Question about Kitchen Ranges
Model#GRSR3955ZWW-1 A friend of mine gave me a GE Evolution ceramic top stovce.. I don't have a manual. Is it normal for the top elements to cut in and out (5-10 seconds) while cooking something? The model # is GRSR3955ZWW-1.
Ge microwave ceramic element
The service manual is here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
You can download GE owner's manuals and installation instructions here.
Dec 27, 2013 | GE Microwave Ovens
Spectra GE model JBP64W0B4WW stove top burner stopped working
Which element is it? Try to switch the infinite switch from another element. This will tell you if it is the element or the switch problem.
Apr 06, 2013 | GE Spectra JBP78 Electric Kitchen Range
2005 Piaggio X9 Evolution 250 no top end speed
Hi, Dan and the usual suspects are:
1. Inlet system air leak.
2. Enrichener valve not seated or leaking.
3. Damaged or restricted fuel tank vent system.
4. Restricted fuel supply tract.
5. Dirty or damaged air cleaner element.
6. Plugged bowl vent or overflow.
7. Worn or damaged needle or needle jet.
8. Vacuum piston assembly malfunction.
9. Loose or plugged main jets or passages.
10. Improper float level.
11. Accelerator pumps inoperative.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Troubleshooting
Leo vince fitted loss alot of power
PIAGGIO MSS X9 EVOLUTION 250 Workshop Manual
Piaggio X9 EVOLUTION 250 2004 Parts
PIAGGIO X9 Evolution 125 Owner Manual
Aug 05, 2017 | 2005 Piaggio X9 Evolution 250
GE Evolution stove/oven. My oven is not working,
remove heating element an check with ohm meter. pretty simple really.
Jun 12, 2009 | GE Ovens
Kenmore Elite dryer won't heat but otherwise operates normally
Make sure you have 220V. The dryer will work (no heat) if only getting 110V. Check your thermostats with your Ohm meter. Mkae sure plug is disconnected and you disconnect thermostat wires. Should have continuity. Just because you have checked your heating element and you have continuity that does not mean it is good. How can this be? Easy, sometimes they (coil in heating element) break and arch against the housing or ceramic insualtors (depending on model) and you will have continuity. This just happened to mine and without a visual inpsection of the heating element do not aaume it is good.
Jan 07, 2009 | Kenmore Elite HE4 Electric Dryer
Baking element
oh bleep, right? well, if you're lucky this will get you going again. 1. disconnect power to range. 2. remove back metal cover just above range power cord (usually 5 quarter inch hex screws) 3. look for burnt off wire leading to/from bake element. If yes, 4. strip ends of broken wire and splice with ceramic wire nut if no 4. bad news. replace ERC (electronic range control) you fried something on the board. It's got the clock display and all the electronics behind it.
Aug 29, 2008 | GE JBP90 Electric Kitchen Range
Whirlpool electric stove
the sensor is built on to the top of the surface element if it was me id replace both the element and switch so you only have to go in once but its probably the element
Jan 19, 2008 | Kitchen Ranges
Ge range
If the ceramic ring you're talking about is around the far outside of the element, then it being broken isn't a big deal (as long as pieces aren't missing). Its just an insulator.
If the knob is stripped, how are you turning the burner on? Are you sure the problem is the element and not the knob?
Either way, since your "friend" cut the wire, the element is not going to work properly. The crimp connections are designed to be removed and replaced, and the element is not going to come with any additional parts. Go to Radio Shack or an auto parts store and get a replacement crimp connector. You'll have to strip and recrimp a connector on the wire your friend cut. The wire may not be long enough now, though, so you'll have to twist the element while installing it so that the wire will reach. This should be fine as there's plenty of room to spin the element around.
Oct 24, 2007 | GE Spectra JBP78 Electric Kitchen Range
Kitchen Ranges Logo
119 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
