Question about Car Audio & Video
ND3T-W56 - 2006 Toyota Runx Radio Problem.
I have a 2006 Toyota Corolla RunX and the factory radio ND3T-W56 is not working proerly. As all the wordings are in Japanese and the only words I could pick up is CD - Open/Close and Remove. I have removed the CD and the display is saying something about CD. i have a feeling its need to be rebooted but i do not have any software for it. Can someone please guide me to where i can get a reboot CD for this radio.
melnavz
  • 1226 Answers
SOURCE: AVIC-N2 The AM fm radio XM radio Backup camera do not work
please try to update the software i guess its a software problem, please try also a hard reset. i think only the sofware.
or you may consult some other experts here.
Posted on Apr 09, 2008
SOURCE: Remove the radio from 1997 Toyota Corolla
i have a 97 corolla as well, and i've changed the radio out several times on my own. if you take a small screwdriver and stick it in between the panel that goes around the around the area where the radio is, u should be able to pry it off relatively easy. just be sure to remove the sliders off the AC controls before you do. after you pop that panel off, you just have to disconnect the wiring harnesses going to the clock, hazard lights, rear defroster, and AC button. the radio is bolted in there with a mounting bracket, so you'll have to unscrew that as well. you'll need to unscrew that bracket from the radio you have in there, and mount it to the one you wanna install....hopefully this helps you out. it sounds harder than it really is.
Posted on Sep 17, 2008
SOURCE: car radio removal
This isn't hard, you just need to breath deeply and take courage.
Be aware that the centre moulding where the radio is extends ove the steering wheel and the whole thing needs to come out. There are screws under the switches that release this panel and the panel under the wheel. Remove them all. Note the cables for the instrument lights and speaker.
Note the grommet around the ignition switch. You have to work this with a screwdriver so the top panel can come forward. This grommet will pull off but I bet you can't do it before the panel comes off. Do it before you put it back.
The panel is click-fit into the centre console. You can lever it off with a paint scraper. Note the lighter wiring.
Once the panel is off the radio is held in by 4xcrosshead screws, just looking at you.
Needless to say, the brackets are exclusively Toyota and fitting a new third party radio is not so easy. Your best bet for a replacement is a good one out of a wreck of the same vintage. It will go straight in and plug up. I got a Camry one. It has security coding but fortunately it was never activated. If the radio is coded make sure you get the full details and provenance. You may need to get it reset by the dealer.
Good luck
Posted on Mar 02, 2009
  • 217 Answers
SOURCE: Remove radio
Replace the CD player. To pull the plastic baffle off the dashboard: Adjust the heating vents so they point downwards. Grab the plastic bar between the heating vents and the stereo. Pull. Remove the screws from the front of the mounting brackets. Pull out the crappy stereo. Unplug the antenna and the wiring harnesses. Transfer the mounting brackets to your new stereo. Cut off the big wiring harness (unless you're lucky enough to have a replacement stereo that accepts the same kind). Connect the wires to the wires on your new stereo's harness. For more info: check the website: http://tomclegg.net/toyotastereo
Posted on Jul 15, 2009
  • 12 Answers
SOURCE: need instructions on how to remove my 2005 toyota corolla radio
Tools required: Phillips screwdriver, small flatblade screwdriver, rachet with 6 inch extension & 10mm socket.
1. Remove negative battery terminal (for stray voltage & airbags.)
2. Remove gear shift trim
3. Remove cable attached to lighter socket.
4. Remove center climate control knob and screw beneath it.
5. Gently pry both bottom corners of climate control face (up then towards the rear) until clear of lock.
6. Pull entire climate control console rearward until clips release. Leave all wiring attached.
7. Remove 4 bolts under radio (10mm.)
8. Gently pry between dash and AC ducting panel (both sides) and pull out.
9. 4 clip hold radio to ducting panel, gently pry while pulling radio out the back.
The rest should be easy...
9. 4 clips hols radio to
Posted on Aug 15, 2009
Can you fit a Toyota runx 1.8 engine into a Toyota runx 1.4 body?
I would think so.they were both offered in that platform.
Aug 08, 2017 | Toyota Cars & Trucks
Where can I find power steering fluid reservoir runx
Toyota Run X
You should find the PS reservoir for your Run X in the same location as is shown in this video of the Toyota Corolla power steering reservoir. It is clearly shown in the video.
Check Power Steering Level Toyota Corolla 2003 2008 2007 Toyota Corolla CE...
Apr 18, 2016 | Cars & Trucks
Toyota problem
maybe the button in the fob to lock the car is worn and might need replacing...it also could be a bad circuit.
May 30, 2014 | 2005 Toyota RunX 160i
Toyota runx 2004
get the codes checked something as simple it needs an oil change or a O2 sensor is bad
Jan 29, 2014 | Cars & Trucks
Want toyota corolla runx 2004 owners manual
I want a Toyota Corolla Runx 2004 Free English Owners manual
Aug 09, 2013 | 1994 Mitsubishi 3000GT
HOW TO SET CAM TIMING ON TOYOTA RUNX 4ZZ
Information how to set timing for toyota corolla 4zz engine.
Jul 21, 2012 | Toyota Corolla Cars & Trucks
I BOUGHT A USED CAR,ITS ON AND ON THE SCREEN IT DISPLAYS THE WORD (ALL OFF) i need a master code to reset or help plase its a kenwood in Toyota Runx
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your Toyota servicecentre and get them to enter this code for you.
Jun 25, 2012 | Kenwood Car Audio & Video
Hi, I was driving my 2003 toyota runx 1.6 RT when the red oil light came on the dashboard. While I was driving the engine switched off. What could be the problem?
check oil levels every fill up of gas.
if you see drop of level then, then check more often.
same answer for 100 years,and will never change. (otto cyle engines, ICE)
if not, say good bye to $3000 for a new engine.
read the opr guide yet?
Jul 25, 2010 | 2002 Toyota Corolla
My dashboard shows two arrows light what does it mean?
corolla runx 2003 petrol fill light stays on with left arrow
Apr 09, 2010 | 2003 Toyota Corolla
Car Audio & Video Logo
237 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
