Question about Vizio 39" E390VL 1080p LCD HDTV
At certain times, the pitch of a voice on my new 39" Vizio will cause a humming sound. This is intermittent. Adjusting volume up or down can mitigate it somewhat. It's like it happens at certain pitch or volumes. It's new so I can take it back. But is there something I can do to adjust it?
SOURCE: Vizio Volume Control
I am sure you did this but recheck your audio menu on all your inputs. I have found that cables can go bad so make sure they are in good shape. Are you haveing the problems with all your inputs dvd, cable (direct cable or a cable box) whatever? It is hard to affect the audio by just moving the set. I am hoping that you changed something or the cables went bad that would be the easy solution.
Good Luck!
Posted on Aug 08, 2008
SOURCE: My Vizio Tv volume does not work properly. When
Okay I just called and found this out. I have the 32 inch vizio hd flat screen. My problem with weak and fluctuating volume, was that I have a cable box. Go into menu, then audio and under the advanced audio section you will see srs trusurround HD and srs trusurround. Basically this function automatically adjusts volume levels for satelites and whatnot. But because cable boxes automatically have this feature you could just turn off the srs trusurround. Hopefully that should help you.
Posted on Jun 29, 2010
SOURCE: The sound on the vizio 37' lcd seems to fluctuate
I have read that you will need to turn off SRS tru-volume off to fix this problem.
Posted on Dec 27, 2010
SOURCE: I just bought the Vizio E421VA and I am
we have had the same problem and I suggested to Hubby that we had better return it soon. He did some research and we are trying this: use the TV remote and press the center button "Select", Choose Audio, Make sure True Volume is set to On. I've only been watching for an hour but it very well may have solved the problem. Hope it works.
Posted on Feb 26, 2011
spr1949
  • 1182 Answers
SOURCE: We replaced the IR sensor on our Vizio but still cannot control the volume via the remote (which has tested good). Any further suggestions?
Since sensor is receiving the signal of other inputs, there is nothing wrong with it. This looks like an incompatibility issue. You may have to retry using the original remote control.
Posted on Jul 31, 2012
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
I have a crosley record player but there is a high pitch tone if I get a better needle will that help with the sound? The tuner adjustment button and volume really doesn't help the super high pitc
Not at all in this case. You either have a loose wire to connections to the cartridge, which can be fixed by hand. Just push the wires on to the cartridge. Or you have a fault in the power supply of the deck. Most likely a mains filter capacitor that is letting the 50hz mains hum in.
The hum will either be caused by a poor earth connection or a power supply problem. The stylus would not cause any hum at all.
Mar 22, 2013 | Audio Players & Recorders
Background noise
no problem with..record some part of the start with no voice just a 5-10 seconds remain quite...just kept running the recording...then start and record your voice after which install AudaCITY Software and drag your audio file in it and then select the first 5-19 seconds recording which was just the background kept recording selecting the part go to Effects -> Noise Removal then press Get Profile,
after which again select all the track by: Control + A key on PC and then go to Effects Noise Removal move the bar to the left side...and press ok/continue key....now your track is very much clean by the noise...and
for sound loudness select all the track and go to Effects -> Normalize then again Effects -> Amplify put the slider value to -0.1 of what the value is shown.
Jan 19, 2012 | Vizio VSB210WS Soundbar
My vizio tv is practically brand new as of christmas, when a movie or even tv is on the voices are very soft and the music or background noises are EXTREMELY loud, so I am always turning the volume up and...
I had this problem with my previous TV (Syntax by Olevia, an off brand). It only happened to me on certain channels, and for certain shows. What is happening is the TV station is broadcasting the audio in Dolby 5.1 format. For some stupid reason, the TV is playing the background speakers (effects) instead of the speaking parts. You get a little bleed-over of the voices into the back speakers, so voices are there but really quiet. Unfortunately my TV didn't have any surround sound options to fix this.
See if your TV has a surround sound option. Otherwise, you will need to connect the TV sound output to a surround sound system that can properly decode the audio channels.
Feb 06, 2011 | Televison & Video
I have a new tv, a Vizio model VL370M and there is a humming noise when I am using standard definition. It is present also when I use a DVD player. It is not the cable box. A Vizio repair man put in two...
If you can handle it then check the 12VDC supply filtration. I mean to say that you have to confirm that the 12VDC is coming with stability and no noise inside it. The filtration work is being performed by the capacitors in the circuitry. Check the capacitor condition in main board please. If it is plague (bad capacitor) then try by replacing it. The sound can be mainly heard through speakers and it most probably caused by sound processing area presents in main board. This kind of thing can be eliminated by changing the main board.
good luck
Feb 02, 2010 | Vizio L37 Television
Hum from tv
try unplugging any equipment that you have attached to the tv one at a time, such as dvd players, surround sound, cable box, etc. also if you have a cable box attached, try adjusting the volume on it. if you have everything unplugged from tv and it still hums, then it may be a tv issue
Oct 21, 2009 | Televison & Video
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Oct 03, 2009 | Bose Companion II Computer Speakers
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
I have a Vizio 42' and a cable box and there's a constant humming
I think I had the same problem. This is how I fixed it.
I have my vizio 42 hooked up to a Harmon Kardon surround sound, and the digital cable box. Essentially, I can adjust the volume 3 ways - through the tv, cable box or av receiver. The humming sound happens when you have the volume maxed out on the av receiver and not the cable box.
For example, the sound level on my Harmon Kardon goes from -10 (lowest) to 10 (loudest), with 0 being the middle ground. The buzzing was happening when the Harmon Kardon was set to 10, and I was using the cable box volume to adjust the sound. To fix it, I turned down the volume on my receiver to 0, which may be about 50% max volume of the receiver. Then, I switched devices and used the volume on my cable box. This got rid of the static I was getting. Hope that helps.
Jan 09, 2009 | Vizio VX32L Television
Vizio 39" E390VL 1080p LCD HDTV Logo
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
