Question about Home
Clock manuals how to set time only not clock
  • crislano Dec 29, 2013
    how to set clock only
How do I set the time on a RCA USB Charging Clock Radio RC142?
Setting clock manually
1. Press and hold Set Time to enter the clock setting mode.
2. Press HOUR+ and MINUTE+ to adjust the time.
• Press and hold to adjust the time value quickly.
• The digits on the display ? ash in clock setting mode.
• The clock is in 12 hour format. The AM or PM indicator will illuminate to indicate the current time setting.
3. Press Set Time again to save the time setting
RCA RC142 User Manual General Controls
Mar 18, 2016 | RCA RC142 AM/FM USB Charging Clock Radio
How do I set the alarm on my Sharp Accu-Set Model SPC452?
  • 1 Insert batteries into your atomic clock. Without these the clock won't work. The number of batteries required depends on the clock. There is usually a panel on the back of the clock where you can insert the batteries.
  • 2 Set the clock. Usually, this is done automatically, as the clock will seek out and receive the signal within 6 to 8 minutes. If this doesn't happen, you'll need to do it yourself. Hold down the "Set" button. A figure on the clock will start blinking. Adjust this by pressing the adjustment button. Press "Set" again to go to a new time. Continue until the clock is properly set. No matter what you put time you put in manually, the clock should adjust to the atomic setting within 48 hours.
  • 3 Set the time zone on your atomic clock. How to do this depends on your specific clock. On some, there is a time zone slider; you simply slide it to your time zone. Otherwise, you will need to enter the manual mode you used to set the clock. Switch the mode until the time zone starts blinking. Now, adjust until your current time zone is selected. If it goes by Greenwich Mean Time (GMT), the time zones in the United States are -5 for Eastern time, -6 for Central, -7 for Mountain, and -8 for Pacific.
  • Read more : http://www.ehow.com/how_6403731_instructions-time-zone-atomic-clock.html
    Jan 29, 2015 | Audio Players & Recorders
    Www.lacrossetechnology.com/8248 need to reset time!
    I'm not totally sure what you mean by "reset the time" because the unit normally sets the time automatically from the WWVB radio time signal. If you want to do it manually, this is what the Instruction Manual (PDF format) says:
    MANUAL TIME SETTING
    In case the atomic clock is not able to detect the WWVB-signal (disturbances, transmitting distance, etc.), the time can be manually set. The clock will then work as a normal Quartz clock.
    1. The hour digits will start flashing in the upper LCD.
    2. Select the desired hours by pressing and releasing the + key.
    3. Press and release the SET key to advance to the minutes setting.
    4. Now the minute digits will start flashing.
    5. Select the desired minutes by pressing and releasing the + key. If the + key is held, the units
      will increase by 5.
    6. Press and release the SET key to confirm the Time setting and continue to the Year setting.
    Nov 08, 2012 | La Crosse Radio Controlled Atomic Clock
    How do I change the time on my tom tom
    The clock on your navigation device is automatically synchronised with the satellite clocks. You can also set the clock manually, for example when the device is indoors and unable to receive a satellite signal. The default setting is to automatically adjust the clock for the current time zone.
    How to change clock settings To select the time format and to set the time, follow these steps:
    Open the Main menu and tap Settings.
    In the Settings menu, tap Set clock.
    Select how the time should be displayed, then tap Next.
    When you do not have a satellite signal, you are asked if you want to set the time manually.
    Note: Since you need to be outside for your navigation device to receive a satellite signal, you might want to immediately set the time manually. The device will then set the time automatically when you next take the device outside.
    Tap Yes to set the time manually or tap No to set your device to update the time automatically using GPS satellites.
    Hope this was helpful. Thank you for using fixya.
    Jan 26, 2011 | Tomtom GPS
    Setting the clock on a microwave what is the last action after setting the time. Everything I've tried results in the error message coming up.
    According to the manual this is how to set clock.
    To set the clock, press "Clock" once or "Timer/Clock" twice (depending on your keypad).
    The colon symbol (:) will flash.
    Enter time of day. The time appears in the window; the colon continues to flash.
    Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set.
    If you need the manual it is on link below.
    http://service.us.panasonic.com/OPERMANPDF/NNH624-SET%20UP.PDF
    Good Luck
    Nov 08, 2010 | Panasonic NNH965BF Microwave Oven
    How do you set the time on the clocl.
    CLOCK SETTING
    1. To set hour, while holding the CLOCK button, press H TIME until
    the desired hour is displayed. Then, release both buttons.
    2. To set minute, while holding the CLOCK button, press TIME M
    until the desired minute is displayed. Then, release both buttons.
    Similal manual may be useful:
    http://www.cobyusa.com/files/manuals/CRA58_MN.pdf
    Sep 20, 2010 | Coby CR-A98 Clock Radio
    How do I set the time on my Pioneer RT500?
    Hi!
    Please follow the instructions given below... =)
    Setting the clock
    The clock is set to the correct time automatically, but it
    can also be set manually. The clock can be set for
    daylight saving time and time zone.
    Preparation:
    • Turn ON the TV and set it to the video input mode.
    • Select “CLOCK” from “SYSTEM SETUP”. For the
    procedure, see steps 1 to 3 in “Using the SETUP
    MENU”
    1 Press SETUP while the DVD and video tape is
    stopped.
    The SETUP MENU screen will appear.
    TIMER REC SET
    SYSTEM SETUP
    AV SETUP
    REC SETUP
    CH SETUP
    OTHER
    SETUP MENU
    ENTER/
    SELECT ENTER RETURN BACK SETUP END
    SELECT
    2 Press  or  to select the desired menu and
    press ENTER.
    The submenu screen of the selected menu will appear.
    TIMER REC SET
    SYSTEM SETUP
    AV SETUP
    REC SETUP
    CH SETUP
    OTHER
    LANGUAGE
    PARENTAL
    CLOCK
    DISC SETUP
    OTHER
    SETUP MENU
    3 Press  or  to select the desired submenu and
    press ENTER.
    The screen for the selected submenu will appear.
    CLOCK (manually)
    You can manually set the date, year and present time
    with the remote control.
    Ex.: Setting the clock to “10:20AM” October, 30th, 2004.
    1 Select “CLOCK” and press ENTER.
    01/01/04 12:00AM
    2 Select the desired items using  or  (month,
    date, year, hour, minute and AM/PM) then press
    ENTER.
    3 Press  or  to set the value of the selected
    item.
    • For the minutes, press  or  once to set the time
    minute by minute, or hold down either of buttons
    for several seconds to set the time in 10-minute
    intervals.
    10/30/04 10:200AM
    4 Repeat steps 2 and 3 to set the date, year and
    present time, and press ENTER. The SETUP MENU
    will close.
    This completes clock time setting.
    AUTO CLOCK
    You can automatically set the clock by turning “ON” the
    AUTO CLOCK function.
    When you want to set the auto clock function to “OFF”,
    select “AUTO CLOCK”, press ENTER and select “OFF”
    from the list.
    Auto clock setting
    Preparation:
    You must connect the antenna or cable before connecting
    the AC cord to the power source.
    Wait 30 minutes with the power turned off, after the
    antenna or cable is connected, for the auto clock
    feature to activate.
    After the clock is set automatically, you may have to set
    the time zone and daylight saving time. (See page 26.)
    Press STANDBY/ON to turn on the DVD/VCR after the
    auto clock operation completed.
    • When shipped from the factory, the “AUTO CLOCK”
    option is set to “ON” position.
    • If you turn the DVD/VCR on during auto clock
    setting, the clock is not set.
    • After a power failure or disconnection of the power
    plug, the clock setting will be lost. In this case, wait
    30 minutes before turning the DVD/VCR on.
    • With cable box connection, if the auto clock setting
    is unsuccessful, select the PBS channel carrying
    the XDS information, then turn the DVD/VCR off.
    After 30 minutes, turn the DVD/VCR on.
    • If the clock is not set automatically, set the clock
    manually.
    STANDARD TIME (Time zone)
    In the rare event that you live within the broadcast range
    of two stations in two different time zones, the DVD/VCR
    may recognize the wrong station for the auto clock set.
    To correct the situation:
    Select “STANDARD TIME” and select the time zone from
    the list below.
    Selectable time zones and correction times
    ATLANTIC: GMT – 4 hours
    (GMT: Greenwich Mean Time)
    EASTERN: GMT – 5 hours
    CENTRAL: GMT – 6 hours
    MOUNTAIN: GMT – 7 hours
    PACIFIC: GMT – 8 hours
    ALASKA: GMT – 9 hours
    HAWAII: GMT – 10 hours
    AUTOMATIC: AUTO SET
    Note
    • When shipped from the factory, the “TIME ZONE” is
    set to “AUTOMATIC”.
    • After making the auto clock setting, in some cases
    the clock may display another time zone. You can
    correct the clock by selecting your time zone
    setting above.
    • When the clock is not set or you set the clock
    manually, the time zone setting is not available.
    DAYLIGHT SAVING TIME
    You can set the clock to daylight saving time automatically
    or manually.
    To select daylight saving time, select “DAYLIGHT
    SAVING TIME” and select “ON”, while to cancel the
    daylight saving time, select “OFF”.
    ON: For manual setting (forward 1 hour)
    OFF: For manual setting (back 1 hour)
    AUTOMATIC: For automatic setting (read XDS in
    the signal)
    Note
    • When you want to set daylight saving time, on the
    first Sunday in April you set it to “ON”, and on the
    last Sunday in October you set it to “OFF”.
    • When shipped from the factory, the “DAYLIGHT
    SAVING TIME” option is set to “AUTOMATIC”.
    • When the clock is not set, the daylight saving time
    • When there is no daylight saving time in your area,
    always select “OFF”.
    Jan 03, 2009 | Pioneer DVR-RT500 DVD Recorder/VCR
    S10Scan atomic clock model 87310 time is 4;pm should be 10:am
    Hi
    Time zone setting
    Language Setting
    The weekdays can be displayed in LCD1 with the pre-set languages: US English, French and Spanish.
    1. Set the desired language for the weekday display in LCD 2 by use of the + key.
    2. Press the SET key to enter the mode “Manual Time Setting”.
    Manual Time Setting
    In case the Skyscan Atomic Clock is not able to detect the WWVB-signal (disturbances, transmitting distance, etc.), the time can be manually set. The clock will then work as a normal Quartz clock.
    Note:
    In 12 hours mode the time will be displayed with an additional “PM” for the time from 12:00 noon until 11:59.
    1. The hour digits will start flashing on LCD1. Set the desired hours by pressing the +key followed by pressing the SET key.
    2. Now the minute digits will start flashing. Set the desired minutes by pressing the +key . If the + key is held, the units will increase by 5.
    3. Press the SET key to move to the “Year Setting”.
    Note:
    The unit will still try and receive the signal every day despite it being manually set. When it does receive the signal, it will change the manually set time into the received time. During reception attempts the WWVB tower icon will flash. If reception has been unsuccessful, then the WWVB tower icon will not appear but reception will still be attempted the following hour.
    WWVB time reception takes place from 12:00 am through 6:00 am each day (attempts WWVB reception every full hour within this time frame). When the time signal is received for example at 1:00 am, the Skyscan Atomic Clock will not attempt to receive the WWVB signal for the remaining hours until 6:00 am. Therefore, the next signal attempt will take place between 12:00 am and 6:00 am the next day. The other times WWVB reception takes place, are upon setup and after manual time set exiting mode. Reception is generally not possible during daylight hours due to the interference of the sun.
    for more details see user manual...
    Thank you
    Dec 12, 2008 | SkyScan 86709 Atomic Wall Clock
    Centrios Atomic Desk Clock/Temperature
    Here is how you adjust the time zone:
    1.) push MODE till "AL" appears after the minute.
    2.) tap "SET" (tap means push but do not hold) and time zone will advance.
    3.) THE TRICK: The Time Zone can only be set in the Alarm Mode. Make sure you so not push and hold "SET" until the hour flashes as you would to set the alarm time. You just go into Alarm Mode and tap "SET" to advance the Time Zone by one zone per tap. When the Time Zone is where you want it, tap MODE to return to the clock and set the correct time.
    Nov 08, 2007 | Audio Players & Recorders
    Manual for timex 609t alarm clock
    you should be able to just push the Time button (top one third from the right) and when it starts to blink, just change it like you change the alarm.
    Oct 17, 2007 | Audio Players & Recorders
    Home Logo
    26 people viewed this question
    Top Home Experts
    Donni Steen
    Tom Chichester
    Are you a Home Expert? Answer questions, earn points and help others
