Question about Cell Phones
Blackberry error Error 10-0015
Hi I haven't used my phone for a couple of years. when I switch it on now it say.. error 102 reload software... what do I do?
You need to do a Factory Reset, AKA a Hard Reset. This removes everything on the phone and reloads the operating system. Your phone is a Blackberry?
  • Error 102 Reload Software - BlackBerry Support Community ... https://supportforums.blackberry.com/t5/BlackBerry-Device-software/... Hello, I've just had a problem with my Blackberry 9930 phone. I already tried updating the Blackberry Desktop Software and I also tried the phone,
  • Error 102 - Reload Software - Blackberry Torch 981 ... https://supportforums.blackberry.com/t5/BlackBerry-OS-Smartphones/... Hi. I took the battery out of my phone and when the phone re-booted I now can only see a white screen with the error 102 and states reload software.
  • How to Reload Blackberry Mobile Software - Snapguide snapguide.com > Technology > Explore
    • 3.5/5
    • 10 RATINGS
    • BY TAHANI ALGHAREEB
    i will teach you how to reload your blackberry soft ware when its got error 102 and not working by this steps. all you ... How to Reload Blackberry Mobile Software
  • JVM Error 102 on your BlackBerry? Try this solution BEFORE ... crackberry.com > ... > Classic > Z30 > Z10 > Q10 > Leap > OS 10.3.2 Video embedded · JVM Error 102 on your BlackBerry? Try this solution ... JVM Error 102 on your BlackBerry? Try this solution BEFORE wiping! ... "Error 102. Reload Software ...
  • Terpecahkan: Curve 9360 Error 102 (Reload software ... forumdukungan.blackberry.com/...Error-102-Reload-software/td-p/258111 Terpecahkan: Dear all, Saya newbie disini, BB saya curve 9360, sudah mati 5 hari dengan error 102 (reload software). Sudah coba ikut instruksi dari
  • How to fix an error 102 reload software blackberry torch ... www.askmefast.com > ... > Error How to fix an error 102 reload software blackberry torch 9810? ... How can I fix reload error 102 on blackberry torch 9810? Comment. Reply. Report.
  • ERROR 102 www.blackberryos.com/general-blackberry-issues/38452-error-102-a.html
    • 2 POSTS
    • FIRST POST: 2013-08-12
    2013-08-12 · how do i reload software on a bb 9360?? ... Join Date Dec 2010 Location Gainesville, FL PIN Jarmeling Device Passport OS 10.3.2.2134
  • May 20, 2016 | Cell Phones
    JUM Error 517
    The actual error is JVM Error 517. It means the file system on your blackberry is corrupt.
    To correct this, follow the steps outlined below:
    1. If not already installed, download BlackBerry Device Software and BlackBerry Desktop Manager from the wireless service provider web site.
    2. Install BlackBerry Desktop Manager and then install the BlackBerry Device Software.
    3. Use Application Loader to reload the software on the BlackBerry device.
    Good luck and thanks for using fixya!
    Dec 10, 2010 | RIM BlackBerry Bold 9700 Smartphone
    BlackBerry Curve 8300 Smartphone: jun error 513...
    Thank you for using Fixya1
    Based on www.blackberry.com the error message you are getting is due to typing incorrect password for a couple of times (10 or more).All of the data and applications on the BlackBerry smartphone have been deleted.
    The BlackBerry® Device Software must be reloaded on to the BlackBerry smartphone. For instructions, click HERE
    Note: Due to the Java Virtual Machine (JVM) error, the BlackBerry smartphone will not show a Connected state in the BlackBerry® Desktop Manager. Proceed to reload the BlackBerry Device Software using the Application Loader.
    Sincerely,
    stif_nec
    May 18, 2010 | AT&T Blackberry Curve 8300 Smartphone
    My phone has an error that say device error 400 reset. it wont even let me use it or nothing
    When adding, deleting, or updating applications on your BlackBerry smartphone, you receive the following error message:
    Device error 400
    OR
    your BlackBerry device resets itself and stops responding.
    CAUSE
    An unspecified error has occurred with an application on your Blackberry smartphone.
    RESOLUTION
    NOTE:The following procedures will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the data on your BlackBerry smartphone before performing this procedure.
    1. Disconnect your Blackberry smartphone from your computer.
    2. Open BlackBerry Desktop Manager.
    3. Open BlackBerry Application Loader.
    4. Reset your Blackberry smartphone.
    5. When the LED indicator has turned on, reconnect the BlackBerry smartphone to the computer.
    6. Click Next.
    7. On the following screen you will see either USB:Unknown or USB:; click Next.
    8. Select the required applications from the applications list and click Next. The firmware is loaded to your BlackBerry smartphone.
    Jun 11, 2009 | RIM BlackBerry 7290
    JUM Error 513, no backup
    Overview After typing an incorrect password ten times and restarting the BlackBerry smartphone, the following error appears:
    JVM error 513
    Cause All of the data and applications on the BlackBerry smartphone have been deleted.
    Resolution Re-install BlackBerry® Device Software on the BlackBerry smartphone and restore the data from a backup file (if available).
    Mar 30, 2009 | AT&T Blackberry Curve 8300 Smartphone
    Jum error 102
    JUM error 102..how do i resolved this
    Sep 10, 2008 | RIM BlackBerry Pearl 8100
    Error code 507
    dear,
    i have the problem of 507 error on my blackberry model 7290. please be of help and tell me what to do about it.
    thanks
    ogbonna
    Nov 28, 2007 | RIM BlackBerry 7290
    Cell Phones Logo
    22 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
