Question about Dogtra Train and Beeper 2500 TB Beeper Collar
On my dogtra 2000 the collar will shut off when pushing the locatoor
How do you know if the batteries are good in the collar & how do I charge the collar
Google (brand)(SD-2000)(manual) without parens for instructions.
Feb 02, 2017 | Pets - Others
How do i change the battery on the dogtra element 1/2 mile training collar for dogs
As one might expect there are many models to choose from and you didn't specify the one you are asking about. Generally, these collars contain a rechargeable battery. The charger often has two leads so that the receiver and transmitter can be charged at the same time. Some of these units have exposed screws that when removed reveal the rechargeable battery. However, the manufacturer suggests returning the unit to them for battery replacement.
Feb 16, 2015 | Pets - Others
Door not closing all the way shut
top of the door hinge has a collar with holes drilled in it. there is or should be a roll pin in one of the holes which stops against a vertical pin. there is a torque rod in the door and this stop loads up like a spring as the door is opened to push the door closed. the torque rod is made to load up in either direction so they are compatible with left or right swing doors. they make a special tool for turning the collar and getting torque load but you can get it done with a small punch or two or even a couple of allen wrenches that will fit in the collar holes. you have to turn the collar to load up the torque rod and install the roll pin where it will do the most good. DO NOT put too much load on the rod it CAN and WILL break in the door. I usually open the door until I get a 3 or 4 inch gap and make sure it will close on its own from there. It usually only involves moving the collar two or three hole spots from neutral torque. If you cant get any torque or if it starts to load up and slips in the door than the rod is bad or the socket it sits in is stripped out.
Mar 28, 2014 | True GDM-23 Refrigerator
KTM EXC Head Torque Specifications
Thanks for contacting FixYa. I was reviewing some of the older un-answered questions trying to ensure your issue has been resolved.
KTM Torque settings
  1. Collar screw, front wheel spindle Front axle nut 40Nm 30ft lbs
  2. Brake Caliper front Brake Caliper front Loctite 243 2 19ft lbs
  3. Brake Disk, front Brake disk front Loctite 243 1 11ft lbs
  4. Brake Disk, rear Brake disk rear Loctite 243 1 11ft lbs
  5. Clamping screws, upper fork bridge Top triple clamp 20Nm 15ft lbs
  6. Clamping screws, lower fork bridge Bottom triple clamp 15Nm 11ft lbs
  7. Clamping screws, fork stubs Front axle pinch bolts 10Nm 7ft lbs
  8. Collar nut, rear wheel spindle Rear axle nut 80Nm 59ft lbs
  9. Hex nut swingarm bolt Swingarm nut 100Nm 74ft lbs
  10. Hex collar screw handlebar clamp Upper handlebar clamps 20Nm 15ft lbs
  11. Allen head screw handlebar support Lower handlebar clamps Loctite 243 4 30ft lbs
  12. Shock absorber top Shock absorber top bolt 60Nm 44ft lbs
  13. Shock absorber bottom Shock absorber botton bolt 60Nm 44ft lbs
  14. Sprocket screws Rear sprocket bolts Loctite 243 3 25ft lbs
  15. Ball joint for push rod Rear brake pedal pivot Loctite 243 1 7ft lbs
  16. Engine mounting bolts Engine mounting bolts 45Nm 33ft lbs
  17. Engine brace Engine brace 33Nm 24ft lbs
  18. Screw adjusting ring spring preload Shock preload collar bolt 8Nm 6ft lbs
  19. Spoke nipple Spokes 5Nm 4ft lbs
  20. Other Screws on chassis M6 10Nm 7ft lbs
  21. M8 25Nm 19ft lbs
  22. M10 45Nm 33ft lbs
  23. Other collar nutes on chassis M6 15Nm 11ft lbs
  24. M8 30Nm 22ft lbs
  25. M10 50Nm 37ft lbs
  26. Front Sprocket 44ft lbs
TF
Aug 26, 2011 | 2000 KTM EXC 300
Can't find reverse on my 91 Volvo 240. 5 spd manual transmission. Something is up with the detent collar or cable ...i think?
There are screws around the rubber boot. You can remove them and pull the boot up from beneath the carpet and see what is up. The detent collar is a pretty simple mechanism. There is a plastic stop that the shifter hits, and goes past when you pull up the collar. That plastic stop may need to be loosened and re-adjusted, or perhaps there is some foreign object in there that is keeping the shifter from moving to the end of its throw when you pull the collar.
Feb 27, 2011 | 1991 Volvo 240
Bought a new Fluidmaster from Home Depot and lost my instruction sheet in english......Colony FitRight two piece toilet. after flushing, the water still runs (most times) into the refill tube. It looks...
First, turn water off at wall valve under toilet. Next, find the plastic ring/collar almost at the bottom of the fluidmaster's shaft inside the tank. Pull UP on the locking ring/collar until it comes loose. This releases the upper shaft from the lower shaft and it can be pulled up or pushed down on the lower shaft to make the entire shaft taller or shorter. It has to be pulled or pushed over some plastic grooves, so it may take a bit of twisting and/or moderate force to move it. You must LOCK the ring/collar back down to the bottom of the upper shaft before turning the water back on. Locking the ring back down may require a bit of twisting back and forth to line up those grooves inside the shaft. Only turn water back on after this lockring is pushed securely back down, after adjusting the shaft height.
Nov 10, 2010 | Home
Assemble Swivel Assembly onto Kenmore Canister vac
Got this post off this web site...I just replaced my swivel and it worked:
http://www.managemyhome.com/mmh/answers/Answers.action#l4q110567
To install a new swivel assembly, you will need 2 small, flat tip screw drivers. Unplug the vacuum. Push the screw drivers in between the hose and the collar where you see the seams in the plastic collar on the end where the hose enters the collar. This will release tabs that hold the collar to the swivel. Pry and pull the collar back over the hose and then pull the small screwdrivers out of the collar. Slide the collar back along the hose. Unplug the wiring connections from the hose. Pull the hose wires up and out of the holder on the swivel assembly. Lift the tabs on the side of the hose and pull it off of the swivel. Push the new swivel onto the hose. Align the hose wires and secure them in the holder. Plug the wires from the swivel into the hose wires (blue to blue, white to white). Secure the swivel wires into the wire holder on the swivel assembly. Push the collar back up the hose and onto the swivel with the plastic seams aligned with the tabs on each side of the hose. Snap the collar securely into place.
Nov 12, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Dogtra Train and Beeper 2500 TB Beeper Collar Logo
50 people viewed this question
Top Dogtra Computers & Internet Experts
David Payne
David Payne
Are you a Dogtra Computer and Internet Expert? Answer questions, earn points and help others
