Question about 2007 Land Rover Range Rover Sport Coolant/Antifreeze
Recommended anti-freeze coolant for a 2006 HSV Clubsport R8
  • OES Genuine Master
  • 10,263 Answers
Any brand as long as you get enough for a 50/50 mix. Find out the capacity of the cooling system...put half that amount of antifreeze in then top off with water. Don't forget to run the engine long enough to open the thermostat and then add water if necessary.
Posted on Jan 01, 2014
Is it safe to drive a car when it leaks out water .Car is not overheating.
It is never recommended to drive a car that is leaking coolant. However, if the leak is small, and you keep close tabs on the coolant levels to avoid running low on coolant, you can drive for short periods of time until repairs can be implemented. Obviously, larger leaks may make this impossible. Also, remember to keep the proper ration of anti-freeze to water in the coolant when you top off. Even if it is not winter, the engine parts need the anti-freeze to prevent corrosion and to lubricate the water pump. Going with straight water, or an overly diluted mixture will cause more problems for you down the road.
Feb 10, 2016 | Cars & Trucks
Coolant boiling problem
There are a number of possibilities:
1. Not enough anti-freeze in the cooling system. Anti-freeze not only protects against freezing, but also boil-over.
2. Defective thermostat. If it is stuck closed or partially so, it can cause overheating.
3. Clogged radiator.
4. Defective water pump.
5. Blown head gasket.
Dec 30, 2015 | 2006 Peugeot 206 1.4
Why is clutch fluid is leaking from the bellhousing out of my 2004 hsv clubsport? how do i fix this?
Hey.
The most common answer to your question is the clutch slave cylinder is mounted inside the gear box this is where your clutch fuild would be coming from.
To fix this problem you need to remove the gearbox from the vehicle and replace slave cylinder .
if you are going todo this make sure you check the clutch while its all strip down.
Jul 02, 2014 | 2002 Holden HSV
What size cd player fits vy 2003 holden clubsport R8
As far as I can decipher this question the answer is easy to find at Crutchfield.com . They have people there to talk to as well.
Dec 08, 2012 | Audio Players & Recorders
I have a holden vx clubsport when i turn key so dash lights are on there is threebeeps then it wont start, if i turn straight to start it fires up beeps three times then dies
it sounds to me like hsv key / immobiliser problem. if you have other keys try them. otherwise its an auto electrician to find fault. hope this helps
Dec 22, 2011 | Cars & Trucks
I have just replaced the thermostat in my mitsubishi outlander 2006 zf 2.4l auto wagon and I am flushing the radiator but i need to know the coolant/radiator capacity and the ratio of coolant/water
Hello aislin87,
The total engine coolant capacity is 7.4 quarts.
Just changing the thermostat should not drain the entire system so you wont need that much.
The recommendation is above 30% but below 60% anti freeze to water to provide for proper freeze and anti-corrosion protection.
Regards,
netvan
Feb 27, 2011 | 2006 Mitsubishi Outlander
The radiator warning light blinks red on startup, what kind of radiator fluid does the vehicle take? 2005 VW new beetle
VW have their own spec anti freeze/coolant, but any good quality upper market anti freeze can be used and some will even say that they are recommended by VW. Follow the directions on the container for mix and dilution.
Feb 04, 2011 | 2005 Volkswagen New Beetle Convertible
Can i use 50/50 antifreeze on 2006 chrysler 300
You can use anything you like that does not freeze at 32 degrees.
Most vehicles come standard with "extended use" coolants.
I do not purchase 50/50 mixed anything as you are paying for 50% water. Mixing stronger than 50% only lowers the freezing point.
The correct and safest answer for you is to look in your owners manual to see if Ethylene Glycol based coolant is factory recommended.
Most "extended use" coolants are not Ethylene Glycol.
Clean coolant is happy coolant when mixed correctly, don't pay for water.
Feb 24, 2010 | 2006 Chrysler 300
Changed water pump now my 95 jeep grand cherokee wont start
A 50/50 mix of an ethylene glycol based anti-freeze and water is recommended at all times.
The solution not only has a lower freezing point than water, it has a higher boiling point to prevent overheating.
Year round it acts as a rust preventative.
If you have A/C, it will prevent your heater core from freezing up.
Alcohol or methanol base coolants are specifically not recommended.
But to answer your question specifically:
To start, just water will work.
If this helped, please take a second and rate my response.
Mike
Jul 12, 2008 | 1995 Jeep Grand Cherokee
2007 Land Rover Range Rover Sport Coolant/Antifreeze Logo
67 people viewed this question
Top OES Genuine Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an OES Genuine Vehicle Part and Accessory Expert? Answer questions, earn points and help others
