Question about Singer Curvy 8770 Electronic Sewing Machine
Bobbin will not move,
Bobbin case does not turn, underthread does not move
Loose underthread and no zig zag
Lower thread tension can be adjusted by tightening (clockwise) the small screw in the bobbin case. The specifications call for 12-20 g resistance when pulling the thread slowly. I suggest tightening in increments of 1/8 turn and trying the machine each time. Also, mark the position of the screw in its original position should you need to return to the original setting and start over (use a piece of tape and place a mark where the slot in the screw is). I don't understand what you're saying about the zig zag problem.
Mar 12, 2014 | Husqvarna Sewing Machines
Bobbin case inserting wrong
hi, Can i ask what model Pfaff it is ?
Regards
Rob
www.electronicrepairs.co
Dec 29, 2013 | PfaFF Sewing Machines
I suspect the "housing" you refer to is not seated completely. Be sure to wiggle it until it slips into place. Once it is seated, the bobbin case should seat firmly as well.
May 02, 2017 | PfaFF Sewing Machines
Have a lockstitch elite for granddaughter, the top stitch looks correct but the bottom stitches are bunching up. What do I need to do?
Check for proper threading, check the pressure foot is down. and check to be sure the bobbin is in correctly. (some turn clockwise, other counterclockwise) check tensions (both upper AND bobbin tensions). These can all be causing
the "underthread" to bunch or tangle. good luck and happy sewing.
Jan 09, 2013 | Sewing Machines
How do i fix my sewing machine underthread keeps breaking
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
Nov 04, 2012 | Sewing Machines
Underthread in sewing machine keeps breaking
I am assuming your talking about the bobbin thread, so that is
the information I am sending you
Nov 04, 2012 | Singer Sewing Machines
Motor is spinning- needle not going up and down.
Check that the inner part of the flywheel is tightened up. This has to be loosened when winding a bobbin for underthread. Easy to forget to re-tighten it for sewing.
Apr 14, 2010 | Kenmore Sewing Machines
Small loops in the underthread
If the hook of the machine has a small burr on the point it can and will snag the upper thread and keep it from locking securely. The hook is what the bobbin case snaps on to. Take some light metal sanding material and polish the point to remove burr.
Jul 19, 2009 | White Sewing 1888 Mechanical Sewing...
Lost sparepart
It is called a bobbin case and most sewing dealers will have this one. It should be a standard case with a finger sticking up from the top. If you have metal bobbins they probably have a lot of holes in them.
sewman7
Mar 19, 2009 | Sewing Machines
Bobbin case is moving out of place
I was having the same problem with my machine and finally the spring broke. I couldn't find any parts for this so my husband made me a new spring out of a coke can! LOL!! Anyway, he messed with it for a while and it kept doing it. He figured out that it was not the spring but the other piece under the spring was not pushed up far enough to keep the bobbin case in place so he took a screw driver and pushed it forward toward the bobbin case and now my bobbin case does not move!! And the machine is sewing perfect! At least for now. Anyway, it's not the spring or the thread adjusting screw!
Jun 06, 2008 | Brother CS6000i Computerized Sewing...
Singer Curvy 8770 Electronic Sewing Machine Logo
22 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
