Question about Dell V313w AllInOne InkJet Printer
Cartridges are loose even after cover is snapped down
There is something wrong with the holder for the cartridges. It states that there is a print head problem. However, when I put in the new cartridges, they are loose. After clicking the holder in place, you the cartridges are loose. You can even remove them.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 90 Answers
Check printing head and cartridge are match or any lock lever was breaked
Posted on Dec 30, 2013
  • 3 Answers
SOURCE: Will not Align with New Ink Cartridge
HAVE TO REPLACE THE COLOR CARTRIDGE
Posted on Mar 25, 2009
SOURCE: printer says cover is open and its completely shut. wont print
Maybe something wrong with sensor which displays the state of the cover.
Try to find it.
Posted on May 31, 2009
pineworks
  • 4041 Answers
SOURCE: States "Right Cartridge incorrect"
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 30, 2010
caroldon
  • 17129 Answers
SOURCE: Printer tells me black cartridge is missing
Please remove your printer and uninstall the software from the PC. then reinstall the software and tehn connect back your printer to be detected and installed once again. I hope you have the software of the printer which came along with the set. This must get your printer back to action. I hope this helps . Good day
Posted on Jul 07, 2010
  • 34255 Answers
SOURCE: My Dell v313w printer only prints in black and blue ink.
Maybe Dell support can help
Posted on Apr 11, 2013
How to change ink cartiridges
  • 1
    Turn on the Canon iP2000 if the device is not on. Allow it to power up for about 30 seconds.
  • 2
    Gently lift the cover of the unit with your hands. Lift only the top cover of the printer.
  • 3
    Wait until the print head moves to the center of the unit. It automatically moves to this position, allowing you access to all the cartridges. Do not try to move the print head manually, or remove a cartridge before this part stops and the light turns green.
  • 4
    Remove the section of orange film on the side of the new ink cartridge. Twist off the small plastic guard on the bottom of the ink cartridge.
  • 5
    Remove the old ink cartridge from the ink cartridge holder with your fingers. Press the tab on the cartridge forward and then pull it up and out of the holder. Slide the new cartridge into its place. Push down on the top of the cartridge to snap it into the unit. Close the cover when finished.
Sep 03, 2012 | Canon PIXMA iP2000 InkJet Printer
Tip
How to replace a brother catridge.
The Brother MFC-240C uses an individual cartridge for each color (black, yellow, cyan, and magenta). When one of the cartridges is empty or near empty, the printer will tell you to replace that ink cartridge.
You can buy the cartridges individually, or you can buy a pack of all three color cartridges or a pack of two black cartridges. To replace one of the ink cartridges, follow the steps below.
All four of the cartridges are located on the right front side of the printer, behind a gray plastic cover. Pull the cover forward from the side, where there is a slight cutout for your finger to grab. When the cover falls forward, you'll see the four ink cartridge holders, coded by color.
For the ink cartridge that you need to replace, push down on the purple handle for that color. The ink cartridge holder will open and fall forward, revealing the ink cartridge itself. Push down on the cartridge holder and the cartridge should pop out toward you a little bit. Grasp the cartridge and remove it.
Open the new cartridge and remove it from its wrapper. Discard the yellow cover, unless you plan to use it for the old cartridge.
Insert the new cartridge into the correct slot (from left to right, they go black, yellow, cyan, magenta) so that the word "brother" is right-side up and located toward the top of the cartridge. Once the cartridge is most of the way in, push the ink cartridge holder up by the purple handle until it snaps into place.
If you are replacing more than one color, repeat this procedure for each cartridge. Then, when you are finished, close the ink cartridge cover.
If you were out of ink or low on ink, the machine should recognize the new cartridge and perform the calibration process. If it doesn't automatically recognize the new cartridge, it will ask if you have changed one or more of the cartridges. Press "1" for Yes when it asks about a color that you replaced, or "2" for No if it asks about a color you didn't replace.
Once the printer comes back up to the ready state, print a color test page to verify that everything is working. If the test page comes out okay, the new cartridge is fine and you can either discard the old cartridge in the trash or save it to recycle. (But don't get rid of it before you are sure that the new cartridge is recognized and working correctly.)
on Jul 21, 2010 | Office Equipment & Supplies
Tip
How to change an ink cartridge on the Brother MFC-240C
The Brother MFC-240C uses an individual cartridge for each color (black, yellow, cyan, and magenta). When one of the colors is out of ink, the printer will tell you to replace the ink cartridge. To replace a cartridge, follow the steps below.
All four cartridges are located on the right front side of the printer, behind a cover. Pull the cover forward from the side, where there is a slight cutout for you to grab. When the cover falls forward, you'll see the ink cartridge holders.
For whichever ink cartridge you are replacing, push down on the purple handle for that color. The ink cartridge holder will open and fall forward, revealing the ink cartridge itself. Push down on the cartridge holder and the cartridge should pop toward you a little bit. Grasp the cartridge and remove it.
Insert the new cartridge into the correct slot (from left to right: black, yellow, cyan, magenta) so that the word "brother" is right-side up and located toward the top of the cartridge. Once it is most of the way in, push the ink cartridge holder up by the purple handle until it snaps into place. Then close the ink cartridge cover.
If you were out of ink, the machine should recognize the new cartridge and perform its calibration. If it doesn't automatically recognize it, it will ask if you have changed one or more of the cartridges. Press "1" for Yes.
Once you have printed a test page with all four colors to verify that everything is working, either discard the old cartridge in the trash or save it to recycle. But don't get rid of it until you are sure the new cartridge is recognized and working.
on Jun 01, 2010 | Brother MFC 240C All-In-One InkJet Printer
Green light flashing and ink replacement light flashing red - when you press the button the cartridge holder will not move to the centre to allow it to be replaced
Hi!
Try to look for a ruler or something that will make you press the cartridge cover fully. It may be loose or not snap in properly thats why the cartridge holder won't go all the way.
Hope this helps.
May 05, 2011 | Epson Stylus 680 InkJet Color Printer
The print cartidge is missing
Please note the printer make and model and visit any computer shop - disclose the model name there they will give you the perfect cartridge. If you know how to fit the cartridge then well but if you don't then unpack the cartridges and please remove the plastic tape from the cartridge head or it will not work, open printer cover up - notice the empty cartridge holder in the printer, there you notice black and color cartridge holder. Look to the cartridge and holder you will understand the position of the cartridge to fit, now push the lower portion of any cartridge to the holder and give a very low pressure on the top (backward pressure to fit the in the holder). Same way you fit the next cartridge. Close the printer cover down. Print any document - it will definitely print.
Jun 09, 2010 | HP DeskJet F380 All-In-One Printer
Printing with no ink
1. Lift the front cover, and wait for the printer to move the old cartridges forward.
2. Take off or pull the clear plastic tape off of the back of the cartridge.
3. Pop the cartridge holder off of the top of the cartridge you are changing and pull the old cartridge out.
4. Carefully insert the new cartridge into the holder until it snap in place.
5. Close the front cover.
6. Your printer will automatically recognize the new cartridge.
7. Try to print a test page.
Oct 20, 2009 | Lexmark X5470 All-In-One InkJet Printer
Printer says cover is open and its completely shut. wont print
Try to find it.
May 31, 2009 | Dell 926 All-In-One InkJet Printer
My black ink cartridge
Follow the articles
1 Make sure the printer is on.
2 Lift the scanner unit until the scanner support keeps it open.
The print cartridge carrier moves and stops at the loading position.
3 Squeeze the tabs on the cartridge lids, and then lift the lids.
4 Remove the old cartridges.
5 Remove the stickers and transparent tape from the bottom of the cartridges.
6 Insert the new cartridge. Make sure the color print cartridge is
secure in the left carrier and then snap the lid closed.
If you are installing a black print cartridge, make sure that it is
secure in the right carrier, and then snap the lid closed.
7 Lift the scanner unit and push the scanner support back while
lowering the scanner unit until it is completely closed.
clean the black cartridge maybe dry up and fix it firmly. touching to the holder.
verify that the new black cartridge is not empty. else clean the pin touching to the holder.
http://www.google.co.in/url?sa=t&source=web&ct=res&cd=10&url=http%3A%2F%2Fsolutions.brother.com%2FLibrary%2Fpdf%2Fpdf-2700%2Fhl2700_tn_eng.pdf&ei=qWklSYulF5GYsAPRnYSADw&usg=AFQjCNFv49E3vrfRxw1WECg1Kc9GWgP-pw&sig2=NW91eX3PHasbq7WcNwPCVQ
http://www.ccs-digital.com/cartridgeproblem.asp
Nov 19, 2008 | Brother MultiFunction Center MFC-440CN...
No print head is installed in the cartridge holder. Open the printer's cover, then open the Inner Cover and install the print head properly. - I don't know how to do this...
What kind of printer. I just installed a new cartridge holder on my kodat easyshare 5100 and it was just easy to snap in to position; you remove the plastic orange caps first. After you do this, if you still have problems with printing, uninstall your software complete, disconnect the cable from printer to computer and then reinstall the software (be sure to hook up the printer when software installation requests you do so and not before). Restart your computer and it should be working fine.
Oct 13, 2008 | Canon Office Equipment & Supplies
How do I change the ink cartridge in my Lexmark x2470
How to Install or Replace the Ink Cartridges in the Lexmark i3 ID: 810 This document does not apply directly to your Lexmark X2470
  1. Make sure that plain paper is loaded in the paper tray.
  2. Ensure that the power light is on.
  3. Open the cartridge door.
    The cartridge carrier may move slightly, and then return to the loading position.
  4. Push up on the cartridge lever.The cartridge holder springs open.
  5. Remove the old print cartridge and dispose of it.
  6. Remove the sticker and transparent tape from the new print cartridge.
    Warning! Do not touch the gold contact area on the print cartridge.
  7. Install the new print cartridge as illustrated below. Insert the cartridge into the carrier slot. Push the cartridge lever back to secure it under the cartridge hook. Press the cartridge lever down until it snaps into place.
    Insert the color cartridge in the front carrier slot.
    Insert the black cartridge in the back carrier slot.
  8. Close the cartridge door.
  9. On the PC, open the Lexmark i3 Solution Center and click Print Cartridges.
  10. Then click Print Cartridge Installation and follow the on-screen instructions to install the cartridges.
Please Rate the solution.
All the Best
Sammy
Sep 26, 2008 | Lexmark Office Equipment & Supplies
Dell V313w AllInOne InkJet Printer Logo
29 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
