I have a sa pt956 panasonic surrounds sound that won't change inputs with the remote
ohms
  • 1879 Answers
SOURCE: Not getting proper surround sound
Greetings,
I would like to refer you to leethedeuce, he knows more about audio system setups.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jul 08, 2008
  • 3 Answers
SOURCE: I get surround sound whenever i'm playing dvd's.
the red and white cables only carry the left and right channels of the full
5.1 mix
to get all 5.1 channels of sound
you need a "toslink" optical cable
there should be a small square shaped plug right under the red and white sound outputs on the back of the tv
just be sure that you're av receiver has the same plug before you buy the cable
Posted on Sep 20, 2009
SOURCE: how to make a panasonic sa-pt956 code free
I solve the problem partly. I don't now how to make a panasonic code free, but I now how to play any disc on this dvd player no matter of region. On your computer you need to use Nero Vision to burn the dvd and everything warks perfectly.Nero burning studio you can get from huckers pages 'torent search engine' (everything is free) and find nero vision in it.To record this file , use 'bit lord' , 'bit comet' etc. If you download movies,music from internet , everything is easy,but if you buy dvd in the store with any region and you want to use in any dvd player ,this proceder need more atension ,but is easy too.
I didn't find out how make dvd code free , but I found how to make disc code free , so you can play it on any dvd player.
Posted on Oct 23, 2009
  • 447 Answers
SOURCE: Replacing Panasonic SA-HT500 with Newer Model that has HDMI Input
ANY amp will be ok, as long as the wattage of your new amp does not exceed the wattage of your speakers. Otherwise you could overdrive your speakers and damage them. First clue, if you turn up the volume and the speakers start to shut off and on you are pushing too much power to them.
Posted on Feb 03, 2010
heavyice
  • 374 Answers
SOURCE: panasonic surround sound system model # sa-ht95
Error code ' F61 ' on most Panasonic models indicate that the built-in diagnostics has sensed a fault at the output stage. This would normally refer to a failed output amplifier IC (?P/N RSN704D66P?). In some instances, the fault could also be triggered by:
  • strands of Speaker wires inadvertently touching each other;
  • faulty speakers;
  • failed Cooling Fan of the output IC.
Options then are:
  • consider a DIY (do-it-yourself) repair only if familiar with electronic components & circuitry, use of a DVM/VOM and a soldering iron. Access to a Service manual would be an advanatge;
  • seek the services of an authorized service center specially if the unit is still under warranty;
  • consider other options based on downtime, cost of repair, parts of availability, age of unit and prices of comparable but newer models.
Good luck
Posted on Mar 06, 2010
Panasonic SA-HT930 surround sound. Only the left and right speakers have sound. I need to check the pro logic setting, however, I have lost the remote.Is there any way to activate surround without it?
There doesn't appear to be any buttons on the unit which activates any sound setting. Without a remote you are stuck. Worse still is that remote for your model seems to be no longer made. If I have the right code, you can try searching for it yourself.
EUR772XD0.
Have a look on the Curry's Partmaster website for a start.
Aug 18, 2015 | Panasonic Audio Players & Recorders
Hi, Can I buy a 5 disc changer for the panasonic SA-PT956 home theatre system, sounds like it has stripped gears. Thanks
They are available from panasonic. I have replaced many. There is a skill level needed to work on one of these. You should get the service manual also.
Sep 01, 2011 | Panasonic Audio Players & Recorders
My Panasonic SA-PT875 surround sound system won't
Hi, I have the same issue ! ... Can you let me know if you fixed it please.
Regards Brad
Aug 16, 2011 | Panasonic Audio Players & Recorders
I would like to connect my computer to my panasonic sa-ht800v unit and hear the sound thru the surround sound speakers
In general, your PC's sound card (and its controlling software) will determine what it can connect to.
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for analog audio connection. Any Line Level input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
The SA-HT800's single LINE Input would accept the Green stereo audio or speaker output from a standard PC, once adapted. Select VCR.
Find your PC's Sound Controls and enable the applicable input. make sure the volumes of both Inputs and Outputs are turned up.
Though not applicable to theGemini, more-advanced sound cards and audio hardware would have similar adaptable 5.1 or 7.1 (paired) analog outputs and / or digital audio outputs that conform to the s/pdif or Dolby Digital standards.
Mar 26, 2011 | Panasonic sa-ht800V Home Theater Audio...
I have a blue ray Prayer connected to my Panasonic SA-HE100 via a toslink digital audio cable. I don't get 5.1 surround sound. I do get stereo but not 5.1 where the back speakers sound. Any...
hi,
do one thing
1. press and hold DIGITAL INPUT button on the remote( will display AUTO--PCM FIX--DTS FIX)
2. select AUTO among them. and the try
ok
Jan 31, 2011 | Panasonic SA-HE100 Receiver
Hi, I have a Panasonic sa-ht870 DVD home cinema system to which the remote has stopped working however the front 2 speakers still work and so do the controls on the DVD player. I bought a new remote and...
Is it a universal 'Generic' remote or dedicated Panasonic for the SA-HT870?
If generic, it may not have compatible firmware built in for Surround function.
If dedicated, check menu settings and OP manual - there may be an option that is disabled there.
Oct 28, 2017 | Panasonic Audio Players & Recorders
My Panassonic SA-XR50 Receiver is not producing surround sound from either of the Optical imputs from the TV or DVDR Both outputs are stereo L and R + subwoofer How do I rectify this What settings should I...
First enable the surround sound mode for the selected input and verify that the media playing is recorded in some mode of surround sound.
You can however, acheive surround sound from 2 channel sources with dolby prologic or prologicII sound processing, or other proprietary modes that your receiver might have from the manufacturer.
Jun 12, 2009 | Panasonic SA-XR50 Receiver
Low sound when turned to AUX for surround sound
remember to turn the volume up on the cable box and down on the surround sound so you will get max audio input to the surround system and then adjust using the surround sound remote! good luck
Jan 11, 2009 | Panasonic SC-HT680 System
Technics surround sound system
Use whatever TV sound output conforms to your receiver's input. If an optical or coaxial digital sound output is available, that is the way to get 5.1 surround sound through the SA-DX1050. But you have to assign the correct input (COAX, OPT1 or OPT2) to the selector (TV, DVD, CD). See pp 12-13 of the operationg instructions for D-Input instructions. If you don't have the manual you can download it at Panasonic.com.
Dec 29, 2007 | Technics SA-DX1050 Receiver
21 people viewed this question
 Grubhead
Grubhead
