Car Audio & Video Logo
B
Braden smith Posted on Dec 29, 2013
Where do I plug in
AMG301
Spark plug wiring diagram for a 2003 chevy malibu
SPARK PLUG WIRE REPLACEMENT (ENGINE CONTROLS - 3.1L)
Removal Procedure
  1. Turn OFF the ignition.
  2. Notice: Twist the spark plug boot one-half turn in order to release the boot. Pull on the spark plug boot only. Do not pull on the spark plug wire or the wire could be damaged.
  3. Remove the spark plug wires 2, 4, and 6 from the engine left side spark plugs.
  4. Remove the spark plug wires from the retaining clips.
  6. Remove the spark plug wires 1, 3, and 5 from the engine right side spark plugs.
  7. Remove the spark plug wires from the retaining clip.
  9. Remove the spark plug wires from the ignition coils.
  10. Remove the spark plug wires from the engine.
  11. If you are replacing the spark plug wires, transfer any of the following components:
    • Spark plug wire conduit
    • Spark plug wire retaining clips
Installation Procedure
  1. Install the spark plug wires to the engine.
  2. Install the spark plug wires to the ignition coils.
  4. Install the spark plug wires 1, 3, and 5 to the engine right side spark plugs.
  5. Install the spark plug wires to the retaining clip.
  7. Install the spark plug wires 2, 4, and 6 to the engine left side spark plugs.
  8. Install the spark plug wires to the retaining clips.
v\:* { behavior : url(#default#VML); position:absolute; } v\:* { behavior : url(#default#VML); position:absolute; }
07 chevy suburnan wiring diagram color
Item12 VoltsSecond 12 VoltsStarterSecond StarterIgnitionSecond IgnitionThird IgnitionAccessorySecond AccessoryThird AccessoryKeysenseData BusCan Bus HighCan Bus LowCan Bus SwPower LockPower UnlockLock MotorDriver Unlock MotorPassenger Unlock MotorParking Lights (-)Parking Lights (+)HazardsTurn Signal (Left)Turn Signal (Right)HeadlightAutoLightsReverse LightLeft Front Door TriggerRight Front Door TriggerLeft Rear Door TriggerRight Rear Door TriggerDome SupervisionTrunk/Hatch PinRear Glass PinHood PinTrunk/Hatch ReleaseTrunk Release MotorFuel Door ReleasePower Sliding Door (Left)Power Sliding Door (Right)Factory Alarm ArmFactory Alarm DisarmDisarm No UnlockTrunk Alarm ShuntTachometerWait to StartNeutral SafetyClutch PedalFuel PumpRear DefrosterMirror DefrosterLeft Front Heated SeatRight Front Heated SeatSpeed SenseBrake WireParking BrakeHorn TriggerWipersLeft Front Window (Up/Down)Right Front Window (Up/Down)Left Rear Window (Up/Down)Right Rear Window (Up/Down)Sun Roof (Open/Close)Sun Roof (Limit/Close)Memory Seat 1Memory Seat 2Memory Seat 3Radio 12VRadio GroundRadio IgnitionRadio IlluminationFactory Amp Turn-onPower AntennaLeft Front Speaker (+/-)Right Front Speaker (+/-)Left Rear Speaker (+/-)Right Rear Speaker (+/-)Center Channel (+/-)Subwoofer (+/-)Aux. Audio Input Left (+/-)Aux. Audio Input Right (+/-)RSE Video (+/-)RSE Audio Left (+/-)RSE Audio Right (+/-)Satellite Radio 12 VoltsSatellite Radio GroundSatellite Radio IgnitionSatellite Radio AntennaSatellite Audio Left (+/-)Satellite Audio Right (+/-)HeadunitLeft Front SpeakerLeft Front TweeterRight Front SpeakerRight Front TweeterLeft Rear SpeakerLeft Rear TweeterRight Rear SpeakerRight Rear TweeterCenter ChannelSubwooferLeft Front HeadrestRight Front HeadrestLeft Rear HeadrestRight Rear HeadrestSatellite Radio Tunerspacer.gifspacer.gifWire Colorred/black (60A), red/black (60A)red/white (x4) (15A each)purple (for starter kill only)pink/black (resistor code), white (5V reference)pinkN/AN/Abrown or yellowsame as second starterN/Asame as second starterdk. green (low speed GMLAN)tan/black (high speed GMLAN)tan (high speed GMLAN)dk. green (low speed GMLAN)use Directed interface modulesee power lockgraypurpletanlt. bluebrown (L), brown (R)whitelt. blue/white (F); yellow or yellow/black (R)dk. blue/white (F); dk. green or dk. green/wht (R)whitedk. green (ground to turn off autolights)dk. bluegray/black (ajar), tan (open)black/white or tan/whitelt. blue/blacklt. green/blackgraypink/blacksame as trunk/hatch pinpink/blackgray (liftgate), pink (liftglass) (rear handle sw)lt. blue (liftgate)N/AN/AN/Aarms on lock with door openlt. green (driver door key cylinder)Passkey and ignitionN/ANOT pinkN/AN/AN/Adk. green/whitepurpleorange or black (L), orange or black (R)dk. blue (back and cushion)dk. blue (back and cushion)dk. green/white (some models only)lt. blue/white (functions with ignition on only)lt. bluetangraydk. blue - browndk. blue - browndk. blue - browndk. blue - brownbrown - org or lt. blu (function with ign on only)N/Aorangesame as memory seat 1N/Ared/whiteblack(low speed GMLAN)yellow (dimmer)same as power antenna (some models only)whitetan - gray or tan - dk. greenlt. green - dk. green or lt. green/white - org/blkbrown - yellow or brown/white - browndk. blue - lt. blue or dk. blue - tandk. blue - orange (with surround)white - pink (with surround)yellow - (bare wire)white - (bare wire)dk. green - white/blacklt. blue - purplewhite - purplered/whiteblack(low speed GMLAN)(coaxial cable)brown/white - tan/whitedk. green/white - graydouble DIN6.56.55.255.25spacer.gifspacer.gifPolarity++++9.6K ohms+++6.3K ohmsdatadatadatadata5 wire5 wire5 wire-+-++--+----+---+-ac+reverse+ latched--ac+--+AAAA-+2.26Kohms+4.26Kohms+-+++,-+,-+,-+,-+,-+,-+,-+,-+,-+,-+,-+-+,-+,-spacer.gifspacer.gifWire Locationdash fuse box, black 40 pin plug (X1), pins F1 and E3BCM, black plug, pins 1, 2, 3, and 4starter or underhood fuse box, blk 50 pin plug (X2), pin F1 or F5ignition switch or BCM, lt. green plug, pins 2 and 4ignition switch or BCM, lt. green plug, pin 14ignition switch or BCM, lt. green plug, pin 21PASS-Key III+ Module, black 5 pin plug, pin 4data link connector, black 16 pin plug, pin 6data link connector, black 16 pin plug, pin 14data link conn, black 16 pin plug, pin 1 or BCM, lt. blue plug, pin 10driver kick or dash fuse box, black 14 pin plug (X3), pin B4driver window switch, brown 16 pin plug, pin 8driver kick or dash fuse box, black 14 pin plug (X3), pin B1headlight switch or BCM, white plug, pin 8underhood fuse box, black 30 pin plug (X3), pins A7 and F7hazard switch or BCM, lt. green plug, pin 19BCM, brown plug, pins 4 and 1BCM, black plug, pin 5; brown plug, pin 2headlight switch or BCM, white plug, pin 12headlight switch or BCM, white plug, pin 17BCM, white plug, pin 22driver window switch, brown 16 pin plug, pins 13 and 11passenger window switch, brown 16 pin plug, pin 13BCM, pink plug, pin 15BCM, pink plug, pin 14BCM, white plug, pin 5BCM, pink plug, pin 12hood switch or BCM, black plug, pin 17BCM, pink plug, pins 13 and 24passenger kick, harness to reardriver window switch, brown 16 pin plug, pin 4any fuel injectorECM, black 73 pin plug (X1), pin 50driver kick, harness to reardriver and passenger window switch, black 10 pin plug, pin 7driver window switch, gray 14 pin plug, pin 6passenger window switch, gray 14 pin plug, pin 6EBCM, blk 38 pin plug, pin 11 or 32 or radio, brn 16 pin plug, pin 5brake switch or BCM, brown plug, pin 6parking brake switch or BCM, brown plug, pin 16horn switch or BCM, brown plug, pin 18BCM, brown plug, pin 20driver window switch, black 6 pin plug, pins 3 and 1passenger window switch, black 6 pin plug, pins 3 and 1left rear window switch, black 8 pin plug, pins E and Hright rear window switch, black 8 pin plug, pins E and Hsunroof switch, black 8 pin plug, pins 6 and 4driver window switch, gray 14 pin plug, pin 5radio, black 14 pin plug, pin 1radio, black 14 pin plug, pin 8radio, black 14 pin plug, pin 7radio, black 14 pin plug, pin 6radio, black 14 pin plug, pins 2 and 9radio, black 14 pin plug, pins 3 and 10radio, black 16 pin plug, pins 5 and 13radio, black 16 pin plug, pins 6 and 14radio, brown 16 pin plug, pins 3 and 11radio, brown 16 pin plug, pins 4 and 12radio, gray 16 pin plug, pins 1 and 9radio, gray 16 pin plug, pins 2 and 9radio, gray 16 pin plug, pins 7 and 15radio, gray 16 pin plug, pins 3 and 11radio, gray 16 pin plug, pins 4 and 11Digital Radio Receiver, black 16 pin plug, pin 16Digital Radio Receiver, black 16 pin plug, pin 9Digital Radio Receiver, blk 16 pin plug, pins 2, 1Digital Radio Receiver, blk 16 pin plug, pins 3, 4center of dashleft front doorleft front pillarright front doorright front pillarleft rear doorleft rear pillarright rear doorright rear pillartop center of dashunder front of center consoleunder passenger dash, behind glove boxspacer.gifspacer.gifPhotohas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifspacer.gifspacer.gifNotehas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifspacer.gif
2helpful
Replacing sparkplugs on a 2003 YukonXL 5.3 Litre
Here's how to remove the spark plugs.
  1. Remove the engine sight shield, if necessary.
  2. Disconnect the spark plug wire from the spark plug. • Twist each spark plug wire 1/2 turn. • Pull only on the boot in order to remove the wire from the plug.
  3. Loosen the spark plug 1 or 2 turns.
  4. Brush or air blast away any dirt from around the spark plug.
  5. Remove the spark plug. If removing all the plug at one time, place each plug in a tray marked with the corresponding cylinder numbers.
  1. Inspect the spark plug gap. Adjust the plug as needed. Specification
    Spark plug gap: 1.524 mm (0.060 in)
  2. Hand start the spark plug.
  3. Tighten the spark plug. Tighten • For used heads tighten the plug to 15 N·m (11 lb ft). • For new aluminum heads tighten the plug to 20 N·m (15 lb ft). • For new iron heads, tighten the plug to 30 N·m (22 lb ft).
1helpful
Anyone have the 2001 VW Golf speaker wire colors?
If your Golf is the premium sound model here is the list:
2001 Volkswagen Golf Car Radio Wiring Schematic for Monsoon Audio
Car Radio Battery Constant 12v+ Wire: Plug #3, Pin #7
Car Radio Accessory Switched 12v+ Wire: Plug #3, Pin #4
Car Radio Ground Wire: Plug #3, Pin #8
Car Radio Illumination Wire: Plug #3, Pin #6
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Plug #2, Pin #5
Left Front Speaker Negative Wire (-): Plug #2, Pin #6
Right Front Speaker Positive Wire (+): Plug #2, Pin #3
Right Front Speaker Negative Wire (-): Plug #2, Pin #4
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Plug #2, Pin #7
Left Rear Speaker Negative Wire (-): Plug #2, Pin #8
Right Rear Speaker Positive Wire (+): Plug #2, Pin #1
Right Rear Speaker Negative Wire (-): Plug #2, Pin #2
Signal for Anti-Theft Alarm System Wire: Plug #3, Pin #1
Data Link Connector (DLC) K-Wire: Plug #3, Pin #3
Battery Supply Constant 12v+ Wire for Anti-Theft System (SAFE): Plug #3, Pin #5
CD Changer Data In Wire: Plug #1, Pin #13
CD Changer Data Out Wire: Plug #1, Pin #14
CD Changer Clock Wire: Plug #1, Pin #15
CD Changer Constant Battery 12v+ Wire: Plug #1, Pin #16
CD Changer Control Signal Wire: Plug #1, Pin #17
CD Changer Ground Wire: Plug #1, Pin #18
CD Changer Left Line Out Wire: Plug #1, Pin #19
CD Changer Right Line Out Wire: Plug #1, Pin #20
11helpful
I need the diagram to put the spark plug cables
2003 Chevrolet Malibu 3.1L SFI OHV 6cyl
Spark Plug Wires - Removal & Installation
3.5L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
    NOTE Twist the spark plug boot one-half turn in order to release the boot. Pull on the spark plug boot only. Do not pull on the spark plug wire or the wire could be damaged.
  2. Remove the intake manifold cover, if required.
  3. Disconnect the left side spark plug wires from the spark plugs.
  4. Disconnect the left side spark plug wires from the ignition coil.
  5. Remove the spark plug wire clips from the Manifold Absolute Pressure (MAP) sensor bracket and the heater inlet and outlet pipe tab.
  6. Remove the spark plug wire assembly.
  7. If replacing only one plug wire, open the retaining clips and remove the appropriate spark plug wire.
  8. Disconnect the right side spark plug wires from the spark plugs.
  9. Disconnect the right side spark plugs from the ignition coils.
  10. Remove the spark plug wire assembly.
  11. If replacing only one plug wire, open the retaining clip and remove the appropriate spark plug wire.
To install:
  1. Install the spark plug wire assembly.
  2. Connect the right side spark plugs to the ignition coils.
  3. Connect the right side spark plug wires to the spark plugs.
  4. If replacing only one plug wire, open the retaining clip and install the appropriate spark plug wire.
  5. Install the spark plug wire assembly.
  6. Connect the left side spark plug wires to the spark plugs.
  7. Connect the left side spark plug wires to the ignition coil.
  8. Install the spark plug wire clips to the MAP sensor bracket and the heater inlet and outlet pipe tab.
  9. If replacing only one plug wire, open the retaining clips and install the appropriate spark plug wire.
  10. Install the intake manifold cover, if required.
Fig. 2.2L Engine Firing Order: 1-3-4-2 Distributorless ignition system
Fig. 3.1L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
Fig. 3.5L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
Fig. 2.4L Engine Firing order: 1-3-4-2 Distributorless ignition system
Fig. 3.5L & 3.9L Engines Firing order: 1-2-3-4-5-6 Distributorless ignition system
I really hope help you with this (remember rated this help) Good luck.
8helpful
Cant find the spark plug location on 2002 4cyl tacoma
Locate the spark plug cover on the engine.On some Toyota Tacoma engines, the cover is across the top of the engine. On others, it is along the side 4 cyl. Remove the cover to reveal the ignition coils and spark plugs wires. The spark plug wires are plugged directly into the engine and the ignition coils are in the tip of the spark plug wire.
Remove the coil and wire from the spark plug. Twist and pull the plug out of the engine. Remove the spark plug from the cylinder well with a socket extender and socket wrench. Turn the wrench to the left to unscrew the spark plug from the engine.
Discard the old spark plug and apply a coat of anti-seize compound to the threads of the new spark plug.
Insert the new spark plug into the socket. Use the socket and extension to screw the spark plug into place.
Return the ignition coils and spark plug wires to the engine and turn it to lock the plug in place. Repeat the entire the process with the remaining spark plugs.
Replace the spark plug cover when all of the spark plugs are replaced.
Good luck and hope this helps and The spark plug tension may range between 11 and 15 foot pounds, depending on the size of the spark plug. The correct tension is indicated on the spark plug's packaging.
Hot and cold plug difference
Hot Plug - has a longer insulator nose length - less heat is absorbed by the plug and transferred to the cooling system - the plug runs at a higher temperature - the plug is more prone to pre-ignition (if greater than 850 degrees C) - NGK BP5ES is hotter than a BP7ES plug. - An overheated plug will be white with brown spots. Cold Plug - has a shorter insulator nose length - more heat is absorbed by the plug and transferred to the cooling system - the plug runs at a lower temperature - the plug is more prone to fouling (if less than 500 degrees C) - NGK BP7ES is cooler than a BP5ES plug. - A fouled plug will be black and sooty.
1helpful
Top Myron & Davis Car Audio & Video Experts
xxxxxx xxx
john h
Firdous Ahmad Lone
Firdous Ahmad Lone
Level 1 Expert
Are you a Myron & Davis Car Audio and Video Expert? Answer questions, earn points and help others
