Question about Viking Kitchen Ranges
Oven knob hit off, how to re-install it - Viking Kitchen Ranges
How do I turn on my electric whirlpool oven?
First of all set the clock, then the rest is easy.
Oct 01, 2014 | Ovens
Viking oven knob was hit off. Now I cannot put it back on
Need to check that the connection rod is white plastic, if it's black its a piece broken from original knob. Replacement knobs from Viking are $25-34. I used a Brainerd #64686 from Lowes (under $3) that works and looks just fine
Dec 29, 2013 | Kitchen Ranges
I hit the bake button on my oven and after 10 secs it says preheat and thats all that happens nothing else no heat at all
Your oven will continue to indicate that it is preheat mode until the thermostat senses the proper set temperature. If you are getting no heat then you will need to address that issue. This could be many things but the most notorious would be the heating element. Could be the control panel as well. Some ovens have a knob for preheat, bake and clean with a separate knob to adjust the temperature. Make sure both are set properly.
Regards, Tony
Apr 07, 2011 | Kenmore Ovens
Gas oven knobs seizing when oven hot
hi my name is mark, yes most manual gas valves can be disassembled and lubed. you will need gas valve grease. remember a little goes a long way and shut off the gas to the unit before disassembly.
Feb 21, 2009 | Cooktops
Lost manual for eaton/viking model # RS3025W-1.
set both knobs the temperature and the bake broil to the lock mode, set the time such as 3 to 4 hrs I think and hit start. You should then here the oven begin to lock.
Jan 28, 2009 | Viking VESO105 Electric Single Oven
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
Re: my whirlpool digital oven
The red key sign is a lock against children. To cancel it you have to hold the two buttons at the same time for 5 seconds (you activate it the same way).
The STOP sign appears after the cooker switches of after a power cut. You just have to press the left button, and, using the right knob, set the time.
Jun 24, 2008 | Ovens
Bottom oven door won't open
Started the pyrolysis cycle for 1 minute and then cancelled it. The door then unlocked.
May 25, 2008 | Gaggenau EB294/295 Electric Double Oven
Jenn Air auto clean oven
once cleaning is completed and completely cooled down. Turn both knobs off. turn both knobs back to clean and hit cancell button twice. should un-lock then
Dec 28, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Kitchen Ranges Logo
Top Viking Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
