Water is leaking on the fill cycle from the seam between the lid and left side panel. How do I get the lid to lift upward...it looks like there is a hinge on the back?
  • pdublu1 May 19, 2009
    That is helpful...but still how do I get to it? Does the washer lid just pry up or is there some other means to get the top up to gain access to those hoses?
    Thanks!
  • pdublu1 May 20, 2009
    So far, very helpful
    Brigadier General:
  • 8,619 Answers
Hi
Usually the lid prys off so that tub and other components can be accessed. Hoses and air gap device can be accessed from the bottom (in some models). Inlet spout can only be accessed by removing the top lid cover.
Please tell me the model number of your Unit so that i can provide you with model specific information.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on May 19, 2009
    Sergeant:
    Champion:
  • 219 Answers
Hi, During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
Thanks! Sandy
95 accord trunk fills with rain water
Leaking trunk seal or rear window sealer also check the tail lights are mounted properly and that the trunk is closed all the way
Jan 10, 2018 | 1995 Honda Accord
I have a GE toploader washer. The model # is WBSR1060T (VVSRV1040V, & YVSR1040V were also on the washer too) the washer keeps filling to the max setting no mater what the water level is set on, also...
Remove the front panel of the washer by using a putty knife to release the retaining clips, located in the seam between the front panel and the washer's top, about 2 inches in from each side. With an empty wash tub, remove the small hose on the left side of the outer tub and clean out the inside of the hose. Replace the hose. Test.
Mar 15, 2011 | Washing Machines
My whirlpool duet sport is more than 3 years old and now leaking on the left side usually towards the end of each washing (rinse cycle). It drains perfectly that no water is left in the tub when the cycle...
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 27, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Washing machine filled with water and then stopped mid-cycle. This happened before and the repairman said it is a door switch. He removed the lid and in 5 mins moved something at the back of the machine....
the lid switch for you model is located inside the cabinet of your washer. you should be able to access it by removing the front panel. by inserting a putty knife or similar tool on the left and right side along the seam of the cabinet. you should be able to feel two small clips that hold it in place. lift up SLIGHTLY on these clips and remove one side at a time. once you have done this you may need to release the top as well, held in by two 3/8 hex screws. the lid switch is on the right. and is held in by two phillips screws and a wiring connection as well remove the two screws and the connection and replace it with a 3355458 lid switch. hope this was a help to you
Thanks
Oct 11, 2009 | Whirlpool LTE6234D Top Load Stacked...
Washer fills with water, washes, but when it gets to spin cycle it quits
probably lid switch uplug unit! to check take out two phillips head screws either on front console left and right about 1 inch in from side or behind in console left and right lift out and roll up console look for lid switch connector in middle of cabinet release and pull up put a small piece of wire between the outside two terminals on connecter then plug back in and try spin cycle if it works order lid switch with model number 877-262-1479
May 31, 2009 | Kenmore 24032\24036 Top Load Washer
Wbsr3140 washer leaks
looking at the washer the front panel is held on by clips, take a flashlight and a butter knife and slide the knife in the top crack of the front panel and slide to one side until it stops. this is a clip. usually in line with the washer lid seam. there is one on each side. push in and up on the clip while gently prying door forward, and wala it will open. if you can fill the washer with water alone and it doesnt leak. you probably have a soap issue which can be solved by cutting the soap usage down
May 17, 2009 | GE WBSR3140DW Top Load Washer
Water Leak Top Load Maytag Washing Machine
you have a leaking "injector sleeve". you need to remove the 2 screws that hold on the front panel ( they are at the bottom) once you remove them, pull the panel outwards, towards your knees. it will release. on both sides in the top you have 2 bolts, remove them, it think they are 3/8ths. on the left if you have a bleach dispenser, remove that hose before you lift the lid. Once the lid is up you will see the injector area on the top left at the side. Hope that helps
Mar 02, 2009 | Washing Machines
Kennmmor Elite oasis top loader leaking from the bottom?
Mar 01, 2009 | Kenmore Washing Machines
Leaking machine
Feb 01, 2009 | Washing Machines
LF code appears and washer does not spin out
This is where to find the manual. When you get to it, it tells you that LF is for long fill which means it is taking longer than ten minutes to fill with water so it shuts off and displays the error code.
Bottom Line : Check your water pressure.
Aug 01, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
94 people viewed this question
Top Washing Machines Experts
