Question about DISH Network IR Remote Control
Need codes for toshiba tv
Need to switch tv video input
  • Official Brand Answer
  • 184 Answers
Hi Howards, my name is Kimberly and I form part of the Social Media department with DISH. I have listed the steps below to assist with programming the remote to your TV. If you have any other questions, let me know at Kimberly.escobar@dish.com!
You can look up codes if needed here: http://www.mydish.com/support/apps/remotecodes.aspx?WT.svl=leftnav
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if it is working.
5.) If no function, repeat steps 1-4 with another code.
NOTE: we do not guarantee our remote will control all your TV functions. Our remotes are made to work strictly with DISH equipment.
Kimberly Escobar
Social Media Representative
DISH L.L.C
Posted on Mar 27, 2014
ON MY OLD TOSHIBA M27A30 TV I CANNOT SWITCH BETWEEN TV/CABLE
Your set has lost ability to switch between different rf sources. Ols set - maybe you can just use one of the working inputs and manually switch when the need arises.
I would not spend any money on it.
Sep 20, 2017 | Toshiba Televison & Video
32" toshiba 36a60 plays DVDs but not cable TV
Did you switch video inputs from the remote, each input has its own menu item.
May 19, 2017 | Toshiba 32DF46 32" TV
How do i get the s video to work on my toshiba tv.
Plug somthing into it and select that input.
Aug 31, 2011 | Toshiba CZ36T31 36" TV
I just got a toshiba theaterview sd dolby digital
That particular TV has both "component video" and standard video inputs. The DVD player might have a component video output (it will be three separate connectors of three different colors.) You will need a component video patch cable available at most electronics stores. If your DVD player doesn't have that input then use the standard video connector, yellow wire connects the video out on the DVD player to the Video input on the TV. The red and white wires are the left and right stereo audio connections they also make a cable for that. It will be color coded so make sure you match the codes from the output to the input on the TV. This set has two video inputs, you will get your best resolution if you use them instead of a "channel" input.
You will need the remote to select the video 1 or video 2 inputs. You can connect your DVD player and your game at the same time. Just use video 1 for the DVD and video 2 for the game. They require the yellow, red and white connector cables. Just follow the color code and match the colors with the jacks on the TV and other units. There is actually a third video input Video 3 behind the little door on the front panel. That would be convenient for the game if you want to remove it easily when not in use.
Push the menu button on the remote (big button in the middle) go to the video function and select either Video 1 for your DVD, Video 2 or 3 for your game.
The correct video input for what you want to view is important. Also if you don't have the user's manual it's available for free here: http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/TV/2003/32A33_32_36A43%28E%29_A.pdf
You might also need to download an Adobe Viewer which allows you to read .pdf files.
That is also available for free at:
http://get.adobe.com/reader/
If you already have malware protection (viruses and the like) un-check the MacAfee box so you don't download that too.
Zashiban
Jun 04, 2010 | Toshiba 32A43 32" TV
Switch Toshiba projection tv to receive input from video-1?
jbrowne_usa
If your DISH remote is programmed to your Toshiba TV, you can press the TV button at the top left of the remote and then release. This will put the remote in TV mode. Press and release the TV/Video button just below the clear TV button. This will cycle through the inputs on your TV. Continue to press and release until you have Video-1 displayed on your TV screen. I hope this helps.
Ray Calo
DISH Network
Jun 14, 2009 | DISH Network DVR-625 DTV Receiver /...
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Apr 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Toshiba 50HP66 Plasma TV
Found that video 1 and video 2 switching does not work. The switching IC was HOT!. Then found a third video input works but no sound. Hooked -up sound output of DVD player to amplified loudspkr and it works, I hate to throw away a 2 year-old plasma TV when TV and cable still works.
Thanks for the offer anyway.
Mike
Oct 12, 2008 | Toshiba 50HP66 50 in. Plasma Television
Connecting VCR to TV
If you have the original remote controller, try to switch inputs. It must be on the f-connection ( coaxial) at the moment. You need to switch it to RCA or S-Video Inputs.
Aug 30, 2008 | Toshiba 27DF46 27" TV
Toshiba that uses CT-90040 remote
Is the cable remote a programmable universal? If so, just a matter of finding the codes to reprogram functions.
Concerning the "tuning video", are you saying that you can't get to different input sources?
Oct 15, 2007 | Toshiba 36AF42 36" TV
DISH Network IR Remote Control Logo
83 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
