Question about Yamaha Full-Size Keyboard
Problem with multiple usb hub adapter
When I connect a device say my usb printer I receive this message:
This usb device can perform faster if connected to usb 2.0.....
what can i do?
    Problem Solver:
  • 10 Answers
Your computer does not support USB 2.0. If you wish to obtain these higher speeds you will need to upgrade your computer, or install an expansion USB 2.0 Card.
This is an example of a card that is likely to work:
http://www.newegg.com/Product/Product.aspx?Item=N82E16815124007
Posted on May 19, 2009
Why are the Keys on my axiom pro 61 not sending MIDI messages?
Does your keyboard have a "MIDI OUT" port? If yes, then
there is a selection to choose between USB or MIDI OUT port.
For my M-AUDIO oxygen 61 (silver), I must press the [Advanced] button then Note F3 on the music keys manual to toggle the MIDI-OUT.
If set to INT, it will not sent via USB. If set to USB it will not send via MIDI-OUT port. To use MIDI-OUT port I need external 12V DC adapter.
Jul 29, 2014 | M-Audio Axiom Pro 61 Advanced 61-Key USB...
Zoom h1 handy recorder
Download the H1 driver for windows & try different usb cable........
Mar 09, 2017 | Music
Behringer XENYX 2442 FX: Turntable into CD/tape IN. CD/tape OUT connected to USB device IN. Why is there no signal from mixer to the computer?
If I read correctly, you have outputs on the Behringer (CD/Tape Out) connected to inputs on the Behringer (USB Device In). Is that correct? If so, try going from CD/Tape Out directly to the computer. If not, please explain what the "USB Device In" is.
Thanks,
Rich
Apr 30, 2012 | Music
Re: Casio WK-210. Audacity, Jet Audio and Ctrl Pnl allow me to choose a USB PnP "record from" option, however, no sound is being recorded from the Casio to the PC. What am I doing wrong. Many...
Pat, the USB output on the Casio WK-210 is only capable of sending and receiving MIDI information. It's not sending any digital or analog audio. Audacity is primarily for sound file editing.
In order to use the keyboard to record onto your computer you can connect an audio cable from the 1/8" stereo mini-jack to an input on your computer. Then you can record into Audacity.
Or you can acquire MIDI recording software (ie. Logic, Cubase) and then using the USB output on the keyboard, you can control and record multiple MIDI instruments in those programs.
Feb 23, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
My axiom 61 dont want to work anymore but it comes on says something about my usb connection
Where do you see the error about USB, on the Axiom display or on your computer? Can you give me the exact error? Is the Axiom connected directly into the computer or into a USB hub? (My Axiom 49 only works connected directly) Try restarting both the computer AND the Axiom with ONLY the Axiom plugged in.
Feb 21, 2011 | M-Audio Axiom Pro 61 Advanced 61-Key USB...
I'm attempting to connect my new axiom pro 61 via Midi cables to my mbox2. To do this I understand I must rely on the power supply rather than USB. When plugging the axiom in to the wall it will not turn...
The AXIOM SHOULD turn on with just the wall wart adapter so you HAVE A PROBLEM.
First thing is to check the adapter that it is the correct one. It should be a 12 VDC 1 amp unit with positive center pin output.
Common adapters for pedals WILL NOT WORK.
Assuming you have the correct adapter, VERIFY the connector is plugged fully in the AXIOM.
Feb 09, 2011 | M-Audio Axiom Pro 61 USB Keyboard + Sp2...
How do i make daw's program program change messages with a dx-21. or must i buy a keyboard controller.Im using Intel. Pen. 3 with 2.2 ghz win. xp v5.1.2600, e-mu dsp audio processor (wdm). software bundle...
ALWAYS to answer your question, refer to the "MIDI IMPLEMENTATION CHART" for your MIDI instrument.
This chart can be found USUALLY near the end of your user's manual.
This chart, among other things, will tell what can be transmitted and received by the MIDI device.
Refering to the chart for your DX21 it shows that the DX21 can both receive and transmit program changes.
If you don't have a user manual, download one here:
http://www.maths.abdn.ac.uk/~bensondj/dx7/manuals/dx21-man.pdf
Nov 09, 2009 | Yamaha Music
Roland RD-700SX as MIDI keyboard
Theres a good article at recordingreview.com. If you join which is free you have access to a lot of great information. You can download Midiox to troubleshoot your midi connections etc. Make sure that your transmit channel on your keyboard matches up with the receive channel in your program. Hope this helps.
Jul 16, 2009 | Music
My hard drive and midi controller wont work with usb
When you connect a hard drive and any other USB device to a 4 port hub you have to use the external power supply all the time. You may have fried the power pins on the USB port you used to connect the 4 port hub. If you can get the hard drive to work separately on the USB port, the 4 port hub may no longer be passing power from the laptop.
Nov 09, 2017 | Vestax Vci 100 Midi Controller
Yamaha Full-Size Keyboard Logo
770 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
