Question about Toys
Barbie Dream House Pillar
The door bell pillar on the Barbie dream house will not fit into the hole on the second floor. The door bell pillar is square inside, the hole on the second floor is round.
4 Suggested Answers
SOURCE: Need the instruction manual for the 1980s Barbie Dream House
You can find a copy of the instructions on ebay for $5. Otherwise, its not impossible to figure it out without them. There are also spare parts on ebay, or you can buy a second house, make one complete one and sell one off for parts.
Posted on Jul 04, 2009
minuuu
  • 242 Answers
SOURCE: how do you get the
you wil get some serial bulbs or some decorative lights in shops
Posted on Dec 24, 2010
SOURCE: The fireplace does not light
Make sure the fireplace is pushed up against the wall of the house...it may snap into place. This worked for me
Posted on Dec 25, 2010
Instructions for barbie dream house elevator
Take some sand paper to the elevator top (the hard plastic) and sand the edges that interfere with the 2nd and 3rd floors. it then goes up and down easily. This thing is definitely "built to a cost" as some have already suggested..
see here for more information:
http://www.transitionsmobility.com/home_elevators_lexington.php
Dec 10, 2012 | Mattel Toys
Looking for barbie dream house replacement parts.
barbie dream house replacement parts can be found on amazon, click here and take a look: Amazon com barbie dream house parts. I hope this was helpful. Cheers
Oct 13, 2012 | Toys
Clean sun roof drain lines
James, I had the same problem with my XC90. First, open the sunroof, and pour a little bit of weater in the drain holes at the front of the sunroof opening. It should only take a few ml/oz to fill them up if they are clogged. Provided the drain is clogged, remove the handle on the pillar of the passengers side, (handle separating the windshield from the passengers door), Use a utility knife, or very small screwdriver to open up the plastic covers, which reveals the small bolts underneath. The handle will come off, anong with the pillar moulding, which will reveal the tubing from the sunroof drain. The end of the tubing fits into a hole in the metal pillar (sq hole I believe), and is made of a soft moulded rubber. This rubber (when removed from the hole in the pillar), has a "plus" shaped hole in it to allow the water to escape. This is where the colg will likely be. dirt, leaves, etc comes down this tube, and gets stuck in the small rubber pcs at the bottom. You can either clean this pc out, or what was suggested to me, was to cut a small pc off the end, to allow water to flow much easier. Just take a little off the end, not so much that it will not stay in place. After you have cleared the drain, and installed the tube back in place, test the drain from above agian, to ensure that this was the only clog. Water should run out on the ground within seconds of being poured into the drain holes at the front of the sunroof. (water should pour out at the bottom of the fender, ahead of the door hinges, and should not be visible in the vehicle)I would reccomend doing both sides, even if you do not see a problem with the drivers side. The entire process will only take you 20-40 minutes. An easy fix to a major problem. Worse than water on the floor, is that there are electronic complnents/sensors on the floor of the passengers side that can be affected by water. I have to repalce my YAW sensor, under the pass seat, because it has gotten wet, and now causes caution lights in the dash regarding stability control. Best of luck. Colin W
Nov 23, 2011 | 2004 Volvo XC90
I lost the instructions to put this barbie dreamhouse together can you tell me where i can get a copy so i can do this today, can you send me a link. thanks. i am desperate.
Link to the mattel site: http://service.mattel.com/us/product_detail.asp?id=N7666&Ntt=N7666&Pn=7&Brand=Barbie&Cat=Barbie+Accessories%2FFashions%2FPlaysets
Opens up a windows. Click on both avaialbe PDF's and download to your pc.
Hope that helps!
Mar 06, 2011 | Mattel Barbie 3-story Dream Townhouse...
Barbie Pink 3-story Dream Townhouse fireplace doesn't work and the chandeler light doesn't come on
For the fireplace, if you press the back wall the fireplace backs to, and the button at the same time, it lights up and crackles.
Dec 26, 2010 | Mattel Barbie 3-story Dream Townhouse...
The fireplace does not light up on the Barbie Dream House
Dec 24, 2010 | Toys
How do you get the fireplace to light up in the barbie dream house?
Dec 24, 2010 | Toys
I cannot get the fireplace to light up or make crackling sounds on the Barbie Dream Townhouse.
The fireplace most likely came loose in shipping. If you can get your fingertips behind the fireplace and pull if forward a bit.... then it is loose. The is a bar/clasp behing the fireplace the top needs to rest/attach to.... lift up and push back on the fireplace until it 'clicks'. (you will feel it when it sets in properly) One attached correctly to the wall... when you push button to make the TV go up - the fireplace also lights up and makes sounds.
Dec 24, 2010 | Mattel Barbie 3-story Dream Townhouse...
Toys Logo
44 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
