Factory reset lg dvd home theater ht963ta
Forgot security code
  • 3422 Answers
SOURCE: unlock a panasonic dvd home theater to region 2
You can buy the codes from HERE or HERE
Goodluck..
Posted on Mar 19, 2008
  • 165 Answers
SOURCE: my panasonic home theater dvd does'nt work with my one for all remote
with your remote control is that what your re saying change baterries for newones...saludos
Posted on Nov 17, 2008
SOURCE: Sony DVD Home Theater System remote control code
I have the same system and one of my dogs got to the remote. I have a philips PMDVR8/PDVR8 universal remote. I was able to get the dav-hdx265 to turn on/off and do volume up and down by using code 0200. I have not been able to get the DVD functionality to work yet, but I will post if I do.
Posted on Dec 14, 2008
  • 4 Answers
SOURCE: need to reset my dvd player
From the manual:
Press STANDBY/ON to put the system in standby, then press and hold the front panel (stop) button for about 8 seconds until the display shows Mem.clr?.
Press the front panel I<<<< or the >>>>I button so that the display shows Interlace?.
Press the front panel >/II button to set to interlace & switch the system back on.
Posted on Mar 12, 2009
SOURCE: Unlock Region Code for LG XB12 Mini Home Theater
Below is the only known process to unlock the region settings on that model of dvd player.
Make sure there is no disc in it
Turn on by pressing "Power"
(--------) apears an "No Disc"
Press "Pause" on remote and "314159"
"Code" apears
Press "0"
"Code 00" apears
press "enter"
Turn off and on
Hope this works for you, let me know. If it doesn't then there are no available region hacks for your dvd player.
Thank you for trying Fixya!
Posted on Mar 25, 2009
Hard reset
You can reset and restore the factory default settings of your LG Attune UN270 mobile phone by following below instructions:
  • Touch Phone Settings and Security.
  • Enter the four-digit Lock Code.
  • Touch Master Reset.
  • Touch OK
  • A message will pop up that says "All settings will revert to factory default."
  • Touch Revert or Cancel.
  • If you touch Revert, enter the four-digit Lock Code. The phone returns to the configuration default.
May 22, 2013 | LG Attune
Tip
LG LH-D6235 Region Free Fix
LG LH-D6235 DVD Home Theater Region Free Fix
Would you like to make your LG LH-D6235 DVD Home Theater Region Free?
Follow these steps:
  1. Press the Pause button on your remote control
  2. Using your remote control enter the code 3, 1, 4, 1, 5 and 9 (If your unit does not enter the following mode which enables you to enter a region code, repeat steps 1 and 2. You may need to enter these codes in a shorter time span for them to work.)
  3. Press the 0 button on your remote control for Region free, 1 for Region 1 or 2 for Region 2.
  4. Press the Pause button on your remote control
  5. Power off your player and wait a few seconds
  6. Power on your player
I hope that helps.
____________________________________________________________________
Download LG LH-D6235 Home Cinema System Manual
on Jul 14, 2010 | Audio Players & Recorders
Tip
Follow these steps:
I hope that helps.
on Jul 14, 2010 | LG LH-D6230 System
I forgot the lock code to my rumor touch and can still access the phone but cannot lock it because i forgot the code... what do i do?
hi dear.. please help me.. i forgot my NOKIA E63 restore factory settings lock code. please send the how to reset my lock code to manikanta.art@gmail.com
May 24, 2011 | LG Rumor Touch
Need code to unlock region for Philips HTS3181
you must have set your THEATRE by few codes whichever options you got in the setting options and you must have set some password so noone can use it except you and now you hv forgot the password please do not try it again call to the technicians they have few codes to reset the system again and unlock the system and some times it reaches to the factory setting ..please do not try to reset your HOME THEATRE by your own it may the result of some more loss
Oct 30, 2010 | Philips HTS3151D/37 Theater System
How do you reset the security code if you have
If you forgot or do not know the reset code for your LG Vu here is the way to do it. Works, just did it to mine.
To do a factory reset with your LG Vu cell phone, you must enter the Test Menu, the instructions are below.LG Phone Problem and solution
    1. Dial 277634#*# on the keypad to access the Test Menu
    2. Select Factory Reset
    3. Select Yes
    4. After the factory reset is complete, you must restart your phone for it to take full effect.
Jul 25, 2010 | LG Vu CU920 Cellular Phone
I have a LG home theatre system model HT963TA(HT963TA,SH93TA-S/CW) THE DVD PLAYER "BLACKS OUT " FOR SHORT PERIODS OF TIMES INTERMITANTLY.I TRIED CHANGING THE HDMI CONNECTION AND ALSO CHECKED THE DVD'S ON...
I have this problem too.If you set the DVD player resolution to 480p instead of 1080p it will not have the blackouts anymore. Of course this defeats the whole purpose of buying an "upscaling" DVD player. Just curious: what TV's are-you using?
Sep 08, 2009 | LG LST-3510A DVD Player/Receiver
Security code reset
1)power on KE970 without SIM
2)type 2945#*#
3)selcet "Factory Reset", now it will reboot. now OK!
Apr 19, 2009 | LG Shine KE970 Cellular Phone
Resetting the progressive scan mode on an LG lh-d2645 home theatre system
the above is correct but you need to have the dvd player on with no disc in so "no disk" is shown on the front display. then hold down the stop button for 5 secs to reset the display mode back.
Jan 20, 2008 | LG LH-D6230 System
61 people viewed this question
 Grubhead
Grubhead
