XP Source Files
To start the process of copying the Windows XP source files to the USB Flash Drive, click GO in the main window of WinSetupFromUSB. Depending on the write speed of your USB Flash drive it may take a while to copy all files.
WinSetupFromUSB - file copy
At the end the following notice about the Windows installation process should be displayed:
WinSetupFromUSB - notice
Click OK and close WinSetupFromUSB with EXIT.
6. Windows Installation - Part 1
Connect the USB Flash Drive to your PC and turn on the computer. Press ESC at the boot screen and you will be able to select the USB Flash Drive as your boot device from the boot menu.
The ESC key is used by ASUS for the Eee PC series.
Other manufacturers may use other keys, e.g. F8 or F12.
After booting from USB Flash Drive, the following menu should be displayed:
Windows XP/2000/2003 Setup - First and Second parts
Press Enter or wait 10 seconds to get to the next menu:
First part of Windows XP Home Edition setup
Second part of XP Home Edition setup+Start Windows for first time
First part of Windows XP Home Edition setup is already selected. Press Enter or wait 10 seconds to start the Text mode part of setup. During this part you can create, delete and format partitions and finally the setup files are copied to your hard disk. At the end the system will restart automatically.
7. Windows Installation - Part 2
After restart, boot the PC again from your USB Flash Drive. The same menu should be displayed:
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to start the GUI mode part of setup. During this part you will be asked for your product key, timezone, usernames and other necessary informations. At the end the system will restart automatically.
8. Windows Installation - Part 3
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to Start Windows for the first time. The Windows installation process will be finished and finally the Windows Desktop will appear.
DO NOT disconnect the USB Flash Drive too early!
At next startup you can boot into Windows from your hard disk.
Notes:
After successsful installation, the following boot menu will always be displayed during startup:
Please select the operating system to start:
Microsoft Windows XP Home Edition
USB Repair NOT to Start Microsoft Windows XP Home Edition
If you don't plan to use the repair option and want to boot directly into windows, you have to do the following:
Open the file boot.ini in the root directory of drive C:\ with Notepad:
[Boot Loader]timeout=30
Default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[Operating Systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(1)partition(1)WINDOWS="USB Repair NOT to Start Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Delete the following line:
DO NOT delete the wrong line!
Your computer may not boot the next time!
Save changes to the file.
At next startup the boot menu will not be displayed.
If you want to keep the repair option, you can reduce the time to display the operating system options from 30 to 5 seconds:
[Boot Loader]
timeout=5
At next startup the boot menu will be displayed only 5 seconds.
gd luck
Mar 09, 2014 | Computers & Internet
Tip
How to Install Windows 7 from USB Flash Drive
what if you don’t have DVD-ROM and you are running Windows XP, you might have guessed in this case we can’t install windows 7. Since Windows 7 ISO size is around 2.24 GB so its obvious that you will need to burn windows 7 iso on DVD and another issue is you can’t start windows 7 installation by mounting ISO file on windows XP as Windows XP upgrade to windows 7 is not allowed. In such situation installing windows 7 from USB pen drive is feasible solution.
Here is small guide on how to install windows 7 from USB flash drive or USB pen Drive for Windows XP users.
How to Install Windows 7 from USB Flash Drive Requirement:
USB Pen Drive (Min 4 GB)
Windows 7 ISO (32 bit or 64 bit)
MBRwiz Download and Extract it on your hard drive (Diskpart utility for Windows XP doesn’t detect USB drive as Disk hence we need to use this free utility to make bootable USB drive).
1. Connect your USB Flash Drive to your computer Format USB drive
2. To Format USB Flash Drive Go to My Computer -> Right click on USB drive and select Format from context menu.
3. Now go to Start Menu->run->cmd (Open Command Prompt) and Type following command
convert i: /fs:ntfs (Where “I” is your USB drive latter)
4. Mount Windows 7 iso as drive (You can use Freeware MagicDisc download from here).
5. Type Start->run->cmd
Now dir to directory where you have extracted MBRWiz and run following commands
mbrwiz /list (note down disk number of your USB Pen drive)
mbrwiz /disk=X /active=X (X is Disk Number of your USB Drive)
exit
6. Now open another command window and type following command
J: (Drive letter of Windows 7 iso mounted with demon tool)
CD boot
bootsect /nt60 Y: (Y is drive latter of your USB drive )
7. Now copy all files from drive where you have mount Windows 7 iso
8. Now reboot your computer and press F9 to get your BIOS screen and select USB drive as your boot drive.
9. If every thing goes fine, Your Windows 7 Installation should start from your USB drive.
on Jan 10, 2010 | Computers & Internet
Tip
Acer One's and More "Making working Windows copy to USB Stick"
Directions for Making Usb OS for windows 98,me,xp,2000,2003
You will need to saerch for a little program called Komku-SP-usb so get going and also a working computer with an actual cd/dvd rom drive.So if you need go use your buddys computer.
After you found the program as stated abovce download it and follow the rest of these directions I have left. Curtosy of someone else of course.
1.Open and install Komku-SP-usb on a working computer other than your Acer One.
Make sure that the Usb Stick you may be using has at least 2GB.
2.Locate folder C:\Komku\PeToUSB\ and double click PeToUSB.exe
3.Select USB Removable,make sure enable disk format and enable disk format are all checked.
If you feel the need you may put something to name your usb in the drive label area.And uncheck
enable file copy if it is checked.
4.Click Start
5.Click Yes
6.Click Yes Again
7.After Operation complete you can exit out of that program.
8.Next open Ms Dos command promt.Click Start > Run > type cmd > click OK
9.On Command Prompt window, go to directory C:\Komku\bootsect\
how to do this?
first type this cd\ and press Enter
10.then type cd komku\bootsect and press Enter
11.on command prompt window, type bootsect /nt52 and whatever your drive letter is {Mine was H:}
12.press enter
13.now type this cd.. and press Enter
14.then type cd usb_prep8 and press Enter
15.type usb_prep8 again... and pres Enter
16.Press any key to continue and the usb_prep8 welcome screen will appear
17.now, insert your original Windows XP CD, or Windows XP with sata ahci driver to your CD/DVD ROM
and back to Command Prompt window
18.type 1 then press Enter and "Browse For Folder" window will appear, select your CD/DVD drive and click OK
19.the result... "XP Setup Source Path" changed to G:\ (yours may be different)
20.now for point 2, if letter T is currently assigned to a drive in your computer,
you must change it.... if not, leave it as it is
To change it type 2 and press Enter...
21.Enter Available Virtual DriveLetter"
for example you doesn't have drive S
so you type S and press Enter
back to usb_prep8 welcome screen...
now type 3 and press Enter...
22.Please give Target USB-Drive Letter e.g type U" Enter Target USB-Drive Letter:
because my Flash drive letter is H
23.so, type H and press Enter...
after back to usb_prep8 welcome screen...
now type 4 and press Enter to make new temporary image with XP LocalSource and copy it to USB Flash Drive
please wait a few seconds..
24.WARNING, ALL DATA ON NON-REMOVABLE DISK DRIVE T: WILL BE LOST! Proceed with Format (Y/N)?"
type Y and press Enter
please wait....
when format virtual disk complete, press any key to continue...
25.when you see "Making of LocalSource folder $WIN_NT$.~LS Ready"
26."Copy TempDrive Files to USB-Drive in about 15 minutes = Yes OR STOP = End Program = No"
Click Yes, and wait...
27.Would you like USB-stick to be preferred Boot Drive U: bla... bla..."
Click Yes
28."Would you like to unmount the Virtual Drive ?"
Click Yes, wait a few seconds, and press any key....
press any key again to close usb_prep8...
29.Now, insert your USB Flash Drive/Flash Disk/Thumb Drive to your notebook (e.g Acer Aspire One)
go to BIOS and make USB HDD (or USB ZIP in some other machine) as primary boot device....
30.then boot form your USB Flash Drive....
and select "TXT Mode Setup Windows XP, Never unplug USB-Drive Until After Logon"
31.After Hard Disk detected, delete all partition, create single partition...
and install Windows XP on that partition...
and wait...
32.once text mode setup is complete, computer will restart....
this time select "GUI Mode setup Windows XP, Continue Setup + Start XP"
33.Continue Windows XP setup.... and Done!
Windows XP Installed....
34.Remember, you can use this tutorial to install Windows XP on all other computers..
not just Aspire One and Asus EEE-PC....
on Jun 21, 2009 | Acer Aspire One AOA150-1570 Notebook PC
How to install windows xp in msi k8mm-v motherboard?
Hi dharmen_shah,
I see that you need to install Windows XP on you Dekstop with an MSI Motherboard k8mm-V.
I have another desktop using the same Motherboard, there are 3 options installing Windows XP on the machine.
  1. Using an IDE Optical Drive
  2. Using a SATA Optical Drive "not a common installation process on this motherboard" since you will need to install the SATA rivers first to be able to use your SATA ODD
  3. Using a USB Flash Drive
See steps below for each installation type.
*Using an IDE Optical Drive*
  • If you have your Windows XP CD insert it on the Disc Drive restart the system as soon as the system restarts keep on tapping F11 this will bring you to the Boot menu.
  • Once in the Boot Menu screen select your Optical Drive, it may say dvd/cd or ODD, select this and press enter. Note: windows may restart during the installation if it says press any key to boot to cd do not press anything anymore leave it will do everything on it's own unless prompted for any user information like a computer name date and time.
  • You will see on the screen Boot to cd: then it will show "press any key to boot to cd" press Enter or any key this will boot from your cd Windows XP.
  • Then you will see inspecting your hardware for configuration, once it boots to your Windows XP cd you will see a blue screen Loading up drivers and stuff for the installation of Windows XP.
  • Next will be the installation of Windows XP itself, just follow the prompt it is very easy to follow and it will give you all the details and what buttons to click on.
  • Note: Select Quick Format (NTFS) this will be faster reformatting your Hard Drive before installation.
*Using SATA Optical Disc Drive*
  • You will need a 1.4 floppy disc to be able to do this.
  • If you have a 1.4 Floppy Drive you will also need to download the SATA driver from the MSI website.
  • Let us disregard this option since I believe you do no have a 1.4 Floppy Disc Drive and no one uses that or has a 1.4 Floppy Drive anymore on their machines.
*Using a USB Flash Drive*
  • To be able to use a USB Flash Drive for the installation of Windows XP your USB Flash Drive should at least be 1GB or 2GB, 1GB will be enough since windows XP only uses at least 7++gb of disc space for the installer size.
  • Using you USB Flash Drive you will need to copy the whole contents of your Windows XP Cd into your USB Flash Drive, don't worry this will be bootable just make sure that you copy everything from the disc into the USB Flash Drive.
  • Once you have copied Windows XP on your USB Flash Drive insert it to one of your USB ports on the machine then restart the computer.
  • Restart the system as soon as the system restarts keep on tapping F11 this will bring you to the Boot menu.
  • This will be the same as using your Windows XP cd but instead you will need to select USB in the Boot Menu then press enter. on the installation steps it will be the same as installing using a disc.
  • Windows may restart during the installation and using a USB Flash Drive will be different at this point because it will boot directly to the USB, Once it restarts and may repeat the installation all over, to prevent this as soon as the system begins to restart from the installation go and keep on tapping "Delete" once it restarts this will bring you to the BIOS screen press F9 to set it to defaults then press F10 to save and exit this will restart again.
  • Once it restarts after setting the BIOS to defaults let the system boot on its own it will then show you a screen asking what windows to install the first thing highlighted will be the installation that was halted earlier just press enter then it will show you the windows installation page and will continue on it's own.
This is based on my own experience since I have an older Desktop that has the same Motherboard, I hope that I have given you all the options possible to installing your windows XP on your Motherboard k8mm-v.
Have a nice day,
mvincentc
Feb 02, 2011 | MSI K8MM-V Motherboard
I have a sandisk 8gb usb stick, I am tryind to copy files from windows xp to it but cant, i keep getting file not specified error. I can copy over small files on to it but nothing big. I know the stick is...
You need to re-format your Flash Drive. The default is FAT32 which only allows files of up to 4GB to be transfered. If you reformat to NTFS, ANY size file can be copied to your FLASH DRIVE.
WARNING ! ! By reformatting, you will loose ALL your data on your Flash Drive. Good Luck
Dec 12, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Jul 17, 2010 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
How can i install windows xp in to my toshiba satellite using a usb cd drive?
you can copy the contents of the windows XP installation disc to the USB drive. A 1gb flash drive should be sufficient.
Apr 11, 2010 | Toshiba Satellite 5005-S504 Notebook
How do you use a flash drive on the computar
Hello
Install the USB Flash Drive:
Plug the USB flash drive into a free USB port on your laptop (it is an approximately 1/2" slot, either on the side or back of the laptop).
Windows XP operating system should recognize it. It may ask you what you want to do with it. Select "Open folder to view files using Windows Explorer" and click OK.
Operating system should assign it a drive letter (see the title of the Windows Explorer window that opens).
Use the USB Flash Drive:
In Windows Explorer, click Folders button on the menu bar to show the installed drives on the left pane of the screen.
To copy a file from c:\ (hard drive) to flash drive:
Find the file you wish to copy on the c:\ drive.
Right-click it and select Copy.
Right-click the location on the new drive where you wish to paste the file, and select Paste.
(File should now appear in desired location.)
Hope you find this useful, if you have any more questions, just leave a comment and i will get back to you as soon as possible.
Kind regards
Andrea
Nov 17, 2009 | SanDisk 1GB Cruzer Titanium USB Flash...
HOW TO INSTALL WINDONS XP PRO ON TOUGHBOOK CF-18
XP can not be installed from usb as the bios does not enable it. Plug the ide hard drive into an older desktop system and install from boot on cd. Once all files are copied over then you need to copy the i386 folder over from the cd. Reinstall the hard drive into the toughbook and carry on the install from there.
Jun 09, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
My laptop is a windows 2000. my mom had this work laptop right. neither of us know the password and it does not have a cdr drive. when i try to copy and paste the windows xp instllaton files to my flash...
thankyou
Aug 19, 2008 | Intel (AXXSCD) (s2894109) Internal 24x...
Computers & Internet Logo
23 people viewed this question
Alun Cox
