Question about Fisher and Paykel DE60FA-US Dryer
Need a comparable timer for fisher de60fa - Fisher and Paykel DE60FA-US Dryer
Fisher & Paykel DE60FA-US2 dryer will not come on
Replace thermistor on blower motor FIRST then try it - could be the door switch as well.
De60faus2 Parts from RepairClinic com
Dec 28, 2014 | Fisher Dryers
Dryer timer not working
Cycle the dryer without the vent on, if there is a clog in the vent from the back of the dryer to the outside the dryer doesn't think the clothes are getting dry so it won't time down, If it times down without the vent on then you know the dryer is fine and its just an obstruction in the wall vent line. If it still doesn't advance depending on which cycle it is it could be a thermostat or the timer it's self.
Jan 31, 2014 | Fisher and Paykel DE60FA-US Dryer
Won't come on.
Sounds like there may be wiring problems where your dryer connects, causing your breakers to trip. I'm no expert but that's definently my first guess
Jul 18, 2013 | Fisher and Paykel DE60FA-US Dryer
When we close the dryer door the dryer starts
Your start switch and or start relay is bad..
Nov 12, 2012 | Fisher and Paykel DE60FA-US Dryer
My Fisher Paykel DE60FA-US6 Dryer overheats, shuts down
one simple thing I would check is make sure the vent hose is not stopped up. double check wiring on 4 post
connect the white wire, along with the white wire from the machine, to the center post suing one of the three screws you removed. This is the neutral connection.
Next connect the black wire, one of the "hot" connections, to the left side post using another of the screws. This is one-half of the 240-volt connection.
Finally, connect the red wire, another of the "hot" connections, to the right side post using the last of the screws. This is the other half of the 240-volt connection. Snuggly tighten the screws so that the wire connections are held into place, but don't overdo it.
hope this helps
Jun 25, 2012 | Fisher and Paykel AeroSmart DG27CW1 Gas...
Why does my fisher tv go off by itself after a short time?
You need to try and turn the Sleep timer OFF.Look in Menu sleep timer.
Mar 01, 2011 | Fisher PC-25R20 25" TV
No heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 12, 2011 | Fisher and Paykel DE60FA-US Dryer
Dryer drum squeaking when operating
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fggf
May 24, 2009 | Fisher and Paykel DE60FA-US Dryer
Fisher and Paykel DE60FA-US Dryer Logo
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
