Question about Home
Uberhaus shower column - Home
  • Morley Kaminski
    Morley Kaminski Dec 31, 2013
    the plumbing adaptor has no way of being secured behind the wall there is only the knut fastener to the brass connection which provides no way of securing it from pulling out of the wall
The grey cartridge (diverter valve) of my shower is discontinued. The whole copper piece costs over $100. The piece I need only costs about $20. Any suggestions if I can find this anywhere else?
Replace Shower valve - how much $? - RedFlagDeals.com Forums
forums.redflagdeals.com > Home & Garden
Nov 27, 2011 - Hi all Just bought a new shower column from Rona. ... the valving is in the pressure balance valve, thermostatic valve, diverter valve or volume ...
How To Troubleshoot A Thermostatic Shower Valve ...
? 9:45
https://www.youtube.com/watch?v=2pVuvG6q84A
Aug 10, 2011 - Uploaded by bathstore
This video shows you how to troubleshoot and rectify thermostatic control problems and the on/off control for a ...
Shower Systems & Valves - Home Depot
Jan 01, 2016 | Home
I installed a uberhaus tub and shower faucet luna series and I don't have the instructions the water won't shut off when I turn the handle to off
you might have the cartridge turned 180 degrees out of alignment. remove the handle, and carefully rotate the stem until the water shuts off, then re install the handle in its appropriate position.
Mar 26, 2015 | Home
" 1500-w wall convector" from uberhaus compared to "1500-w electronic converter" Stelpro
One of the main differences is the stelpro is 110 volts and the uberhaus is 240.
Dec 02, 2013 | Fahrenheat Electric Convector Baseboard...
Uberhaus 75175006 shower column has very low hot water pressure
The shower head may be clogged with debris.
Nov 09, 2013 | Home
Uberhaus faucet
needs new Oring kit
Sep 20, 2013 | Garden
Uberhaus bathtub and shower faucet 81585016 problem
The reason is because they built this wrong and Rona still decides to sell it. I have one in the wall that I am stuck with. Call up Mecanair, the rep for uberhaus and the they will tell you its not a mistake to have HOT water come out when the handle is at the C position.
Mar 06, 2013 | Home
Installation instructions for trevi Calista shower column
Where can I get spare parts for the Calista Shower Culumn? One of the joints inside has snapped.
Jun 26, 2012 | Home
Want to buy a thermostatic shower column which I believe was made in china--it looks beautiful but only has a 1 year warranty --sold only by Rona--will i have problems with it?
One year warranty is just good enough. Verify from Rona
if it will really honor the warranty. Nowadays, Chinese
product are now better than before. They learn it from the
American companies having facilities in China for lower
labor cost, and no strikes. You may buy the Thermostatic Shower.
Nov 22, 2009 | Hansgrohe Axor Hansgrohe Starck Shower...
Insufficient hot water from Gledhill pulsacoil 2000
changing the shower head will not do anything.to do what you want,you would need more BTU's or a bigger unit to supply more water,someone may be hogging the water also.
Feb 25, 2009 | Hansgrohe Axor Hansgrohe Starck Shower...
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
