Question about Bissell 3522 PowerForce Bagged Upright Vacuum
My vacuum sounds like a lawnmower - Bissell 3522 PowerForce Bagged Upright Vacuum
I have a b&d mm850 lawnmower. The height adjustment broke. Can I fix that myself?
try for a part first
otherwise get material that is around the same size and manufacturer a new one
May 21, 2015 | Vacuums
I have weedeater but my fuel line ic corroded what type of line do I need to order
There is special silicone piping made for weed eaters and it is available at all lawnmower spares suppliers. Do not use conventional plastic tubing, it goes hard in fuel and will not follow the fuel as the machine is manipulated.
Jun 08, 2011 | Vacuums
Hi, I desperately need a service manual for my Suzuki M120X lawnmower engine.
Try this link. Manual is for a Toro mower with a Suzuki engine. http://www.scribd.com/doc/38652193/Toro-2-Cycle-Engine-User-Guide
Aug 14, 2010 | Vacuums
How to replace electrical cord on Dyson ball vacuum cleaner. Our puppy chewed it.
Depending on where it has been chewed, you may not need to replace the whole of your cord. Ask your local electrical supplier, or possibly somewhere like B & Q, if they have an 'inline' plug and socket to repair your existing cord.this would resemble the type of plug and socket used to connectd the power chord to a lawnmower, except you would not be buying the sealed type.Then you could simply cut out the chewed part of your ccord, and fit the two new ends, one the plug and the other the socket.It is no more difficlt than fitting a new domestic 13 amp plug on a cable.It is also a safe but much cheaper solution, so you should save money too.
Jul 10, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Lawnmower
There may be a thermal fuse fitted to the motor, sometimes they reset when they cool down. Sometimes they are a one shot fuse, when they blow the have to be replaced.
There may also be a reset switch on or inside the operating lever/switch.
Have you also checked the operating switch/lever for a bad connection or a wire come loose.
Mar 31, 2008 | Vacuums
Vacuum sound is too loud
If its aloud grating noise the motors at fault the fan in the motor is catcthing its housibng
Nov 06, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Bissell 3522 PowerForce Bagged Upright Vacuum Logo
53 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
