Question about Spec-D 99-05 Volkswagon Golf IV / 99-02 GTI LED Halo Projector Headlights /w
2002 Golf won't start
Antitheft alarm is on. The dash alert is a picture of a car with a key in it. How can we reset the car? The car will turn over and start briefly, but will shut of as soon as it starts running.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 31 Answers
Un-hook your battery-let it set for a few minutes-this should reset everything-
Posted on Apr 23, 2014
Reset security alarm
The security, antitheft or lock picture/icon is a visual indication that something in the car's antitheft system is failing. In most GM cars and trucks there is a hidden system that most people are unaware even exists. From the moment you put your key in the ignition, there begins a constant line of communication between your key's security chip or transponder, to the ignition's lock cylinder, and then to the car's TDM (Theft Deterrent Module). These 3 parts are in CONSTANT communication. If the key is in the ignition, then these parts are sending signals to each other. The security light illuminates when that signal gets broken, even just for a second. When the signal breaks, the car misinterprets this as an attempt at theft and goes into antitheft mode. The car thinks its being stolen or hotwired because it is not getting that signal from YOUR specific key. This is why the security light turns on and shuts down your vehicle. This link explains it pretty well.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Mar 27, 2014 | Cadillac STS Cars & Trucks
2004 lincoln ls in antitheft mode
start with fully charging your battery.
Dec 28, 2013 | 2004 Lincoln LS
2004 cavalier won't start, need to reset anti-theft
the way i reset the antitheft is to put the key in the ignition and turn it on till all the dash lights come on but dont start it let it sit 15 minutes turn the key off and turn it on again till all the lights come on again repeat this procedure three times after the third time turn the key off for about 5 seconds and then your car should start hope this helps.
Mar 30, 2013 | 2004 Chevrolet Cavalier
How to reset security alarm on 98 firebird
The security, antitheft, or passlock light is a visual indication that something in the car's antitheft system is failing. In most GM cars and trucks there is a hidden system that most people are unaware even exists. From the moment you put your key in the ignition, there begins a constant line of communication between your key's security chip or transponder, to the ignition's lock cylinder, and then to the car's TDM (Theft Deterrent Module). These 3 parts are in CONSTANT communication. If the key is in the ignition, then these parts are sending signals to each other. The security light illuminates when that signal gets broken, even just for a second. When the signal breaks, the car misinterperates this as an attempt at theft and goes into antitheft mode. The car thinks its being stolen or hotwired because it is not getting that signal from YOUR specific key. This is why the security light turns on and shuts down your vehicle.
This link may help you find ways to bypass this or fix it yourself.
Mar 15, 2013 | 1998 Pontiac Firebird
1999 lincoln navigator turns over won't start dash board lights stay on with key out.
sounds like antitheft system is acting up..needs reprogramed maybe..pull the negative cable with the key on....kills everything..then shut the key off..reconnect the negative.. turn the key to run position for a few seconds(resets all factory presets) see if it will start..
Feb 10, 2013 | 1999 Lincoln Navigator
2002 MONTE CARLO SS DALE EARN HARD EDITION CAR WILL NOT CRANK OVER TURN KEY ON DASH LIGHTS COME ON TURN KEY TO ON CAR WONT CRANK OVER LIGHTS GO OUT AS IF CAR IS GOING TO START BUT WILL NOT ...
Either your battery is dead, or the antitheft is activated unintentionally. Here is a link for the antitheft
Apr 22, 2012 | 2002 Chevrolet Monte Carlo
Our 2002 alero won't turn over /start with key but starts by jumping. Test shows battery and fuses OK
Look for a light that says SECURITY or ANTITHEFT on the dash. This light could cause this problem. Explained on this link.
Nov 18, 2011 | Cars & Trucks
2004 Hyundai Elantra won't start, emergency flashers keep blinking, can't shut off, lights dim, can't jump start, clicking from under dash from relays. What could it be?
The 'Keyless Entry & Burglar Alarm System" is activated. You must 'Disarm' the system using the Keyless Entry Remove (Key Fob) to "Reset" the system. The reason the engine won't start is due to the burglar alarm - it has a "Starter Kill" circuit which is activated when the alarm is activated. The alarm must be DEactivated to DEactivate the 'Starter Kill' circuit.
Another way to start the engine is to get in the car, put the key in the ignition and turn it to 'ON" and wait 3 to 5 minutes until the emergency flashers stop/turn off. Afterward, you should be able to start the engine. NOTE: This does NOT reset the burglar alarm. It will go off again when you enter the vehicle without using the remote/key fob.
Sep 06, 2011 | Hyundai Elantra Cars & Trucks
Imobiliser problem
If im not mistaken,your car should have an alarm reset/override.Below the steering column,on the dash should be a slot where you put your remote transmitter to deactivate the alarm.If that works,you then need to have your remote checked and coded by a vw dealer.Good luck.
Jun 16, 2009 | 1997 Volkswagen Golf
Golf indicator lights flashing when locking with beeper
possible ecm reset needed (electronic control module) This is easy to do at home with a pair of visegrips or a wrench set. anyway the idea is to disconnect the car batt for atleast 2-3 minutes and with the key out of the ignition replace the batt terminals and tighten them wait 2-3 minutes and then get in car turn key only to light the dash this is called the post, once the dash has sat in the active position for the time said 2-3 minutes, turn car off remove key replace key and start the car let it run for a min or so and then turn off and exit the car and proceed to activate the alarm if the prob still is there i then suggest an ecm test any mechanic or dealer will test it for a nominal fee, if there is any thing at all not right with the car this test will get to the root. and if the test is showing no problems with the car the issue is most likely in the electronic keychain alarm keylock box
Jun 01, 2009 | 1996 Volkswagen Golf
Spec-D 99-05 Volkswagon Golf IV / 99-02 GTI LED Halo Projector Headlights /w Logo
59 people viewed this question
Top Spec-D Clothing Accessories Experts
Da Doc
ray gallant
Are you a Spec-D Clothing Accessory Expert? Answer questions, earn points and help others
