Question about Insignia NS-LCD47HD-09 47 in. LCD TV
Insignia 47" tv goes to blue or black screen after watching for a few minutes
Blue or black screen with sound requiring you to turn tv off and back on again
SOURCE: TV turns on for a split second then back to standyby
i think your capacitor is blown, do a google search for insignia, lcd, capacitor...
you can buy another one for about $2 but its a pain to install, you can also instead buy a new powerboard for about $80, its an east install and you wont blow more capacitors
bestbuy.partssearch.com
Posted on May 15, 2008
  • 133 Answers
SOURCE: no picture
Try a hard restart, which simply means unplugging the power cord, and replugging it after 4 hours have passed. This technique helps to reprogram the electronics, to a certain extent. ( Turning it off and on again by a switch will not work). If the picture does not return, then you might need the expertise of a TV repairman.
Posted on Jul 08, 2008
  • 718 Answers
SOURCE: TV was playing, then the screen turned black.
If the screen is black and you have sound then lightly press and shine a strong flashlight against the screen. If you see an image around the edge of the flashlight, an image is being 'displayed'. The problem is probably in the Inverter/CCFT or the power going to the Inverter.
Posted on Feb 24, 2009
  • 814 Answers
SOURCE: When i turn on tv screen is bright white instead of blue!!!
This is a problem that should be taken in for service as there could be many problems causing the problem. The power supply could not be supplying voltage to run the video card or you could have a failure in the video card itself. Try calling this number for Insignia Customer service help. 1-877-467-4289. Hope this helps you with your problem.
Posted on May 13, 2009
  • 814 Answers
SOURCE: I have a 37 inch Insignia flat screen tv. This
This unit needs to be tested in a service center because it has problems with the operation of the video card. This could be caused by a loss of voltage supplying the video card from the power supply card. Or a failure on the video card itself. You can purchase parts for unit from Best Buy Parts at !-888-237-8289 and get customer service at 1-877-467-8289. You should get an estimate from the service center, That should tell you which parts are bad and then you can proceed from there. If the prices seem too high for parts and labor from the service center, try buying the parts yourself and have them install them for you. You should try to check the prices on the parts , just to make sure you are getting a fair deal.You can do this by getting the part numbers, you should ask the service center to provide the part numbers needed if they need to replace the power supply board or video board and with your model number of television check out the prices and availability at the Best Buy Parts website.Of course if the television is still under warranty send it in for warranty service. Hope this helps you with your problem.
My Dynex 32" LCD tv seems to turn on and off
The blue light merely indicates that power is getting to your TV. It has internal power supply problems.
Nov 30, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
Syntax Olevia flat screen tv video goes off then on
Hi, Replace the bulging capasitors on the main power supply board. Thanks.
Sep 22, 2009 | Insignia 37" LCD Flat-Panel HDTV
Insignia tv will not powerup
Nothing at all? Does the screen seem to go from dark black to a lighter shade of black?
If the screen appears to stay on the darker shade of black then it is broken, and needs to be sent for repair. ( ie the screen isnt powering on when the tv is and there is nothing you can do without opening it.
You might try unplugging all cables and leaving it off with no power for a day This is in effect performing a factory reset.
and this may sound stupid and patronizing but is the TV being taken out of standby mode and actually switched on?
Nick
Sep 09, 2009 | Insignia NS-LCD47HD-09 47 in. LCD TV
Power failure
OLEVIA SAYS UNPLUG ALL (ELECTRIC, CABLE ECT. FOR 2 HOURS THEN REPLUG IN, THIS WILL RESET POWER PROGRAMMING0
Jul 12, 2008 | Syntax LT27HV 27 in. LCD HDTV
May 09, 2008 | Insignia IS-LCDTV32 32 in. Television
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Sony KP-51HW40 51 in. Rear Projection turns blue
Hello......
First reduse the G2 voltage for the blue c.r.t,and watch if the unit works for longer period (offcource blue colour will be not present).After reducing G2 voltage to blue c.r.t still behaves the same than c.r.t is faulty and you have to replace.
Pls count the red led blinking when it goes off,incase it goes to std by mode.
Gopali
Dec 14, 2007 | Sony KP-51HW40 51" Rear Projection...
Insignia NS-LCD47HD-09 47 in. LCD TV Logo
20 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
