Question about Pony Little Tikes Giddyup N' Go Pony
Foot peg keeps falling off my giddy up pony - Pony Little Tikes Giddyup N' Go Pony
How do I design a 6 foot diameter circle for my garden?
drive a peg in the ground where you want the center of the circle to be
get a piece of string and make a loop at one enf big enough to fall over the peg
measure out 3 ft from that loop and tie a stake at that point
now pull the string until it is tight and where the peg hits the ground make a mark
move about a foot an make another mark keeping the string tight all the whole
repeat the process until you have done a complete circle
the marks will be the circumference of a 6 foot diameter circle
Oct 12, 2014 | Esschert Design USA Esschert Design...
Giddy up and go pony's saddle won't bounce
I am having the same problem...did you fix it
Nov 30, 2012 | Pony Little Tikes Giddyup N' Go Pony
How can i remove the foot pegs from my XL1200 C Harley?
There's a pin that holds the foot peg onto the foot peg extension. Take the clip off the backside of it and remove the pin. The foot peg will come off.
Good Luck
Steve
Jun 18, 2011 | 2009 Harley Davidson XL 1200L Sportster...
How to change the shifter foot peg on my 2001 harley roadking classic
Remove pinch bolt from shifter. Remove shifter from shaft. You may need to spread shifter with wedge (screwdriver) to get it to slide off. Put on new shifter and tighten bolt to secure.
A little blue locktight will keep it from falling off.
Feb 07, 2011 | 2001 Harley Davidson FLHR - FLHRCI Road...
How to take off and put on a new foot peg on yamaha r6
get the correct size allen key,undo the footpeg bolt,remove bolt,pull peg out,be careful not to lose the spacers on each side of where the peg fits to the mounting point,and be sure to line the spacers correct the little holes go over the bearing on the peg to keep them snug when not in use,(rear peg only)rider peg s dont have this on them.
Jul 10, 2010 | 2003 Yamaha YZF-R6
Foot Pegs
Well yes and no, yes if you are willing to do a major renov and if keeping OEM then no. Get a Harley it is more kind to your height.
Mar 22, 2010 | kawasaki KX 450 F Motorcycles
New dryer keep blowing 30 amp fuses
your problem (especially if you are using screw-in "plug fuses") i.e. BUSS fuses and cartridge fuses they get hot and with time the insulating disc that insulates hot from neutral (grnd) breaks down and with dryer current draw it arcs over and in summer its more humid which contributes to moisture,have a new sub(pony) panel if you have no room for another 240volt circuit in your main panel,that should cure your trouble
Jul 19, 2009 | LG DLE5955 Dryer
Giddy up n go pony
We just purchased this pony for our daughter, We snapped on
the head tight, but it will not steer.
Any help would be appreciated.
Jul 09, 2009 | Giddy Up Rocking Horse
I just put together a Peg perego Polaris RZR ride on toy and it will go forward, but not reverse. The light showing a full battery goes OFF when I try to put it in reverse. Any ideas? Is there a loose wire...
For this Peg Perego Razor model, some of them have a lever that slips over the foot pedal to keep it from going in reverse for safety reasons.
I would check the foot pedal and see if it has one.
Let me know what you find.
May 06, 2009 | Polaris Ranger RZR Ride on Toy
Carolina rudder does not work properly
Slider to which the pegs are attached is probably binding, take entire mechanism out (2 screws), and lubricate with silicone wax. If that doesn't work, replace sliders and pegs.
Apr 06, 2009 | Carolina Manufacturing Perception Carolina...
Pony Little Tikes Giddyup N' Go Pony Logo
32 people viewed this question
Top Pony Toys Experts
Tony Curto
Tony Curto
Rainer Mueller
Rainer Mueller
Level 1 Expert
Jon Charlesworth
Jon Charlesworth
Level 1 Expert
Are you a Pony Toy Expert? Answer questions, earn points and help others
