Question about Canon PIXMA MP610 InkJet Printer
Showing printer error 6A00
Canon pixma printer error 6A00. Cannot solve error by turning power off then back on like printer suggests!
  • selinaganim May 19, 2009
    BAB thankyou so very much!!!!
  • Anonymous Mar 18, 2014
    error comes up
    Sergeant:
    Champion:
  • 240 Answers
I just copy this solution for you to this link:
the solution is posted by BAB..
they have the same problem as you ..then this solution solve it..^^
http://www.fixyourownprinter.com/forums/inkjet/39177
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Posted on May 19, 2009
The copy shows a error code 6A00 I can't do anything with it the ink cradle does not light up
Solution Canon Pixma IP4300 Error 6A00, this reset tips is from someone in printer forum but the tutorial in picture. You can follow the instruction in the picture to solve error 6A00 in Canon iP4300. Some users say on the forum this reset method also work on Canon iP4200 and Canon MP800. Look the picture below to view the complete tutorial how to solve Error 6A00
Larger picture here
Jul 07, 2011 | Canon Office Equipment & Supplies
Error code 6A00
>shutdown the machine & disconnect it from the computer
>check for any obstructions
>power on and try re-seating the cartridges
what happened before this issue started ?
Aug 25, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Jammed paper removed flashing green and yellow error code 6A00
6A00 meens jammed paper. Check that there is nothing inside, take the paper tray all the way out and look inside. Unplug the power, the take it back in and turn on the printer to see if that solves your problem.
Jun 05, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Canon pixma all in one mp500 error code 6A00
6A00 is a problem with the sheet feed unit.
Manually move the print head left and right, and turn the printer on/off. I would also inspect the rollers for ANY debris... it can often be fixed by using "canned air" and blowing the interior out completely.
Apr 29, 2010 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP800 error code 6A00 - what does it mean
Canon says you need to send it to them to fix.
Before you do, turn the printer off and try moving the carriage back and forth a few times. At the same time, look for any debris in the area that could be jamming the sheet feed unit.
Turn the printer back on and see if the error goes away. Several other people with this problem report solving it this way.
Oct 05, 2009 | Office Equipment & Supplies
Your Problem: canon ip service error 6a00
Had this error and did the following to solve the problem.
Turn the printer off.
Open the top cover and move the printer cartridge to the left.
On the right you can see a white part.
Press it down.
Turn the printer on.
if that doesnt help then there its better to call canon...
thank you have a nice day
Jun 02, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Will not turn on error 6A00
This is what I found from a service manual: AP position error [6A00] - Sheet feed unit (QM2-1220) - Logic board ***'y (QM2-1786)*1
What does it mean? This link should be useful: http://www.fixyourownprinter.com/forums/inkjet/37440
May 30, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Please problem solve
Hi
Error 6A00
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jun 11, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Error Codes 6A00 and 5C10
I tried everything suggested on other posts (cleaning paper feeds and making sure rollers were free, moving carriage back and forth manually, etc)., but nothing worked. With it still plugged in, I turned the whole thing upside down and shook it. It hummed and buzzed, and moved the carriage a couple of times. Viola, problem solved. Go figure.
May 03, 2008 | Canon PIXMA MP830 All-In-One InkJet...
MP600
when i turn on my mp600 canon printer i get the same error code 6A00! i cannot do anything with the printer, please help!
Apr 08, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP610 InkJet Printer Logo
606 people viewed this question
old marine
old marine
